Question about LG 42LC2D 42 in. LCD HDTV
My model number is 42LC7D-UB. The main board went out so I bought a new one. The old part number was LA73E EAX35607004(0). I found a cheaper one on Ebay with the model number LA73E EAX35607006(2). I was told this one would still work so I ordered it. After installing it my TV still doesn't work. It's made an improvement from before though. Before it would turn on for about 3 seconds then just turn off by itself. Now it stays powered on but there is no picture or sound. I heard sometimes you have to update the software so I tried that but the USB input in the back is not getting any power so nothing happens. I'm afraid the part number may need to be exact. Is that correct?
  • 13 more comments
  • deanlemmon Sep 08, 2010
    I can't find anywhere to type in a model number. Are you saying I should search to see if it tells me if they're compatible? I tried contacting LG and the guy said he thought it should work but when I asked him for any help he just told me I need to take it to an authorized service center.
    Also I just noticed that I posted this under 42LC2D but I actually have a 42LC7D. Hope that doesn't make too big of a difference
  • deanlemmon Sep 09, 2010
    Do I need to get the exact part number or is there a different problem?
    So are you suggesting that I need to order this part or try to fix it?
    I replaced the power board first but nothing changed at all so then I tried the main board. This is a slight improvement; before I replaced the main board the TV would turn on for about 3 seconds then just automatically shut itself off.
    So should I try to get the exact part number or is there anything else you suggest I try?
    I'm not too familiar with this sort of thing, can you give me some sort of idea which part that is?
    Is the low voltage power supply and the power supply board the same thing?
    Ok I understand that. What I don't understand is which part of the TV is the "low voltage power supply." If it's the same thing as the power supply board then I already replaced that and I got the exact part number. It's the main pc/tuner board that the part number was slightly off.
    Oh ok thanks. I'll check it out and get back to you
    Well I don't really have any idea what I'm looking for. I unscrewed it and took it out but there doesn't appear to be any way to take it apart further. I'm guessing I'm going to need some way to test the voltage or something like that. Any suggestions?
    Ok thank you!
  • deanlemmon Oct 25, 2010
    Yes I did. The only thing wrong was the cable that goes from the main board to the power supply board was bad. I changed that and it works great.
    Yes I did. The cable going from the main board to the power supply board was bad. I changed that and now it works great.
  • 4,889 Answers
Yes absolutely! The part number must be exactly the same. Different part number indicates a different version of the same board.
Posted on Sep 09, 2010
  • eagle338
    eagle338 Sep 09, 2010
    You are welcome :)
  • 11,896 Answers
Have you checked the power inverter or power board?
  • 5 more comments
  • Nate Stansfield
    Nate Stansfield Sep 09, 2010
    Sounds like a main board Y sus board or a power board or power inverter problem.
  • Nate Stansfield
    It sounds like the low voltage
    power supply has crashed. Since the set is essentially dead, this would be the first place to look.
  • Nate Stansfield
    You will need the exact same part number for that to work correctly. Partstore.com or shop jimmy should have it.
  • Nate Stansfield
    Each and every component has it's own part number. Either it is imprinted and on the part itself or on the circuit board directly next to that component.
  • Nate Stansfield
    It is the little box that is directly connected to the power cord. Some may have resistors that control the power flow.
  • Nate Stansfield
    Sounds good.
  • Nate Stansfield
    Not a problem. Oh, and on the back of the tv there should be a lable. Some are imprinted. Itshould say the DC Voltage Output. That voltage reading should match your volt tester if you decide to test it. Thanks.
  • LG Master
  • 5,138 Answers
Google to this website and type in your Model number
Encompass Parts Distrbution they should list Parts and PN and Prices they have,sometimes they have service manuals
1-800-638-3328 see if they are listing Main board and sub board
and are the numbers the same as what you order?
UED is another company you can try 1-800-648-6657
Posted on Sep 08, 2010
  • ladywinn
    ladywinn Sep 09, 2010
    I went to Encompass Parts and typed in your model number 42LC7D they are listing Free Service Manual that you can print out online and they List Main PC board PN# EBR35639601 Price $209.68
  • ladywinn
    ladywinn Oct 25, 2010
    Hello, I was just wondering did you ever get your TV Fixed?
LG 42LC7D-UB after few minutes the sound goes off and channel change by itself
When heats up, the supply voltage from the main power supply board goes less. Check all the soldering to this board for any loose solder terminals. Resolder all the suspected solder terminals by applying a little more solder. If it do not help you, replace the board as card basis.
Jan 09, 2013 | LG 42LC7D-UB Television
Will parts from a 42lc7d tv fit a 42lg20 tv..?
if your are referring to boards the pwr supply and tcon and inveter board will be diff because of size of lcd ,main board might be same have to ck part#'s on board
Oct 09, 2011 | LG 42LC7D-UB Television
LG 42LC7D.......Have sound but no picture at all. Light goes from red to green and sounds as though the screen tries to turn on but no picture.
It sounds like you have a logic board problem. It is easy to fix open up your tv on the back and the logic board should be covered with a small metal plate unscrew the it, it uses small screws get the number of that board an order it through guytvparts.com is the cheapest
Apr 03, 2011 | LG 42LC7D-UB Television
I have the exact same issue as the unsolved problem below on this page: I have a LG 42LC7D that is about 3 years old. A Problem with the LG 42LC7D-UB Television I have a LG 42LC7D that is about 3 years...
The power on problem is a cap in the power on circuit. The loss of signal for an areal is delayed. Nothing you can for DIY.It needs repair shop visit.
Feb 12, 2011 | LG 42LC7D-UB Television
How do I replace the bulb on an LG 42LC7D
first you need to remove old bulb there is model no menstion on the top side.please check and replace with same no.
Oct 16, 2010 | LG 42LC7D-UB Television
Only av input is working LG 42LC7D TV
I may put money that some one did stole your internal cable from the power supply to the main board !
Don't be surprised they did it to me at LG company .
Jul 26, 2010 | LG 42LC7D-UB Television
Replace main board on LG 42LC7D-UB
Try this place, http://www.shopjimmy.com/catalogsearch/result/index/?q=42lc7d-ub&p=2
I the best place I know of to get parts at a good price.
There are a couple of boards that have different part numbers. You'll have to match the part# with yours. It maybe out of stock, but click on it. Then click on "find other products with this part number". Then all the main boards show up with that part number. A couple of them should be should be in stock.
Apr 16, 2009 | LG RU-30LZ50C 30 in. HDTV-Ready LCD...
Cuts off
Most likely the power supply board.
Lie the tv down on a bed and unscrew the back. Its only about 9 screws around the edge and look at the power board, on the left, see if theres any burn marks.
I have a brand new board I bought the other day for the same issue but before I replaced it, stupidly, I checked with LG and turns out mine is still under warranty so I'm stuck with a new board.
Let me know if you want it. I'll match any price you can find online.
Mar 20, 2009 | LG 42LC7D-UB Television
not sure what you're referring to as a "main board", but heres the LCD Control Board for the TV
http://cgi.ebay.com/LG-42LC7D-UB-LCD-CONTROL-BOARD-6870C-0119A_W0QQitemZ150277759127QQcmdZViewItem
Mar 13, 2009 | LG 42LC7D-UB Television
LG 42LC2D 42 in. LCD HDTV Logo
156 people viewed this question
Computer Repairing
Computer Repairing
