Question about Panasonic Irons
I have an iron Panasonic NI-685E. How to remove iron plate?
jmgldsmth
  • 1889 Answers
SOURCE: Panasonic Iron won't heat
most iron cases can not be seperated from the iron plate but, if you can take off the bottom plate you will see a heating element and attached to that a small cylinder it has a point on one side and a flat end on the other it is called a thermal fuse and radioshack sells them
they are made in different versions so take the fuse in to get the right one clip it back in and your iron should work again
Posted on Apr 24, 2009
oscarn
  • 109 Answers
SOURCE: My panasonic NI-R73NR iron went off and is not coming back on.
Check fuse in plug, check wire in plug for loose connection. Turn the thermostat a little higher to 'freeup' the contact mechanism. Check continuity with a ohm meter on the irom conacts, check lamp on iron
Posted on Sep 21, 2007
  • 158 Answers
SOURCE: removing deposits on iron plate
Try adding some CLR to the iron, fill it up with water, and run self clean. Then wipe bottom of iron with an old towel. Repeat with clean water in the iron, to rinse out the CLR and minerals.
Posted on Jun 22, 2009
  • 13 Answers
SOURCE: Panasonic Iron NI-R73NR will not heat up
Either a bad thermostat or a bad heating element or an open connection somewhere in the power cord. My advice, toss it!
Posted on Aug 27, 2009
SOURCE: sticky substance on iron plate
get some of the Rowenta remover, YOu put it on your sole plate when Iron is warm. I use an old facecloth, put some on the cloth, then drag the iron side ways or back and forth. Then a clean towel to clean, when it does nto remove, i put some directly on the iron, does a pretty great job.. keep up with the stuff. If you are using fusible things when you Iron, you set yourself up with sggrivation, but a teflon cloth from a quilt store or on line,.It is used for applique and works great.
Posted on Jan 30, 2010
How do i increase the iron heating temperature (thermostat) in Panasonic Electric Iron NI-22AWJ
Check the voltage at your power point, irons draw a lot of power. most irons have a temp setting switch cool med hot . If this a new iron return for service.
Feb 18, 2015 | Panasonic Irons
My iron is not warming up any more what can i do?
A. Check the wire connections. If so, tighteing or chaning the cord with do . B. Thermostat migh got suck, if so, inspection of it will show and you need to gently sand the contact point. Or worst case senario, the heating element (coil) inside the heating plate might have been burnt, is this is the case, the iron is toast.
Sep 19, 2011 | Panasonic NI-A57SR Iron with Auto Shut-off
I have black burn on the soleplate of my iron that nothing seems to get it off. any suggestions
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaning a Steam Iron Soleplate
heatman101
Dec 17, 2010 | Panasonic NI-C78SR Iron
Panasonic NIA56NR NI-A56NR Iron shut off and wont turn back on
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Oct 04, 2009 | Panasonic NIA56NR NI-A56NR Iron
Apr 24, 2009 | Panasonic NIA56NR NI-A56NR Iron
Panasonic iron NI-A56NR wont turn on
first test your heating element to see if it is working.
You can by pass the control module by removing it from the line. Just disconnect all wires that goes to the module and put aside, then, connect back lead to the far right connection and white wire to the third connection from the left. Be careful playing with electricity is hazardous to yout health if you don't know what you are doing.
Jan 17, 2009 | Panasonic NI-A57SR Iron with Auto Shut-off
Iron is out of order
an appliance repair center could probably fix it but you have to consider the cost against a new iron
mostly it is more costly to repair than to fix
Oct 19, 2017 | Panasonic NI-A57SR Iron with Auto Shut-off
Water drips out of steam holes
I suspect that by placing it on its heel rest the water from the tank is not allowed to enter into the steam chamber and when you go into ironing mode there is a rush of water that is cooling down the sole plate to below steaming temperature. Try keeping it in the horizontal position on a heat proof pad and press the steam button just before going into ironing mode.
Sep 08, 2007 | Panasonic NI-H10NS Iron
Aug 11, 2007 | Panasonic NI-R73NR Iron
Irons Logo
70 people viewed this question
Top Panasonic Irons Experts
Jim Goldsmith
Jim Goldsmith
Bill Boyd
Rani wadia
Rani wadia
Are you a Panasonic Iron Expert? Answer questions, earn points and help others
