Question about GE (PSS26MSRSS) Side by Side Refrigerator
Wall covered with snow - GE (PSS26MSRSS) Side by Side Refrigerator
  • GE Master
  • 1,606 Answers
You have a defrost problem , due to the " snow " . Most likely , the problem is a bad defrost heater , pt # WR51X10055 , but I would still suggest going thru the motions to make sure . The heater runs about $45.00 .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature
Posted on Sep 09, 2010
ISnowblower is throwing snow, but also putting snow up on the machine ananda on me. When I finished one row the machine is covered with snow!
There are many factors that can cause this to occur. ONE IS THE WIND, LIGHT SNOW WILL BLOW BACK OR SNEAK THROUGH HE CRACKS OF THE EXIT. if THE SNOW ON THE OTHER HAND IS WET THEN THE EXIT CHUTE WILL ALLOW THE SNOW TO DROP ON THE MACHINE. ONE WAY TO FIX THIS REQUIRES THE ADDITION OF RUBBER STRAPS, YOU WILL NEED TO DRILL HOLES IN THE IMPELLERS and attach the rubber, (this can be cut from an old tire or a floor mat or other rubber that is around 1/4" thick or more. Make the parts the width of the blades and around 2-3 " from tip to base. This will stop the snow from collecting on the walls of the blower and throw the snow farther from the blower.
sorry about the uppercase, did not know I had hit the caps lock, not a touch type person.
Neal
Feb 26, 2015 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Can utilitech timer, 0154182, be located at ground level and must it be in an upright position?
Don't put timer at ground level where it can get wet of covered with snow.
Otherwise will work in any position as long as photoeye turned away from lights.
http://waterheatertimer.org/Woods-timers-and-manuals.html#photo-eye
Gene
h
Nov 27, 2013 | Intermatic Inc. ST01C Digital In-Wall...
Refigerator and freezer all of the sudden don't seem to keep cold enough
The back wall of your freezer covered with snow? If it is I would suggest you replace the heater and a thermistor - Heater: WR51X10101 Thermistor: WR55X10025. If no snow then it is probably the main pcb: WR55X10656
Mar 24, 2013 | GE GSH22JFT Side by Side Refrigerator
Windshield wipers stopped working with heavy snow cover
The windshield wiper circuit has an circuit breaker in it, under heavy load this breaker trips to protect the wiper motor, when the motor cools, the breaker resets automatically restoring proper wiper action.
Feb 24, 2012 | 2008 Kia Optima
Back wall of frezzer covered with snow, removed cover, coils frozen over with ice. have to de-frost freezer every 3-4 wks. Model#: GSL22JFTA BS
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE GSS25JFM Side by Side Refrigerator
"snow" in the freezer
YOU HAVE A DEFROST PROBLEM IF THE SNOW IS ON THE BACK WALL. ISSUES WOULSD BE --TIMER, DEFROST THERMOSTAT. OR DEFROST HEATER. IF THE SNOW IS SOME WHERE ELSE YOU HAVE A PROBLEM WITH A DOOR SEAL.
Nov 03, 2009 | Refrigerators
I have a kenmore refridgerator side by side. The freezer is beginning to have snow buildup (it is a self defrost) the refridgerator side is not cold
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Could you find a model number like 321.256489 for example then I can find the parts to look for. Sea Breeze
Aug 20, 2009 | Kenmore Refrigerators
Freezer suddenly is creating mounds of freezer "fluff"
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Sea Breeze
Aug 20, 2009 | KitchenAid KSRS25ILSS Side by Side...
Samsung side by side
Check for snow on the back wall of the freezer compartment, Air to cool the refrigerator is supplied from the freezer section. If the coil is frozen over the air circulation becomes retarded and the refrigerator suffers. Snow on the back wall indicates a defrost problem.
May 15, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
44 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
