Question about Kenmore Washing Machines
My machine says F-21 - Kenmore Washing Machines
  • 15,935 Answers
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 08, 2010
Error code F-21
F21 relates to a motor or control board fault.
Sep 27, 2016 | Kenmore Elite 45986 Front Load Washer
Hi Washing machine BOSCH Maxx 7. Displays error F 21. What's wrong - and what can we do ? sincerely,Jette
The F21 error code indicates that you have a problem with the washing machine's motor.
Have it checked out by competent electrician.
Feb 22, 2015 | Bosch Washing Machines
What does the error code F 21 mean
F 21 indicates a drain problem.... mostly due to a clog. Google
washing machine F 21 code. There are many links including
repair videos. Good luck to you.
Regards,
Dennis
Oct 06, 2014 | Washing Machines
F 21 problem
What is the complete model number of your unit?
Dec 03, 2012 | Washing Machines
Drive belt size mtd 21 " 6.75hp mower
If you post the model number of the machine, I can probably find the belt dimensions..
Tim
Oct 16, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Can't select stitches 11-21
To select stitches 11-21 you position the stitch length dial on the "SS" setting , and the pattern selecting dial on the desired stitch number.
Mar 08, 2008 | Brother XL-5700 Mechanical Sewing Machine
HP DL585 G2 Machine Check Exception
This problem has been seen for awhile on all flavors of hardware: CPU X: Machine Check Exception: 0000000000000004. In can come from a kernel recompile after new drivers have or havenot been upgraded. Upgrading OS on older hardware can cause this exception throw. At any rate your system is now rendered unstable and probably should be returned to the last good known configuration - so goes the old addage - "upgrade or die!"
Feb 20, 2008 | Computers & Internet
Washing Machines Logo
14 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
