Question about GE DLSR483EE Electric Dryer
Dryer has no power even though outlet has power
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 08, 2010
Kenmore 110-88752793 washer dryer. Tub filled up for the rinse cycle and then stopped. Tried turning on the dryer and that has no power either. Cycled the circuit breaker. Still nothing. Any ideas?
The circuit that supplies your washer and dryer may also have an in-line GFI outlet which may have tripped. Even though you have cycled the circuit breaker you would also have to reset the GFI outlet as well. Good luck.
Nov 26, 2016 | Kenmore Washing Machines
How do I check for power to my dryer
You could plug something else, like a lamp, in the wall outlet and see if that gets power.
If the dryer requires a phase connection, that would be harder to test. Then you would need a volt meter to test the power outlet for proper voltage. That's a little dangerous though, unless you have some experience with power line testing.
Hope this helps.
Feb 04, 2015 | Whirlpool LEW0050PQ 3.8 Cu. Ft. Electric...
How to fix a dryer wont dry
If it gets hot but won't dry, it will always be some form of blockage in the venting system. That could be a smashed vent hose, lint clog in the hose or the exit opening outside, a bird has built a nest in your outside vent, the hose run is very long before exiting to the outside, etc.
If no heat, could be the element, could be a thermal fuse, could be a burned wire and in VERY RARE cases it can even be the motor even though the dryer comes on and turns.
Sometimes you have a home electrical problem where your 220 outlet is providing power to the motor but not to the element.
May 12, 2014 | Roper Dryers
Dryer was working fine until I turned off the breaker to work on an electrical outlet on the same circuit. When I was done I turned on the breaker all other outlets worked, I went to use the dryer and...
Hello Steve,
I am a bit confused because the model you selected is for a electric dryer which should have a dedicated outlet/breaker only for the dryer
I am going to assume it's a gas dryer and the trouble is with the outlet,to verify this plug a know working object into the outlet and see if it works
Even if the part in the dryer part that cuts the circuit to the motor if it's bad(thermal fuse) has no bearing on the drum light and that should work if power to dryer
Gene
Jul 29, 2011 | Estate TEDS840JQ Electric Dryer
WILL NOT HEAT, 240VOLT AT OUTLET, POWER TO MACHINE, CONTROLS WORK PROPERLY,
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 26, 2011 | Dryers
What could cause no power supply to my dryer
There are a couple of things...
First check the circuit breaker in your electrical panel....even though it says it is on turn it off and forcefully slam it on again...
Next thing would be to check the wiring in the outlet and plug...these wires can heat up become loose and then not make contact. If the outlet or the plug looks burnt or is brown at all replace both the outlet and the dryer cord....
Next check the wiring at the dryer....same thing... look for brown or burnt wires...replace the wiring as needed....
Make sure to turn off all power before checking anything!!! Electric can be deadly!!!
If all of this check out then the problem is internal in the dryer...of course using an electrical meter can make the job much simpler.... the power can then be checked at each stage...a meter can be purchased at many dept. stores or Walmart for around 20 bucks....
Set the meter for an A/.C voltage setting of greater then 240 volts.... the reading across the two hot lines should be at least 220 volts...be very careful when trying to get these readings on hot wires...
Heatman101
Nov 07, 2010 | Whirlpool LER4634J Electric Dryer
My dryer wont start i have power 220volt comming out of the outlet but nothing
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 06, 2010 | Whirlpool WED5300S Electric Dryer
Our Maytag Intellidry PYE4558AYW dryer will not turn on
Check the door interlock switch. If it is defective, the machine will not start. If no help, then there may be trouble in the control panel.
Jan 02, 2010 | Maytag PYE2300AY Electric Dryer
ELECTRICAL POWER DOES NOT SEEM TO WORK EVEN THOUGH PLUGGED IN
Try another outlet in your home. Or if it is plugged into a surge protector remove it for the surge and plug it directly into another outlet
Jun 11, 2009 | HP Compaq nc8000 Notebook
Dryer trips the GFI
It sounds as though some component in the dryer has a high resistance short to ground. Not enough to burn it up, but enough to allow the current in the hot leg of 120VAC to be greater than the current through the neutral leg.
It is also possible that the ground is a low resistance short to ground. Have you tried to temporarily plug the dryer into a non GFI outlet (use a heavy duty extension cord)? If so, does the breaker for that circuit trip?
DO NOT LEAVE THE APPLIANCE CONNECTED USING AN EXTENSION CORD! THIS IS ONLY TO TEST THE APPLICANCE FOR A HIGH RESISTANCE SHORT.
Either way, I would be suspect of the motor first, and the pilot igniter circuit 2nd. Please provide more information as to what you find in the test above.
Jan 14, 2009 | Whirlpool GGQ8831L Gas Dryer
GE DLSR483EE Electric Dryer Logo
65 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
