Question about GE Dishwashers
Central water tower does not extend upward when in wash cycle
  • GE Master
  • 3,247 Answers
Please provide the model number of your GE dishwasher
That will help me assess the problem you are having.
It is likely the wash tower is jammed or the pump is not generating enough water pressure to lift it. If I assume your model no. is GSD3200 then the parts will look like this in the diagram. That should help you open it up and clean etc and put back. Look for wear etc of the pump impeller.
Posted on Sep 09, 2010
Bosch maxx 1000 - when finished cycle, leaves central fabric conditioner drawer full of water + trace of condtioner.
Check that the hose that connects the drawer to the tub is clean, fabric conditioner normally gunks up especially on colder wash cycles.
Apr 01, 2015 | Bosch Washing Machines
Wash cycle takes too long
If the incoming water is very cold it takes longer to heat
this extends the cycle length
Sep 20, 2014 | Bosch Washing Machines
Water Sprays Upward & All Over - On The Floor - HELP
Have you checked the hose in the back it might be loose and it sounds like it is out of balence check the little feet that screw out and make sure its balenced and be sure not to over fill with clothing it may need to be rebalenced the drum
Nov 16, 2013 | Crosley Washing Machines
Indesit D41 Dishwasher draining problem. the filter on my dishwasher isn't letting through water, I attacked it with a plunger but I don't know how to open it up to unblock it. please help
First check this. Clean the water inlet filter at the tap outlet regularly. - Turn off the water tap. - Unscrew the end of the water inlet hose, remove the filter and clean it carefully under running water. - Replace the filter and screw the water hose back into position.
Then, if needed check this. Cleaning the filters
The filter assembly consists of three filters which remove food residues from the washing water and then recirculate the water. They should be cleaned if you wish to achieve the best results in every wash. Clean the filters regularly. The dishwasher should not be used without filters, or if the filter is loose. After several washes, check the filter assembly and if necessary clean it thoroughly under running water, using a non-metallic brush and following the instructions below: 1. Turn the cylindrical filter C in an anti-clockwise direction and pull it out (fig. 1). 2. Remove the cup filter B by exerting a slight pressure on the side flaps (fig. 2). 3. Slide out the stainless steel plate filter A (fig. 3). 4. Inspect the trap and remove any food residue. NEVER REMOVE the wash cycle pump (black detail) (fig. 4).
Always keep the door of the appliance ajar in order to avoid moisture from forming and being trapped inside the machine. Clean the seals around the door and detergent dispensers regularly using a damp sponge. This will avoid food becoming trapped in the seals, which is the main cause behind the formation of unpleasant odours.
Preventing unpleasant odours
Food residue may become encrusted onto the sprayer arms and block the holes used to spray the water. It is therefore recommended that the arms are checked from time to time and cleaned with a small non-metallic brush. The two sprayer arms may both be removed. To remove the upper sprayer arm, rotate the locking ring in an anti-clockwise direction. The upper sprayer arm should be replaced with the holes facing upwards. The lower sprayer arm can be removed by pressing on the side tabs and pulling it upwards.
Cleaning the sprayer arms
After cleaning the filters, replace the filter assembly and fix it in position correctly; this is essential for maintaining the efficient operation of the dishwasher.
Leaving the machine unused for extended periods
If the water hoses are new or have not been used for an extended period of time, let the water run to make sure it is clear and free of impurities before performing the necessary connections. If this precaution is not taken, the water inlet could become blocked and damage the dishwasher.
Cleaning the water inlet filter*
Disconnect the appliance from the electricity supply and shut off the water tap. Leave the door of the appliance ajar.
When you return, run a wash cycle when the dishwasher is empty.
That should cover all your bases
Oct 21, 2013 | Dishwashers
Problem with wash tower of GE GSD2200G00ww not rising up
if the tower isn't rising DURING the wash cycle it is most likely caused by one of 2 issues. 1 being too low of a water level which can be caused by low flow thru the pipes, blocked filter in the inlet valve, or a bad inlet valve. The 2nd cause can be low pump pressure due to the main food shredder screen, located below the large plastic "filter" in the rear right-hand corner, being plugged with garbage. The valve can be replaced if needed, the filter can be cleaned w/o removal of the entire unit, but if the water flow is low, you will most likely need a plumber.
Nov 22, 2012 | GE Nautilus 24" Built-in Dishwasher
While moving my samsung top washing machine, I think my drain hose pipe has moved down the water level. Now machine is not able to retain the water while washing/soaking. I need to pull the drain hose pipe...
Although a few modern washing machines can operate with the drain pipe at any height, most machines will drain the water as soon as the drain pipe is placed below the machine water level.
The simplest solution for your problem would be to ask somebody with some handy man skills or hire a plumber to add a 2 inch PVC pipe to your drainage pipe which extends to a point behind your washing machine & then points upwards, making sure it is long enough to be at a higher point than your machines fullest water level.
This should be a relatively inexpensive alteration & will ensure that water does not drain unless the machine is on its drain cycle.
Please let me know if you need any further assistance.
Best wishes,
Graeme
Mar 10, 2011 | Samsung SW62ASP Top Load Washer
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Center water tower came apart
There have been many versions of the spray tower used over the years. If you have the model HDA3400G which you posted under, you should get a part number WD22X10008 which is the lower spray arm and tower assembly. By looking at the new part, you will see how a couple tabs hold the part on, and can figure out how to remove the old one with a flat blade screwdriver (or two). If you have a different model, please post the exact model number. The model number sticker is generally located on the left side wall of the tub, right by the front.
Apr 19, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Dishwasher needs repair
Bonnie, the spray arm itself will have a tower that extends upward. On the lower rack in the center will be a tower protector and the upper rack should have a water diffuser in the middle. The protecter and diffuser will clip on to the center of the racks. Hope this gets you going..
May 28, 2006 | Roper 24 in. RUD5750DB Built-in Dishwasher
Dishwashers Logo
100 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
