Question about Vintage Keeper 220 Plus Wine Cellar
I need to purchase a replacement cooling unit for a Vintage Keeper 220. I need to know who can supply me with the unit.
  • 288 Answers
SOURCE: My kool space wine cellar is not holding temperature
has the cellar ever worked right in your home? These small refrigeration units basically move heat from a conditioned space to another space that is not objectionable such as your home where your central air system then moves the btu's. This being said, the cellar has a ventilation system that must pull in room air and push out the box air. these vents must be clean and clear of obstrucions to ensure proper performance by the equipment
Posted on Nov 27, 2009
  • 4793 Answers
SOURCE: We are looking at purchasing a used vintage
if the unit was left unused for 4 years chances are its way passed its sell by date,but if you switch it on and it works/was cheap to buy,then what the hell......
Posted on Jul 31, 2010
  • 2187 Answers
SOURCE: I have a Vintage Keeper
Have it checked on how much refrigerant yo have left before deciding on the purchase of a new unit or recharging it. The cost may be far and from there you can decide on which is more practical. It may also just be a faulty thermostat.
Posted on Apr 06, 2011
reyjoshua07
  • 1157 Answers
SOURCE: I have a vintage keeper
Hi drcunning1,
Just a follow up question about your concern, does your refrigerator is not cooling properly and not getting cold at all?
Thank you for using FixYa.
Posted on May 05, 2011
  • 1456 Answers
Hello
The problem lies in the thermoelectric cooling module.This part should be replaced. Finding this part on ebay can be done by searching for "thermoelectric cooler". If the exact part cannot be found, then any similar part that's 40mm x 40mm in size, and 51 to 69 watts should do fine.
To replace the part you must remove the back panel from your Wine cellar. You will see 2 big fans attached to two large heat sinks. (If a heat sink on the back does not feel warm to the touch, the the other side is obviously not cooling, which means that zone is broken.) Remove the screws from the fan and the heat sink of the zone that is not cooling, and while holding the heat sink, pull the whole cooling assembly for that zone out. Dont be alarmed if you feel some insulating foam separating as you pull it out, its a tight fit so that is to be expected.
Once you have the cooling assembly out of the fridge, take it apart and you will see the square ceramic cooling module inside. (REMEMBER which way the module was oriented before you remove it, so you know how to put the new one in.) Clip the red and black wires near the module and remove it from the assembly. DON'T wipe away any of the white thermal grease left behind on the heat sinks. If you have any extra thermal grease handy (available at Best Buy, or online at sites like newegg), apply an extra pea-sized dab to both sides of the new module. Put the assembly back together and splice the wires from the new module to the loose wires left behind going into the back of the Wine cellar. Mount everything back in place as before, close up the back, and youre done!
Posted on Jul 12, 2011
Where can I find a compressor (cooling motor) for vintage keeper koolspace
Best place to look on the internet. Get the make and model number from the compressor tag and check ebay, which has a multitude of vintage parts.
Oct 02, 2017 | Vintage Keeper Refrigerators
Cooling unit is running, but interior is not cool.
How long have you had this unit and did it quit suddenly or did it fail intermittently. Do you mean running where you can hear the fan and the light comes on when you open the wine cellar door? If so, I would suspect the starting relay failure on your cooler which should be very easy to replace. There should be a wiring diragram on the back of your unit somewhere and could be labeled (RT). Your compressor would be the last thing I would suspect.
Dec 05, 2010 | Vintage Keeper 500 Plus Wine Cellar
We are looking at purchasing a used vintage keeper. The owner turned it on and it was cooling down to 55 and then it shut off. There are no instruction booklets so we had to guess as to how to restart it....
Jul 31, 2010 | Vintage Keeper 250 Plus Wine Cellar
I have a Koolspace AA6 Tuscany free standing unit. Sn 05314-11. Power went out cooling unit will not restart. I get the thermostat to read and fan to turn for a while then goes into high temp alarm mode.
It seems like this cooling unit (AA6, also Grand Cru 800) just doesn't last as per numerous postings that I found when I was trying to find a replacement unit. Best advise seems to be get a higher output unit that will fit application.
May 14, 2010 | Vintage Keeper Koolspace Wine Cellar
Nov 26, 2009 | Vintage Keeper Koolspace Wine Cellar
My Vintagekeeper Tuscany 220 wine fridge is making lots of unnecessary noise.
Hello, this is a common problem when parts start to wear in the motor. They rattle and clang allover the place, depending on age of fridge you can get the motor replaced and regassed. Or depending on age it may be time to replace the fridge. I hope this is of some use.
Nov 04, 2009 | Vintage Keeper Koolspace chillR Cooling...
Koolspace wine cooler
I have the Vintage Keeper Odyssey. I had the same thing the other day. Unit is 7 years old. Vintage Keeper web-site suggested to unscrew the control box and remove. (The box with the "Set" and Up and Down arrows. Unplug the wiring and sensor on the back and then plug back in. Plug in the unit and text. It took my "AL" away.
Unit doesn't cool very well. A coolant leak may be my problem. I was looking for solutions other than buying a new refrigeration unit.
Jun 07, 2008 | Vintage Keeper Koolspace chillR Cooling...
VP500 Cooling unit issues
http://www.rosehillwinecellars.com/3rsV2/54_RHWC_plans/tuscany_plus_250_500.pdf
above is a link to the Vintage Keeper manual PDF format manual and problems and trouble shooting guide
Oct 23, 2007 | Vintage Keeper VP500 Wine Cooler
Vintage Keeper 220 Plus Wine Cellar Logo
783 people viewed this question
Top Vintage Keeper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vintage Keeper Refrigerator Expert? Answer questions, earn points and help others
