Question about Refrigerators
Icemaker not geting water Water side is working
  • DavidLKelly2 Sep 09, 2010
    Kenmore side-by-side model5752
  • DavidLKelly2 Sep 10, 2010
    Kenmore side-by-side Model 57542
    Top Expert:
  • Refrigerators Master
  • 80,263 Answers
Make and the model number of the fridge or icemaker
Posted on Sep 08, 2010
Amana side by side icemaker stopped working
The icemaker is not working because the water pressure is too low. An icemaker is controlled by a timer so it has no idea how much water is in it. The water valve gets energized for about 7 seconds letting water in the icemaker, but if there is no water pressure then the icemaker will not fill.
Sep 12, 2009 | Refrigerators
Icemaker stopped making ice
see if it geting water if not it is probley the water valve if it is getting water then see if it freezeing ice cubes if so and still not getting ice the it could be the heater on the ice maker and it needs to be replaced.......
Aug 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Icemaker doesn't work
chack water valve and make sure it is getting water if so and there is ice in ice maker then your heater is bad and not releaseing ice
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Kenmore side by side ice maker is not geting water. water is on and if I temp change electrical connectors on the silinoid and work the water arm on the door I can get water to the ice tray. What is wrong...
You have a bad water valve . Both solenoids work independently of each other . 1 for the water dispensor and one for the icemaker .The icemaker when 5 degrees and harvests , tells the valve to give it water (electronically) .
Jul 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Icemaker not working,water pours from dispenser side
it could be water valve or ice maker that has gone bad.check all connectins to icemaker and tubing to icemaker and water valve.
Mar 20, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Icemaker on Hotpoint Model HSS25GFPAWW Refrigerator not working
try turning the temperature for the freezer down a little bit. it has to at least be around 17 degrees before the older ice makers start to work.
Jan 20, 2009 | Hotpoint HSS25GFP Side by Side...
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jun 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Samsung rs2555sl icemaker
replaced circuit board. Problem solved
Oct 17, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
