Question about HP Officejet 5610 All-In-One InkJet Printer
We put the wrong ink cartridge in and now it won't come out
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
push it very hard down and pull it out
hope i help you
Posted on Oct 30, 2010
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
Put brand new lexmark 28 cartridge just 4 days ago. Maybe used 10 times. Computer says ink is low and won't print anymore. However, can still make copies.
It could be just a slight communication failure between your cartridges and the printer. Try to re-seat the cartridges by removing and re-inserting them into the cartridge carrier.
I hope this helps.
Mar 02, 2012 | Lexmark X2500 All-In-One Printer
My printer won't align new ink. It says load paper in tray. I load it. then blank page come out and gives me the same message. Load paper in tray. I did a diagnostic test and at the bottom it says...
Sorry to know you're in trouble with your printer. Here are my suggestions: You have to buy a new genuine cartridge or you can refill ink. Be warned! Refilling ink or using a refilled ink cartridges will not work until the ink cartridge chip or ink monitor is disabled. For instructions on how to disable an ink cartridge chip, please visit [http://www.ehow.com/how_6201242_disable-ink-cartridge-chip.html]Now you can CURSE the manufacturer of your printer for making your life sucks by making it complicated the things that should be made SIMPLE and EASY. Printer or Cartridge, more or less, cost you the same. Don't you think the printer cartridges should be made simply refillable/usable unless they are broken, and we should be buying only the ink for the cartridges. It is SO ANNOYING, dude! Good luck.
May 06, 2011 | Office Equipment & Supplies
Says cartridge cannot be used after initialization but brand new HP 363 cartridge sent directly by HP to me. This happens ever time I put a new cartridge in when prompted by printer to do so. Do I put new...
The following are common issues.
The following ink cartridges cannot be used after device initialization and must be replaced
Cause The wrong ink cartridge(s) are installed.
Solution The indicated ink cartridge(s) cannot be used after the device has undergone first time setup. Replace the ink cartridge(s) with the appropriate ink cartridges for the HP All-in-One. To find out the reorder number for all the ink cartridges that the HP All-in-One supports, see the printed documentation that came with the HP All-in-One.
If you are using compatible cartridges make sure they are reset for use.
Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might need to be cleaned. If there are no ink cartridges missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge.
Sep 21, 2009 | HP Photosmart 3310 Printer
Pic`s wrong colors
you need to check
1) same color ink of the cartridge almost empty, change a new ink cartridge or refill the color ink (there is only one ink cartridge)
2) the cartridge ink channel dryer and constipated, take out the cartridge put the bottom surface touch down clean water (a little) 1 hr, then set back if the cartridge has enough ink.
Feb 05, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Wrong Cartridge
replace print head. print head is bad.
Jul 27, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Refilling HP 56 Cartridge
USING THIS TYPE OF REFILLS JUST ISN'T A GOOD IDEA. THE INK IS NOT THE SAME AS HP CARTRIDGE INK AND YOUR PRINTER WAS MADE FOR HP INK, NOT SOME GENERIC BRAND. THE FACT THAT IT DOESN'T WORK UNLESS YOU STICK IT IN WATER, ETC. SHOULD TELL YOU SOMETHING IS WRONG HERE. REFILLING IS MESSY, AND CAN CAUSE LEAKS IN YOUR PRINTER AND REALLY MESS THINGS UP. THE BEST BET IS TO USE THE PROPER INK CARTRIDGE WITH YOUR PRINTER. THATS THE TYPE OF INK IT WAS DESIGNED FOR.
ARCLIGHT1217
Jun 05, 2008 | HP PSC 1110 All-In-One Thermal Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
