Question about Maytag Ovens
Oven will not heat up only goes to 160 degrees and no more
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Sep 08, 2010
Oven heats up but wont get above 160 degrees
I assume you mean it trips the circuit breaker. If the circuit breaker is good, that means the heating coil is bad, and pulling too much electrical current. Sometimes circuit breakers fail, and trip at say 5 amps when rated at 15 amps. Have you electrician switch that breaker with another one and see if there is a difference. If not, it is a bad heating coil.
Oct 19, 2012 | Bosch HBN5046AUC Electric Single Oven
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
Oven won't heat above 160 degrees
heatman101
Jan 18, 2011 | Jenn-Air JJW8330D Electric Single Oven
My oven is taking ages to heat up! goes up about 1 degree every 20 mins can u help
heatman101
Jan 14, 2011 | Ovens
Oven only goes to 175 degrees
heatman101
Dec 30, 2010 | Frigidaire GLEB27S7A Electric Single Oven
It takes 28 minutes for the oven to reach temperature of 375 degrees. The ready buzzer goes off in about 15 minutes. The temperature is 300 degrees. Is there any adjustments to be made.
what is your oven if is gas or electric, if is gas easy to preheat by using lower heating element, if electric? that your unit have convection? or not? coz some probelm of the oven is, 1 if the oven is no convection or your oven is single heating in upper element,if your oven have a timer and cut off in 15minute? dont use timer,use a manual timer by it your self,if you want to reach the degrees that you want check your oven if der a lower and upper heating element with convection function,that the one is the most easy way to reach the degree that you want to reach.
Dec 17, 2010 | Ovens
Oven not heating up to temperature
no it does not did you change correct limiter double ovens have up to 3 and they all operate at different values.
May 14, 2010 | Neff U1721 Double circotherm Electric Oven
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Jun 25, 2008 | GE Profile JT912 Electric Single Oven
Ovens Logo
90 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Mack Baxter
ashburton
Are you a Maytag Oven Expert? Answer questions, earn points and help others
