Question about Swift Ultra-Lite 762 Binocular
Is there a tethered lens cap for the swift 10 x 42 model 762? I cannot seem to find any that will fit this model.
Keeps saying to turn off camera and won't take pictures
What the troubleshooting guide suggest is to turn off the camera and turn it back on which sound like what you have been doing. The cause of this generally points to a camera malfunction between the camera and lens. This makes me believe that either something is restricting the lens from moving like the lens cap is tethered to the camera and tight on the lens so it can't do it's "pre" view and goes into the shut down mode. If the lens has any restriction be it the lens cap, ever ready case or anything that is restricting the lens movement remove it and try it again. I have another theory which is completely opposite to anything even suggested and that is the camera can't read the SD card so goes into shut down mode. If you remove the SD card and check to make sure the "lock" switch is in the unlock position. I'll give you a diagram for this.
The little switch needs to be pushed forward towards the gold contacts.
Diagram
Jan 09, 2011 | FUJIFILM FinePix S1800 Digital Camera
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
Dec 21, 2010 | Sony Lens Cap for A100
My polaroid dvg 1080p camcorder is great except there's no lens cap. how can I get one?
Lens caps for this model camera are not available from Polaroid, unfortunately.you could certainly fashion one from a used medicine bottle cap. Find a one that fits over the lens, paint it black, and add a string or take a lanyard from your old camera and use it! It's a cheap alternative, but an alternative nonetheless!
Apr 06, 2010 | Polaroid DVG-1080P HD Camcorder
Cant seem to fit the converter to a 50-500mm ex sigma lens ?
It all depends upon the lens. Not all lenses can accept teleconverters, usually due to projecting rear elements incorporated into the individual lens design. With such lenses, manufacturers will either advise that a particular lens will not be compatible with a teleconverter or for some models may produce a custom matched model usually for that lens alone.
Which exact lens are you trying to fit to your Sigma 1.4x EX APO DG teleconverter?
Feb 05, 2010 | Sigma 1.4x EX APO DG TELE CONVERTER (CANON...
How do i replace rear bearings in a suzuki swift i cant seem to get the cap off
cgi.ebay.com/.../95-96-97-98-Suzuki-Swift-Rear-Wheel-Hub-Bearing_W0QQitemZ350283708684QQcmdZViewItemQQimsxZ20091124
check this site out. its selling upgraded parts and the parts come with instructions and specs. thses are going to be one of two styles. either you need to remove the cap like you were saying or if you look at the back you may see 3-4 bolts which will allow the release of the bearing assembly. try taking a screwdriver under the lip of the cap and do thiall the way around with a hammer tapping just enough to get under the lip. if you are doing the left side, be careful as it will have left hand threads.
Dec 17, 2009 | 1997 Suzuki Swift
I hace a pair of swift ultra light binoculars and have lost 2 screws in one of the eyepieces. Where can I get replacements>
i would take one out of the other side and take it to a hardware store and see if i could match it up with some thing.
Nov 03, 2009 | Swift Ultra-Lite 762 Binocular
Need 80mm eyecepie,for swift spotting scope #821.
LARGEST EYEPIECE MAGNIFICATION LENS FOR THE SWIFT 821 IS 60MM. THEY DO NOT MAKE AN 80MM FOR THIS MODEL. THE EYEPIECES ARE INTERCHANGABLE IN 15X, 20X, 30X, 40X, AND LASTLY 60X.
Sep 07, 2009 | Swift Optics
My camcorder when you turn it on reads "lens cap" and will not record it thinks the lens cap is on what do i need to do to fix this. thanks Ric
hi,
normally on some cam's there is a small switch like device where the cap fits, if this switch is stuck or something has got stuck, then the signal it gives would be as lens cap.. so i suggest you chk this first.
any way if you can give the brand & model name then it would be much more helpfull.
Mar 23, 2009 | JVC COMPACT VHS-C CAMCORDER
Lost lens cap
I would sugest using an adaptor ring. You can reduce the size of your lens opening down a common size lens cap that will fit your camera. If you can't go this route then give me the make and model number and I will see what I can do for you. LJ
Sep 18, 2007 | Konica Minolta DiMAGE Z20 Digital Camera
F717, protector and lens cap (question)
Had the same problem with my polarizing filter. The Sony lenscap was not a snug fit onto the polarizer. Solved the problem by purchasing a cheap third party 58mm lenscap at a retail photography shop. Cost under $5.00.
Sep 12, 2005 | Sony Cyber-Shot DSC-F717 Digital Camera
Swift Ultra-Lite 762 Binocular Logo
Top Swift Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Bill Laudeman
Bill Laudeman
Level 1 Expert
Are you a Swift Optic Expert? Answer questions, earn points and help others
