With Ethernet connection, network and sharing center reports 'unidentified'. Only on ethernet, wifi is fine. How can I fix this?
  • 57 Answers
Try BOTH or either steps
1.
- Press Windows key and "r" key at the same time to open RUN box
- type ncpa.cpl
- right click on Local Area connection, click Diagnose
- follow the prompts
2.
- type ncpa.cpl
- right click on Local Area connection, then properties
- on the list with check boxes, uncheck IPv4 & IPv6
click OK, then click YES
- right click again on Local Area conenction, properties
- put the check back on IPv4 & IPv6, it will check back all the rest
- click OK
- wait for a few secs.. it will show "identifying", then you'll be prompted to select is as a HOME or Public network, select HOME
Posted on Sep 08, 2010
  • digecorp
    digecorp Sep 08, 2010
    Unfortunately, this did not help. Step 1 made no difference, and I was never prompted for home/public on 2. It just went straight back to unidentified.
  • marvie gepte
    marvie gepte Sep 10, 2010
    if this is Vista, it is or was a common issue..
    - reinstall driver for ethernet
    - run windows update
    - then try resetting your router, though you would need to reconfigure it (like the wireless settings)..
How do i connect two pc together
If they are alrady on te same router / WiFi, make a drive or folder 'shared' and then on the other use 'Map network drive'
If not, then just use any old Ethernet cable to link them (both PC's should be happy enough to set a default IP addresses and 'see' each other) - modern PC's don't need special 'switch over' cables (a 5m Ethernet cable from the £1 shop will work fine)
On the PC you want to 'expose' data, you 'Share' the folder (right click for the folder 'properties', look for 'security/sharing' etc).
On the other you 'map network drive' (if asked for a user name/log-in, use the account on the OTHER PC ..)
Apr 04, 2014 | Dell Dimension 8300 PC Desktop
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
Tip
Connect your 3g mobile broadband to an xbox360!
Have you ever wonder if you could connect your 3G mobile broadband modem to your xbox360? Well i have done it and it works fine.
What you will need to do is enable network sharing in your laptop/pc
I am using a vista laptop and orange mobile boradband, and this is how i done it!
First of all connect your 3G modem to your laptop/pc as you normaly would. Now get an ethernet cable and plug this into your laptops ethernet port and then into the back of your xbox's ethernet port.
Click on start> connect to> Then you will see "open network and sharing center" Click that. In the next window you will find all networks connected to your laptop/pc. You will see one below your normal internet connection called unidentified network. Click "view staus" Now in this window click and go to properties. now in this window click on the network tab at the top of the window. While now in this window click on enable network sharing via this device. Now go to your xbox360 and try to connect to Xbox live if at the first atempt it did not work test your connection via xbox as it will ask you to do this anyways. You should now be eable to connect to xbox live using your 3G modem.
Hope this helps!
on Dec 28, 2009 | Computers & Internet
I can connect to internet from cable modem but not thru Router Belkin Surf N300. I can get wifi thru router
I'm confused? If you connect a Ethernet cable direct fron the Belkin to the computer, will it connect? What does it say in Network and Sharing Center on computer, What is the computer and the OS? I think you have a Computer issue. Post Computer Make,Model, and the OS.
Dec 26, 2012 | Belkin Computers & Internet
Wont allow me to share my internet , its hooked up to wifi i want to run a cord to my xbox to give it internet possible?
Yes this is possible. You will need to bridge connections between your WIFI adaptor and Ethernet ports.
Navigate to Network connections, select both your WIFI adaptor and Ethernet adaptor. Now right click and select "bridge connections"
Take care!
damnor01
Sep 11, 2012 | eMachines E620-5885 Notebook
I want to network two pc with windows xp using crossover cable,, how do i do it step by step pls.
Connect two computers using a crossover cable
If you need to connect two computers but you don't have access to a network and can't set up an ad hoc network, you can use an Ethernet crossover cable to create a direct cable connection.
Generally speaking, a crossover cable is constructed by reversing ("crossing over") the order of the wires inside so that it can connect two computers directly. A crossover cable looks almost exactly like a regular Ethernet cable (a "straight-through" cable), so make sure you have a crossover cable before following these steps.
Before buying a crossover cable, check your network adapter. Some newer network adapters automatically "cross over" when they detect that they are connected directly to another network adapter using a regular Ethernet cable.
To connect two computers with a crossover cable
This works best if both computers are running this version of Windows.
Plug each end of the crossover cable into a network port on the back of each computer.
On one of the computers that is running this version of Windows, do the following:
Open Network and Sharing Center by clicking the Start button , clicking Control Panel, clicking Network and Internet, and then clicking Network and Sharing Center.
In the network map at the top of Network and Sharing Center, double-click the Unidentified network? icon. (If you have more than one network, this icon will be labeled Multiple networks.)
If network discovery and file sharing are turned off, in Network, click the Information bar containing the following message: "Network discovery and file sharing are turned off. Network computers and devices are not visible. Click to change...," and then click Turn on network discovery and file sharing. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
In the Network discovery and file sharing dialog box, select one of the following options:
No, make the network that I am connected to a private network
Yes, turn on network discovery and file sharing for all public networks
The first option is usually the best choice because it only affects the network that you are connected to.
Notes
Networks created with crossover cables are automatically set up as "Public place" networks, which means that network discovery, file sharing, and printer sharing are off by default.
For Gigabit Ethernet or token ring networks, you will need a slightly different kind of crossover cable. For more information, contact a cable manufacturer.
Icons for both computers should now be visible in the Network window. Double-click each computer icon to share printers and other resources.
Note
If one of the computers is running Windows XP, it can take some time for that computer to appear in the Network window. You might need to move both computers to the same workgroup. You can do that by changing the workgroup on either computer. To change a workgroup, see Join or create a workgroup. You might also need to turn on file and printer sharing on the computer running Windows XP.
Hope this help!
Sep 06, 2011 | Pine Technology Motherboard Xfx Nforce...
Does the acer aspire z5700 desktop have a built in wifi router or do i need to purchase and set up a router to enable home sharing network?
While it doesn't have a built-in router, it DOES have a wireless adapter built in. So if you were to purchase your own router (or rent one from your ISP), the computer would work fine with it.
More details on your computer here:
http://reviews.cnet.com/desktops/acer-aspire-z5700-u2102/4507-3118_7-34132723.html?tag=doormat;rnav
May 02, 2011 | Computers & Internet
Is it possible to connect my ASUS X58C laptop to a Win98SE pc
Connect the two computers using the Ethernet crossover cable.
On the computer running Windows Vista, from the Start menu, click Control Panel. Then, double-click Network and Sharing Center. Note: If this doesn't match what you see, switch yorur control panel to classic view..
At the top of the main portion of the Network and Sharing Center window, double-click the Unidentified Network icon.
If network discovery and file sharing are disabled, the following message will appear:
"Network discovery and file sharing are turned off. Network computers and devices are not visible. Click to change..."
Click the message to enable network discovery and file sharing; you may be prompted for an administrator username and/or password.
In the dialog box that opens, select No, make the network that I am connected to a private network. This allows you to initiate file sharing on the two computers without affecting the settings for any other networks.
Icons for both computers should now be visible in the Network window. Double-click a computer icon to share printers and other resources.
Mar 28, 2010 | Computers & Internet
Brother 2700CN Color Laserwriter--Loss of Ethernet Connection
No lights on network card mean that you will need to replace network port/card on printer if cable and connection is sound
Nov 28, 2007 | Office Equipment & Supplies
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
