Dear i have prima plasma tv 19 inch model no. lc-19hu268s, now i want connect dvd player to tv , i tried i canot see the vedieo in put can u please help if u can get manual for this tv please sent me hadil003yahoo.com
siphilips
  • 34 Answers
SOURCE: connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Posted on Nov 05, 2007
SOURCE: i need the code for my tv 19 inch tv model number is 19tvd4s
The code is 1944 on a universal remote, but you will only be able to access basic functions, not the setup functions....you will need to find the original remote on ebay or something to get full access to the TV functions
Posted on Dec 20, 2008
ruben_barrer
  • 117 Answers
SOURCE: Panasonic PV-20DF64 20 inch TV/DVD Combo TV can not read disc
If the disc loads up and you can hear it spin, then you get the error, more than likely the optical lens has been damaged. This will have to be repaired by a local shop if its worth the cost. if the part is available it would probably run anywhere from 130-165 to repair
Good Luck!
Ruben
Posted on Jul 23, 2009
  • 107 Answers
SOURCE: how to connect a DVD player
heres a link to your tv info..
http://www2.panasonic.com/consumer-electronics/support/Televisions/TV-Combos/Operating-Instructions/model.PV-M2048.O#ts
it doesnt have AV connectors on it, but you can get an RF to AV converter for it at radio shack, best buy, etc...should be about $30 and will give you the inputs your DVD needs
Posted on Aug 28, 2009
SOURCE: digital labs 19 inch tv/dvd combo
Wish I knew the answer ... I have the same problem after switching to Dish Network (Satellite). It worked fine with Time Warner Cable. I'm suspecting the signal over Dish is analog (NTSC) which is not supported by this particular TV. I wish I still had the box and receipt!
Posted on Feb 01, 2010
Testimonial: "Thanks, I am going to call the company tomorrow and see if they have a solution. If not I am not sure what to do. Thanks for your help."
Sir I have prima hd tv.model.LC.19HU268S I Lost my remote control. I need remote model Number
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. You can't get its original one from nowhere from the open market. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Oct 28, 2016 | Prima Televison & Video
I have a beko 37 inch hd ready tv i recently go the sky hd box . my tv only has one hdmi port and i also have a samsung blu ray dvd player which only has a hdmi connection i got a switcher box for the hdmi...
It is possible the hdmi cable that you are using is faulty. The reason I say this is because you have multiple signals that pass through a hdmi cable (19 pins in it means 19 wires to carry signals). The more the cable gets moved and bent, you increase the chances of creating a short or re-connecting a short if moved from one tv to another. This is the best case scenario as it is easier to replace the cable and less costly. Since you already connected the the dvd directly to the tv, and I am presuming that you have working devices running through the switch and you can eliminate that as the problem. If you do not have working devices on your switch or directly into your tv, and you have tried multiple hdmi cable and still nothing, the hdmi connector on your tv is probably bad and that would be the worse case scenario.
Nov 03, 2013 | Philips Televison & Video
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
32 inch prima lcd tv model lc-32u16 that won't turn on
You probably have some defective filter capacitors in the power supply. The tops of them may be domed instead of flat. Be sure to replace them with same values listed on the originals - slightly higher voltage rating is OK, but no less! Make sure they are rated at 105 degrees C and not 85 degrees.
Apr 02, 2010 | Prima C2012 TV
Program prima tv remote
prima lcd tv:lc-27w25s auto search passward
Mar 15, 2010 | Primax Electronics HT2778P TV
Hooked up cable box, wii box and dvd player to new lg 50 inch 720p plasma tv... all external components work, however, dvds and wii only show in black and white - no color...
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
Dec 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
Built-in DVD player in tv stopped reading discs
try to clean the laser lens with rubbing alcohol and a q-tip. be gentle
Sep 24, 2009 | Televison & Video
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
Panasonic Viera 37 inch Plasma won't read DVD player
does the cd/dvd player have component hookups or are you just using HDMI cable, lots of tv's are having trouble with the HDMI protocol, I only use component cabling, it has HD capability up to 1080i resolution
Mar 16, 2008 | Televison & Video
Unlock region code for Toshiba SD-5000
what make of dvd player do you have?
make and model
Jan 18, 2008 | Toshiba SD-5000
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
