Question about Danby 22 in. DDW399 Free-standing Dishwasher
Were do you put the soap and how much should I use. What is the best soap to use.
Suggest me the best organic soap?
When it comes to selecting soaps for use, I always prefer going organic, because whenever I use Natural Skin Care soaps I feel more secure and better. These are much better than the normal soaps as well. They create no harmful effects on my skin. Non-organic soaps on the market are loaded with synthetic and artificial ingredients, which then cause skin allergies and irritations, not mentioning the dryness and itchiness they cause due to heavy loads of chemicals. With organic soaps, I am able to avoid all these because they pose no harm to my health but only give skin benefits, including moisturizing and nourishing.
Dec 08, 2017 | Best Computers & Internet
Tip
HOW TO WASH YOUR BUGABOO
Hand wash it. Sunlight soap is the best and give it a good soak and rub with your hands and the marks should come out. DON'T put it in the washing machine, so many websites say just machine wash but I don't recommend it. I have seen hoods completely skewed out of shape. There are lots of layers in the making of these (another reason why they are so expensive). They don't take long to wash, rinse until waters clear, squeeze excess water out and then dry in the shade. Don't put any cleaning substances/ upholstery cleaners on it, Sunlight soap is my all time favourite for this sort of thing and gets most marks out. If you don't know what Sunlight soap is then any pure soap or baby friendly washing soap would do (one with a picture of a baby on it).If you want details on how all the fabrics fit on to the Bugaboo check out Bugaboo Customer Service for downloadable User Guideswww.bugaboo.com/28 (note Bugaboo change site page names frequently so this link may be out of date when you try it. Just take the 28 out and try again.
on Jan 27, 2011 | Bugaboo Cameleon Jogger
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
I have a Semi Automatic Whirlpool Sparkle washing machine my question is can i put water in the dryer just to remove soap from the clothes
Whether your dryer is electric or gas, DON'T PUT WATER IN THE DRYER!!! If you need to get more soap out of the laundry, run it through another cycle without soap.
Jul 27, 2014 | Whirlpool Washing Machines
Don't know how to use with shampoo
Best to not put shampoo in machine. Put traffic lane cleaner in sprayer with hot water, spray onto carpet after thorough vacuuming, allow cleaner to dwell 5 to 10 minutes and clean and rinse with fresh clean water in machine. For best results do NOT put shampoo in he machine even though it was designed for it. Most of the machines brought in for repairs are clogged with soap gunk. Carpets will be cleaner and stay clean longer because the soap has been rinsed out of carpet
Sep 26, 2013 | Vacuums
Detergent cup not draining
think you mean one compartment staying full of water this would be for softner or if the soap powder is staying in the drawer then a blocked pipe to the drum could clog useing to much powder at one time best results are put soap strait in the drum then cant clog i am an domestic engineere and have seen this problem a number of times
Aug 12, 2012 | Washing Machines
What is the best way to clean a 46" LCD Toshiba TV
You do not want to use any harsh chemical or anything in excess. What I use and recommend is simply water and dish soap such as ivory. Use clean lint free paper towels or cotton or soft fabrics. You put a drop or two of detergent on a damp towel.You gently wash the screen then wipe it dry. The towel needs to be damp but not enough so that you get any running water.You may need to do it in small sections. If you use too much soap you get streaks. If that happens just get another damp piece without soap and go over and then use the dry to wipe the screen dry. The soap takes off anything without harming the anti-glare coatings on the screens. The wrong type of alcohol or a harsh cleaner can strip these coatings off or damage the plastics. Dish soap and water is very safe dirt cheap and found in the kitchen usually. ;-]
Sep 02, 2011 | Toshiba 46SL417U LCD TV
I recently replaced the latch on my dishwasher, and after I performed this task, the soap dispenser door will now not open to allow the soap to dispense. I tried just putting the soap packet in the bottom...
Hi, W/D here.
Look first at your wiring connections to the dispenser. It is very easy to install the connections in a position where the terminals do not make contact. Check each one, and trace it back to the control panel and check the contacts there as well.
Best regards, --W/D--
Feb 28, 2011 | Whirlpool Dishwashers
I have a Grohe soap dispenser and it has quit working for me. It is as if it gets stuck after you push it down and it seems to leak the soap out of the bottom part of the dispenser getting soap all over...
Sounds like there might simply be old soap caked on the inside of the dispenser head and feed tube. Best thing to do is have a sink filled with HOT water and just put the head portion in there to soak for a while. This should loosen the old soap enough to either dissolve or at least get it moving again. You can also take what soap is still in the dispenser out and put in another container, taking time to rinse the container with hot water as well and then filling it with hot water as well to test the pump action of the head, again using this action to help clean the insides of the pump. Short of this doing the trick, it may just be time for a new one. Good luck.
Aug 26, 2010 | Grohe Satin Nickel Soap Dispenser...
Water is not spraying around and soapy water is in bottom after putting no soap for past five starts
You have an oversud problem and pump is cavitating due to too much soap. best and quickest way is to remedy is use 1 cup liquid fabric softener and let dish washer run thru complete cycle wit heat dry in off position.The fabric softener will break down the soap and remedy the problem. Hope this helps.
Feb 12, 2010 | GE Dishwashers
Danby 22 in. DDW399 Free-standing Dishwasher Logo
Top Danby Dishwashers Experts
Batista Saint
Level 1 Expert
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
