The internet button and volume control button have stopped working. Where do I look to check if they are turned on? I had some work done to speed the computer up and they have not worked since this was done.
  • 95 Answers
Connect the keyboard with any good computer and check the internet button and volume control button is working or not.
Posted on Sep 08, 2010
  • 83 Answers
The person that modified some settings on your computer might have disabled the services that allow these things to be shown.
For sound, if you can hear sound and the volume control does not appear, try going to the control panel and check the sound applet. You have an option there to make the icon appear on the system tray beside the clock.
For internet, go to control panel, go to network connections, you will see there your active and inactive connections on the computer.
Hope this helps! :D
My RCA 46la45rq tv remote AND side buttons stopped working
The panel control circuit inside should be checked. Contact any experienced service technician.
Nov 27, 2012 | RCA 46 46LA45RQ LCD TV
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
2002 Ford F150. Cruise control stopped working.
Did you have the recall done on it ?
recall 05S28. Description: Speed Control Deactivation Switch.
It could be a blow fuse in the recall harness, if you did have it done.
Try the self test, and see what the results are. If you do not get it into self test mode, it could be the fuse in teh recall harness that is blown. The 1st revision of the recall harness was an inline ATM fuse, not sure if the revision 2 was the same. If that fuse is blown, the switch is leaking, and should be checked.
Self-Test Diagnostics
WARNING:
This test is a key on engine off (KOEO) test only that is conducted in park only with emergency brake fully engaged.
1. Enter self-test diagnostics by depressing the speed control OFF switch while turning the ignition key ON, making sure the engine does not start and is not running. The speed control indicator on the instrument panel will flash once to indicate that speed control module entered the diagnostic mode. Five additional flashes at this point indicate a defective speed control servo. Release the OFF switch.
2. Press the remaining switches in this sequence: ON, RESUME, COAST and SET/ACCEL.
If the ON switch is not depressed within five seconds after entering the diagnostics mode, the module times out and the procedure must be started over.
The speed control indicator lamp will flash as each switch is depressed. Press each switch in the sequence immediately after the indicator light goes out for the previous switch.
Note:
There will be a slight delay when the last button is pressed and the lamp flashes.
3. A lamp flash with the last button (SET/ACCEL) indicates that the static test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective.
If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
— 2 flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
Feb 22, 2010 | 2002 Ford F150 Regular Cab
Volume buttons stopped working
Check in the TV's AUDIO menu for anything related to turning on/off speakers. Also, unplug RCA's that you may have hooked up to the Audio OUT ports. Some video inputs may not have a sound input associated. The only one I can think of would be VGA, but even that would be rare.
Dec 05, 2009 | Samsung RS105N Remote Control
Hp laptop touchpad for cd and wireless conet. stopped working
I get it. The multimedia keys above the keyboard is not working. If I'm right, check if you have installed the HP Quick Launch buttons software. If not check in C:/SwSetup and you'll find a folder. Install the application and check if the buttons are working. If not, post back
Jun 24, 2009 | HP Pavilion dv4000 Notebook
The volume control won't work on my sky remote
for a toshiba tv,
press tv
press and hold select and red until the led blinks twice
type in 0 1 5 6
press the power button on the remote
If the tv turns off press select and hey presto you're done, if the tv doesn't turn off, press tv then press the power button and keep doing this until the tv turns off. When the tv turns off press select.
Nov 17, 2008 | Universal Remote Control Remote Control
Radio volumn goes down when braking
if there is a menu button or something like it look for avc auto volume control set to 0
Nov 13, 2008 | 2006 Ford Focus
Compaq Presario v2000 ALTEC LANSING speakers not working
Go to "Start", "Control Panel", Administrative Tools, Computer Management, click on "Device Manager" on the left hand side and look on the right hand side. See if you have a yellow exclamation next to the "Sounds, Video and Game Controllers". If yes, double-click on the line with the exclamation and then click on the driver tab at the top. Click update driver and when it asks if you would like to to check the internet for updated drivers, tell it yes, this time only and continue. After this process, it should either download and install a new driver for your sound card or install the one that was shipped with your computer. If this does not work, please let me know and we will check the next possible problem.
Please remember to rate this solution.
Sep 22, 2008 | Altec Lansing Multimedia Computer Speakers
Help
Hold the menu button (the m button, in the middle), then it will go to the main menu.
Then click on the music button with the "m" but dont hold it then click the play button and then click the volume button wile the sign next to the bar that tells you how long the song is and how long it takes to get done. check the volume if you have it on pause or stop it will go strait to the record button. try it and if it dont work then srry.
Feb 24, 2008 | Mach Speed TRIO Onyx MP3 Player
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
