Question about Samsung Televison & Video
Samsung HL61A750 parts manual - Samsung Televison & Video
Ineed a user manual!
Easier done than said... go up on the SAMSUNG USA site at
TVs 3D LED LCD Plasma HDTV Televisions Samsung
Go to ...(but do not stop there... (model # ready))
Download Center Download Software Firmware Drivers Manuals Samsung Download Center Download Software Firmware Drivers Manuals Samsung
Put in your Model # (say UN40eh5300F)...
and every manual... and guide you ever wanted will appear at
It's all GOOD... Just never trust SAMSUNG to refer you for Samsung PARTS SALES...
When EVERYTHING goes wrong ... then Samsung USA will tell you "Samsung Parts" (not part of SAMSUNG) is just another flea market...
(I'm just saying... Having PAINFUL personal experience)
Jan 14, 2016 | Samsung Televison & Video
Manual for samsung model LN22B460B2DXZA
Sears Parts Direct has the User's Manual for the LN22B460B2DXZA here: http://www.searspartsdirect.com/partsdirect/user-manuals/ln22b460b2dxza-samsung-parts-lcd+tv-manual?pathRender=fromManualTabPage . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0904079.pdf .
Samsung has additional documentation on the product support page: http://www.samsung.com/us/support/owners/product/LN22B460B2DXZA . Scroll down to the Manuals section and then expand the See More link. You will need to accept the Samsung terms of use for their manuals. The direct link to the User's Manual (English & Spanish) is currently http://downloadcenter.samsung.com/content/UM/201104/20110426142936710/BN68-02034A-00L02-110426.pdf .
I hope this helps.
Jan 01, 2016 | Samsung Televison & Video
Check Fan #1 message on screen.
that would lead me to believe it needed to go to a repair shop.If I were not an electronics minded person .
Sep 26, 2015 | Samsung Hl61a750 61" LED Powered DLP HDTV
White dots on screen
http://www.metacafe.com/watch/yt-XeIOwN1CIp8/samsung_mitsubishi_toshiba_dlp_hd_tv_repair_tips_black_white_dots_on_tv_problems_bad_dlp_chip/
I believe it is the digital projection chip that is beginning to fail. Causing white and black spots to appear. To repair this may cost more than a new tv. If you want to attempt it yourself check out the above link. Hope this helps
Jan 12, 2014 | Samsung Hl61a750 61" LED Powered DLP HDTV
I have a Samsung hl61a750, and the tv will lose picture while watching, but the sound will remain for about 20-30 seconds, then the tv will turn itself off completely then restart itself. Once it has...
Sounds like you have some bad capacitors on your power supply. If you are good with a soldering iron, this is a simple fix. There is a group of either 1000mf/10v or 2200mf/10v. they will be easy to spot out, because they will be swollen, rounded on the top. Replace them and you should be good to go. If this is something you are not comfortable doing, then I would take it to a authorized service center. You would mostly just pay for labor, as the parts are only a couple of dollars.
Apr 08, 2011 | Televison & Video
Samsung HL61A750 61 Inch 1080P Led Powered DLP HDTV will not stay on. It can be turned on, but 15 or 20 seconds go by and it goes/tunrs off. Everytime.
It sounds like the lamp bulb, I had the same problem and I took the bulb unit out of the back, cleaned it out really good and replaced it, it works fine now and I didn't have to buy a new bulb unit for about $200.00. Good luck.
Sep 06, 2009 | Samsung Televison & Video
Samsung hl61750a - unable to display video service over hdmi
I was using an hdmi cable purchased online. A friend told me that it might be the 'cheap' hdmi cable. I tried a set of Monster hdmi cables and problem solved. So all hdmi cables are not the same.
Jan 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Digital Cable Ready Question
Hey barfinkl1,
"Digital cable ready" TV's have a built-in feature that allows them to receive both standard and high definition signals, typically through the use of CableCARD technology instead of a set-top box.
While this specific Samsung model (HL61A750) is not digital cable ready, it does feature both an ATSC and Clear QAM tuner. This means that it should still be able to receive locally broadcast and unscrambled over-the-air digital signals, but will require a set-top cable box to receive any kind of scrambled digital signal.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 17, 2008 | Televison & Video
Televison & Video Logo
322 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
