Question about Bosch Dishwashers
Dishes not clean I dont think it is draining right
  • Bosch Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 10, 2010
It doesn't wash the dishes well, leaves dirt and doesn't melt the detergent
Dishwasher Not Cleaning Dishes - The Family Handyman
www.familyhandyman.com > Skills > Appliance Repair
When your dishwasher doesn't clean well, fix it yourself following these simple steps and avoid the expensive professional service call. A simple cleaning often ...
Why Doesn't My Dishwasher Actually Clean My Dishes ...
dishwashers.reviewed.com/.../why-doesnt-my-dishwasher-actually-clean-...
Feb 26, 2015 - My dishwasher is supposed to wash dishes, right? So what are all these ... The good news is that filters are incredibly easy to clean. The little ...
What to Do When the Dishwasher Won't Clean - YouTube
? 8:27
https://www.youtube.com/watch?v=aZojUCnQifs
Sep 21, 2012 - Uploaded by doityourselfstan
Dishes aren't getting clean in your dishwasher? The problem ...Whirlpool, Maytag, Sears dishwasher Repair & diagnostic - Not cleaning well ...
Jan 01, 2016 | Dishwashers
I have a maytag quiet series 300, dishes dont get clean on top rack and sometimes it doesnt drain. do i need to clean some trap or drain?
Check the screen area around the sump right below the lower spray arm if it is built up with lime deposit then the wash pump is starving for water and cannot pump water to the upper spray arm this would also starve water to the drain pump.
Mar 06, 2014 | Dishwashers
How do i get it to drain water
new install? check end of drain hose where it mounts to disposer, there may be a plug in there.
If old install, drain at the bottom of dishwasher is plugged, may be plugged in pump which recycles water. If it aint thrown water, your dishes ain't going to get clean.
Feb 14, 2012 | Whirlpool Dishwashers
Our bosch shu9902uc dosnt clean the dishes,ive tryed to clean out the drains,blew compressed air thru the drain line,cleaned out the sprayers,still it dosnt clean food off the dishes. water plenty hot and...
make sure you clean the sprayers out real good,if theres debris on the end nozzles they dont spin around too good,also pull out the little service plug that protects debris from getting in the impeller.
i found a little chunk of wood in there! im still not sure how wood ended up in the dishwasher!
Jan 04, 2010 | Bosch SHU9922UC Built-in Dishwasher
Dirty dishes coming out of dishwasher dirty
check your drain line it should go up from bottom of d/w and then go down to drain that is so water from sink wont back up into d/w
Oct 27, 2009 | Dishwashers
Dont clean my dishes
Try cleaning out your drain because it could be clogging up and this can cause it not to clean the dishes.
May 19, 2009 | Tappan MDB531RF Dishwasher
WATER IS NOT DRAINING IN THE BOTTOM OF DISHWASHER
I am thinking these expensive dishwashers have reached end of life. I cannot get it to drain, clean the dishes or shut off when the door is opened. I bought this product thinking due to its cost, it would last longer. So sick of being ripped off. Let me know if you find a solution RMCDaniel at kervin@avaya.com
May 01, 2008 | Dishwashers
Presto Heat Dish
The hardest part of cleaning the dish is that you can't get your hand inside the cage surrounding the dish. What I did was to use a wire cutter to snip enough pieces of the cage off so that I could get access to the dish. If you do it carefully, it looks as if it was intended and doesn't prevent the cage from working. If you think of the cage/dish as a clock, I cut all the strips between 9 and 11, and 1 and 3. Easy to clean the dish afterwards.
That might not solve the buzzing problem, though. It didn't solve it for me.
Feb 07, 2008 | Presto HeatDish Compact Heater
GE Built in Dishwasher
You possibly have several problems. The plunger is broken to the dispenser. You will have to disassemble the door to check the dispenser. Your water not draining is why the dishes aren't getting clean. Check to see if your drain hose is clogged. It may drain at a disposal or through a siphon gap which is mounted to the rear of your sink. Sometimes the siphon gap gets clogged and will cause drainage problems. It sometimes is located at the right or left rear of the sink and has a cap that sits about 3 to 5 inches high. Take the cap off and make sure there is no clog.
Dec 21, 2007 | Dishwashers
Diswasher Leaked, now Won't Work
if you see a float inside of the dishwasher make sure its cleaned well.that float tells the control board when to drain and to fill with water.the symptom you descibe tells me its trying to drain,make sure the float moves freely.if you dont have a float you will see a metal probe clean that up as well.try this and if it doesnt fix the sensor may be part of the drain body and it has failed(leaking).
Aug 27, 2007 | Bosch SHU9915UC Dishwasher
Dishwashers Logo
47 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
