Question about Whirlpool Duet GHW9150P Front Load Washer
I have constant water flow into my washer. what do i do to fix it?
  • 347 Answers
The fill valve solenoid assy (mix valve) needs to be replaced. One of the solenoid valves is not seating properly letting water flow into unit even when not running Easy fix all you have to do is shut off the water supply, disconnect hoses remove the top of unit ,three screws in back,slide top towards back..the rest will be easy Good Luck
Posted on Sep 08, 2010
Whirlpool duet 8E error code, what is the cause?
F8E0Steam valve failureCheck the water supply hoses for kinks. Check for a restricted screen in the water valves. Replace the steam valve if defective.
Steam valve
F8E1No water detectedMake sure that both water supply valves behind the washer are fully open. In winter, check the fill lines for freezing. Check the drain system for a siphon problem. If the water valve assembly is defective, replace it.
See the repair guide to fix it yourselfWater valve assembly
F8E2Dispenser failureThe dispenser can't move into position. Unplug the washer and check the mechanical linkage on the dispenser housing. Repair or replace any damaged dispenser parts.
Dispenser assembly parts
F8E3Overflow conditionUnplug the washer and, if the washer is overfilled, check the water valve assembly for proper shut-off of water flow. If the water valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water level pressure switch.
See the repair guide to fix it yourselfWater valve assembly, water level pressure switch
F8E4Low water flowThe flow meter detects a long fill time. Make sure that both water supply valves behind the washer are fully open. In winter, check the fill lines for freezing. Check the drain system for a siphon problem. If the water valve assembly is defective, replace it. If water flows normally, replace the flow meter.
See the repair guide to fix it yourselfWater valve assembly, flow meter
F9E1Long drainRemove excess suds; the washer can't drain excessively sudsy water. Check your house drain system for a clog. Check the drain hose for kinks or clogs. Replace the drain pump if defective. If the washer drains properly, replace the water level pressure switch because it isn't accurately detecting the water level.
See the repair guide to fix it yourselfDrain pump, water level pressure switch
Oct 16, 2016 | Whirlpool Washing Machines
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Constantly leaks water into machine
The relay that shuts off the water, or the mechanism that senses the level of the water, and then shuts off the flow of the water needs to be checked, fixed or replaced. If you're competent to do all that, and have the necessary tools, all the better. If not, them a repairman must be called in....should be fairly cheap to fix.
Sep 20, 2012 | Fisher and Paykel IWL12 Top Load Washer
I get an F H code. I bought a new inlet value which fixed the problem for about two weeks. I then installed the old one wich lasted another 2 weeks. How can I find and fix the correct problem. Maytag ...
As i suppose you know by replacing the water inlet valve that the F-H error code means now water was detected entering the washer. having replaced the water valve,one thing you should check,espically if using"aqua flow flood stop" braided steel inlet hoses from the house water supply,is if water is flowing through the inlet hoses into the washer, if your using that type of hose from the faucet they have a problem in them and the internal flood stop device inside the hose fails and even though the water faucets are on no water is getting into the washing machine. Also or even if using those type hoses disconnect them from washer and check for water flow through them when not connected to washer. If water flow is good into washer replace this part called the flow meter part # W10110225 it measures and tells the control that water is coming into the washer. It the flow meter can of course be purchased where you got the water inlet valve.
Good luck,
Gene
Aug 19, 2011 | Maytag EPIC MFW9700S Front Load Washer
The washer as a code LF what can I do to fix it or do I need a repair man to come?
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa!!
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
G'day, model number 311170n0 is constantly leaking
If you are on city water and your inlet to your house has a back flow preventer this could be you problem.if so theres an expansion tank that can be installed on the cold water line,after you water warms up theres no room for expansion and the relief valve goes off at 150 psi
Jan 17, 2011 | Rheem Water Heaters
Keep getting fh code, replaced pressure switch, replaced flowmeter, noticed that the hot water would not shut off, even put on cold water only and hot water would still run. Machine is constantly sending...
the code means water inlet problem
Have the water flow meter checked or replaced. If the internal wheel sticks inside the meter, the CCU will think no water is entering the washer and give you this error code.
Do you notice an above normal amount of water in the washer when you notice the error code? This is a good indication the flow meter is faulty. You can obtain the part from Sears and install it yourself. Very easy fix.
The flow meter has a reed switch on the side of it.
Sometimes this switch fails and doesn't respond to the magnetic wheel inside the flow switch. It is suppose to provide a pulse action as the wheel turns. The CCU interprets these pulses to determine flow rate. Just because the wheel inside the meter turns, does not necessarily mean the reed switch is functioning. Exactly when do you see the hf error. At the exact moment you see the error is the washer's water level higher than normal?
A GOOD TIP IS: blow air back into drum and into the pressure switch. It will usually work after that!
Mar 10, 2010 | Kenmore 44832 Front Load Washer
The hf flashes and i cleaned all the screens it fixed for a few days and still does it
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 01, 2009 | Kenmore Elite 45986 Front Load Washer
Stops before spin with error code of LF
Apr 20, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Water doesnt stop
defective inlet vavle or ( FILL VAVLE ) replace..onthejob
Feb 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet GHW9150P Front Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
