Question about Canon DC220 DVD Camcorder
Is there a possibility of finalizing a DVD after recording or is there a soft enabling finalizing ? or a recording soft including finalizing DVD ? Thanks.
  • 10,594 Answers
What kind of dvd you are using in camcorder, is it once record or rewritable disc?
You can finalize dvd disc after recording in camcorder to view that disc in other dvd players. Use ac power charger to finalize disc as some camcorders do not give finalize option if battery is attached.
Let me know if you have additional question.
Thanks.
Posted on Sep 08, 2010
A standard commercial movie on DVD first showed 'no disc' and then on second loading 'disc not recognised' after it had spun the disc up. This has happened to several discs. All discs work in any other...
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked. Hence the rejection but the best is for cleaning manually the laser head eye with a cotton bud very softly and without any pressing of the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to work correctly and the possibility of the optical head being the suspected fault is closer.
Finally try to see if the set records on a DVD with a given signal source. If not the fault is confirmed.
But if any of the above seems otherwise we must recheck with possibilities of the processor board
Sep 29, 2010 | LG RH177 DVD Recorder/HDD Recorder
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
"movie recording disabled". How do I enable it?
If you are using DVD-RW, format it because it got some error in data writing.
and if its DVD-R, use another disc and try to finalize existing DVD-R / DVD-RW to get data.
Thanks.
Sep 13, 2009 | Sony DCR-DVD610 DVD Camcorder
Lost recordings
It is required to finalize the recording in the Camcorder in order to play the recording in any device like DVD player or in Computer.
First finalize the recording in the Camcorder and then try playing the DVD in any DVD player.
After finalizing the DVD, a DVD player will be able to play the disk.
Refer the User Guide page # 44 of 139 for the instruction to finalize the recording in the Camcorder.
Check the link give below to download the User Guide (Operating instruction):
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DCRDVD108
or
http://www.docs.sony.com/release/DCRDVD108.pdf
Good Luck!!!!!!!!!!!!!!!!!!!!!
Sep 13, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Movie recording disabled
it's either you finalized a disk or your memory stick is full. if possible delete recordings and or photos in your memory stick to enable recording, or put a blank disc..once a disc is finalized it cannot be used to record on the cam but could still be viewed on the cam by selecting the media format,
Mar 09, 2009 | Sony DCR-DVD610 DVD Camcorder
My Dad recorded all his VHS tapes and made DVD's on the Panasonic DVD Recorder DMR-ES30V and now they wont play on any DVD player except for the DMR-ES30V. I believe he recoreded them with a lock so they...
Hi and welcome to FixYa,
My compliments to the foresight of your father. Your described concern is not caused by a "lock". It is indicative that the recording session was not 100% completed. Rather than 'crack', what is required is the final step in the recording. All the DVDs must be "finalized" in the same machine that recorded the movies, the Panasonic DVD Recorder DMR-ES30V. The finalize option would be in the MENU/Settings and must be enabled. Finalization per disc would take some time.
Good luck and thank you for using FixYa.
Feb 18, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Dvd recorder can't read disc it previously read
Take the Disc out and put it aside. You must clean the Laser Eye, and clean dust and other matter from inside your recorder. Clean Eye with rubbibg alcohol and q-tip. A regular CD/DVD cleaner disc will not work. After cleaning, reinsert your Disc and Finalize it.
Jan 02, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
Cyberhome 1500 does not finalize my recorded dvds
The 1500 needs to have a cooling fan installed and possibly the power supply repaired if it has been damaged from overheating. While you are doing that you can play and even make a finalized copy of your disc on a PC with instructins on my website here: www.drx9000repair.netfirms.com/
Jan 22, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Canon DC220 DVD Camcorder Logo
82 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
