Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
My cleaner won't pick up the dirty water - Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
  • Bissell Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 08, 2010
Hoover f8100900 will not suction
Here is a site which will guide you through possible causes that are causing the problem with your vacuum and help you pin point the correct one. Hope this helps. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Vacuum-Cleaner/113-203--/Hoover-Vacuum-cleaner-won-t-pick-up-no-suction
Jan 12, 2018 | Hoover F8100900 Upright WetDry Vacuum
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
I have a hoover steam vac spin scrub that won't pick up the dirty water heeelllllllppppppppppppp please
The most common reason for lack of pick up is that the lid is not fully seated on the dirty water tank. Be sure to hook the two tabs on the front of the lid, and then snap the rear latch into place. Another reason is that the duct on the front of the dirty water tank is missing. The duct may have been removed to install the hose, and was not put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. A far less common reason for no pick-up is that the seal that the tank sits on has fallen off the motor cover suction tube. You will see a round tube on the bottom of the dirty water tank. This sits on top of a large rubber seal on the motor cover when the tank is in place. Be sure the seal has not fallen down into the hood.
Jun 15, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Cleaner does not get up water
The most common reason for lack of pick up is that the lid is not fully seated on the dirty water tank. Be sure to hook the two tabs on the front of the lid, and then snap the rear latch into place. Another reason is that the duct on the front of the dirty water tank is missing. The duct may have been removed to install the hose, and was not put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. A far less common reason for no pick-up is that the seal that the tank sits on has fallen off the motor cover suction tube. You will see a round tube on the bottom of the dirty water tank. This sits on top of a large rubber seal on the motor cover when the tank is in place. Be sure the seal has not fallen down into the hood. This applies to the F5800 and F5900 series SteamVacs.
May 09, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
78 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
