Question about GE Spacemaker Washer and Dryer Electric Laundry Center
WASHER NOT SPINNING - GE Spacemaker Washer and Dryer Electric Laundry Center
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 08, 2010
Kenmore Series 70 washer keeps spinning when you open the lid, is this the correct operation? Also, the washer is always moving around when in the spinning cycle, is something worn out or what?
If the machine keeps spinning if the lid is open then the lid switch has failed. This is the safety device that prevents injury from people reaching in and getting hurt when the machine is in operation.
Jun 04, 2012 | Kenmore Washing Machines
Makes a lot of noise when spinning, could be
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 31, 2010 | Candy CBL166 Front Load Washer
Very noisy when spinning - suspect bearing problem. Would appreciate advice on bearing replacement. Model no. WF 240
heatman101
May 30, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Noise when is spinning
Could be a bearing, or perhaps vibration Check concrete weight are tight , springs okay.Machine is level..please leave feedback.
Apr 07, 2010 | Kenmore 45981 Washer
Whirlpool LSR8444 washer, timer works but no spin or aggitation
Your problem is a broken drive coupling between the motor and transmission. Replace the drive coupling.
Jul 27, 2009 | Washing Machines
I have a GE model# WLSR2000G2WW washer and it's not spinning out at the end of the cycle it started not spinning out when set on small load only now it's not spinning out on large load either. But if I...
I found the hose hooked to the pressure was clogged down at the tub end. So it couldn't send a signal to the switch telling it the water had pumped out and it was time to spin out, the plugged hose was holding pressure telling the washer (falsely) that the tub had water in it so it won't spin if it thinks water is still in the tub. By pulling the hose off the switch end and blowing thru it to clear the lint and soap slime that was plugging the other end it works perfect now.
Jun 13, 2009 | GE Washing Machines
Can hear washer spinning but tub isn't spinning
Check the belt and replace it, Ithas either borken or has become loose. You can remove the back cover and get to the belt. Remove it or if it is broken just take it into a local hardware store and buy a new belt. Looking at about 10 dollars max to buy
Feb 07, 2009 | Amana ALW480DA Top Load Washer
HELP!!!!!!
Before spinning, washer draining water aut & than start spinning,,,,if motor runing without drainig water, chek the belt, if belt is OK,and runing pupm, chek the pump,,,,disconnect hoses and clean pump... if washer do not draining & spinning, replase lid switch..... If you need instruction how to replace lid switch, i will post you instruktion....
Sep 01, 2007 | Maytag Performa PAV2200
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
109 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
