I have an Abit AMD socket A VA-10 motherboard that does not recognize a Western Digital SATA drive I am trying to install. The bios recognizes the drive and the boot up post sees it but will not but up but freezes on the boot up process. I think I need a SATA HDD controller driver so it will recognize the drive. Please help.
    Top Expert:
  • Computers & ... Master
  • 76,109 Answers
You must have a board that is SATA equipped or use a IDE drive, if it is a software issue the maker of the motherboard can supply the software, just contact the customer web site.
Posted on Sep 08, 2010
Abit-vt7 can't get bios to recognize SATA drives
http://driverscollection.com/?H=VT7&By=ABIT
Dec 10, 2013 | Abit Computers & Internet
Sir, i have an msi n1996 (vt8237r & km400 8237) mother board. My sata 160 gb hdd is not getting recognized in bios. Pl. help. (it is reported somewhare on the net that i have to enter into the...
I enabled SATA support on my BioStar M7VIZ-SATA MOBO (it is km400 and 8237r, like yours) by first installing the VIA SATA RAID drivers. At this point, Windows recognized the device controller but not the 120GB drive. The problem was that the system doesn't support "newer" SATA drives, so I installed a jumper on the disk drive to set it to "150" mode... SATA version 1 compatibility. After that, Windows immediately recognized the drive and mounted the filesystem.
I think it was a Western Digital drive. Other manufacturers have a different name for the same jumper. Also, I read that one type (Samsung?) can only be set to the old SATA standard by getting the drive running in a SATA 2 environment, then using a utility program to adjust the drive's microcode setting.
Good Luck to you.
May 28, 2011 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
Just bought a new cpu, put it together and purchased the western digital 160 gb sata II model number WD1600AAJS. i am installing windows 7 on it, or attempting and it won't recognize the drive. it says it...
The drivers are not needed, West. Digital is right. Your problem is that the hard disk is not recognized by the motherboard (not the cpu). Since you didn't mentioned anything about motherboard's brand / model, I have to tell you that you have to get into the bios settings and get yout hard disk recognized by the bios. I assume that the connections are right.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 19, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Doesn't recognize SATA hard drives. BIOS option
Need to install latest bios update go to there website also if you are trying to boot up with usb installed take it out. BIOS ID:15
  1. Fixed the issue where SATA HDD boot up will fail if USB storage device is installed.
  2. Fixed the issue where SATA HDD boot up will fail if "USB keyboard/mouse" setting as "BIOS" section.
  3. Enhance the compatibility of SATA device on WIN98SE/ME.
  4. BIOS compile date: 06/07/2004
Nov 28, 2009 | Abit KV7-V Motherboard
Gigabyte 945 gzm s2 doesn`t recognize HDD Western Digital 320 GB
You might need to change your bios settings from ide to sata. Have you already checked the bios settings? If everything is in order you might have a bad board. What have you tried so far?
Nov 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Trying to install a new sata harddrive but win xp does not recogn
check bios and set the parameters for the new hard drive. These parameter should be found on the hard drive itself
Dec 10, 2008 | Dell Computers & Internet
HDD both IDE or SATA 1 are not recognized
Unplugg the disk from motherboard and reboot your computer
Shut off the computer, connect the drive again and start up again.
If the problem continue, set the drive on your bios manually.
If after that the problem continue replace the disk.
Oct 06, 2008 | Abit KV-80 Motherboard
Wd800jd sata hard drive not recognized in bios on boot up
Hi, A couple of ideas: 1. There are 3 versions of this motherboard: Dragon Plus, V1.0 & V2.0, perhaps your BIOS needs an update to be able to recognize the new HD. This of course would require flashing; 2. There are two variations of a WD SATA hard drive: Serial ATA amd Serial ATA II; 3. Re Jumper settings: the eight-pin jumper block is only used to enable power management on the drive. There are no master/slave settings since there is only one drive per cable; 4. If you are fresh installing Windows on it, you need to press F6 when asked by the Windows Installer and follow on-screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information.
Sep 17, 2007 | Western Digital Caviar SE WD800JD SATA...
Hard drive recognized as slave drive
You probably need the change the jumper on the hard drive itself. The jumper looks like a thin little cap that covers a set of pins on the back of the hard drive. You should see it next to when you power supply connects and most drives will usually have a diagram on how to change the jumper from a slave to a master.
Sep 09, 2006 | Cornerstone FIC VA-503+ Socket 7 AT...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
