Question about Kenmore Washing Machines
I have a Sears & Roebuck, Kenmore top loading washing machine Model 81864120 that will not Agiate or Spin. It does fill and drain with no problem and the timer for the wash cycles work fine.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Sep 08, 2010
I have an Kenmore 70 series washer. It would not Spin or Agiate so after looking to the internent for help I found it may be the washer coupling. I replaced this part, but now it won't spin, agitate or...
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore Service manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Are you sure that you plugged the Lid Switch back in when you put the cabinet back on??
If the switch is connected, I'd also pull the cabinet again and make sure that the Motor coupler is installed correctly. If it isn't, it could be broken again and the washer wouldn't agitate or spin.
Are you sure you connected the motor?
Jan 19, 2011 | Kenmore Washing Machines
Top load washer will fill, will not drain or agiate
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jun 26, 2010 | Kenmore 22422 Top Load Washer
Kenmore topload washing machine that wont switch to drain
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore will not agitate
The timer is the most common problem. Call any appliance parts store and tell them the model number and ask for price for new timer. Also call sears appliance parts and get price. But a new timer and install it.
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Washer does not spin
You must replace the direct drive coupling between the motor and transmission. About $30.00
Mar 10, 2009 | Kenmore Washing Machines
Kenmore washer machine series 80
If it will not spin either, you most likely have a broken drive coupler. This machine is "direct drive" and has no belt. As techs, we see this several times during our work week. Otherwise, if you have the "two piece" agitator, you may simply need new "dogs" in the agitator. if the machine spins fine, fill it only on the smallest load size with no clothes in it. When the agitate cycle starts, take note if the bottom section of the agitator is going back and forth. If it is, and the upper part does not "ratchet" then you just need to rebuild the agitator and that is an easy job.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
50 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
