Question about Troy Garden
I have a troy built TB590BC 4 CYCLE TRIMMER. I had a week spark so replaced spark plug and still didn't start. Now I have no spark at all. I checked kill switch and that's seems ok. I figure it might be coil. Does anyone have directions on how to change coil? I've had problems with it since day one starting. Would have to pull cord more than normal to get it started. Thanks for your help.
  • 10865 Answers
SOURCE: need to clean carburetor of troy built trimmer.
Go to any auto parts store and buy an aerosol can of carbeurator cleaner. Remove the air cleaner filter and give the air intake a couple of squirts. Pull the cord and turn the engine over a couple of times to draw the cleaner into the carb. Then let it sit for an hour and dissolve what ever is gumming up your carb.
Posted on Jun 11, 2009
panilling9
  • 284 Answers
SOURCE: Troy Bilt 4-cycle trimmer won't stop!
Take the switch so it is accessable
take the two wires and touch them together or hook them together bypassing the switch
does it shut off or it should not have spark?
if so you have a bad grounding problem if it does not shut off,if it does your switch is still bad
2 wires one tied to ign. module and other to a metal ground all the switch does is dead short. the igniton to shut down the spark and in turn kills the engine.
Be sure your grounding is tight and clean and all wires are intact and making good contact to their designated areas (no broken wires)
hope this helps some for you
Posted on Jun 13, 2009
SOURCE: how to change trimmer ine in tb525cs
You need to unscrew the black bumper button. I believe it is counter-clockwise. Mine was very tight and took a pair of channel lock pliers to loosen.
Posted on Jul 19, 2010
SOURCE: Cannot disassemble Troy-bilt trimmer head
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
Posted on May 04, 2011
  • 5603 Answers
SOURCE: I have a troy built 4 cycle trimmer. I pull on
If you can sense that the shaft is turning, then the valves are sticking open.
Posted on Jul 23, 2011
I have a troy built trimmer model # tb65ss
check the kill switch position and wiring, if good, check magneto wire
Jun 30, 2014 | Troy Bilt Tb70ss Gas Trimmer
Trimmer keeps cutting off
change spark plug or like mine it my only use non-e85 gas
Mar 30, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I put trimmer away after using, and the next time I took it out it would not start, I changed the spark plug and the gas and still it wont start., the kill switch on the handle check out ok with a meter?
I want u to make sure a critter hasn't built a nest in the exaust hole.
Use something to get in there and scratch around with, and blow out with some air. If its not exausting it won't start. Also make sure the fuel lines are not cracked or loose and letting air bubbles in, she won't start then either. Hope I helped.
ballping
Jul 26, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
New TB70SS used one hour run great started easy. Following week started on run fine for 10 minutes it became sluggish and died. Has not started since. Yes new gas correct mix. check spark arrester for...
If the trimmer is new and giving you these problems, then take it back to the retailer and either trade for another one, or pay a little extra for a 4 cycle. The 4 cycle is a little hard to start too, but will run out perfectly and no more mixing of oil.
The higher price tag is well worth the time, effort and aggrivation experienced versus a 2 cycle engine.
I hope this helps.
Jul 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy built 6 75 hp lawnmower will not stay on I start it but it will quickly turnoff''
on the bottom of the carb. is a bolt that holds the float bowl on. remove that bolt and float bowl. use a small needle and stick it in the holes on the bolt to clean them out. look at the gas in the float bowl to make sure there is no water in the fuel tank .
Jul 02, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Spark plug
You can obtain a spark plug at any Troy Built dealer. Lowes is ours. Your owners manual should tell you what type of oil to use. Again you can obtain it at Lowes.
Sep 15, 2008 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
75 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
