Question about Hotpoint WF430 Front Load Washer
Wf430 stuck in wash cycle runs continuously No error codes, am able to stop it then pump out / spin Can you help please
    Problem Solver:
  • 10 Answers
Try to check the pressure is not faulty, unclip the pastic tube and blow into it, should to clicks - that mean's it ok and then check plastic tube has no leaks and make sure it is firmly attached at both ends.
Posted on Oct 07, 2010
  • A Hussain Oct 07, 2010
    sorry for the previous post, it should have been... Check the pressure switch, open cover and it is on the top left hand side of machine, unclip the plastic tube and blow into the switch, should here two clicks - this means its ok, then check the plastic tube that's attached to it has no leaks and is firmly attached at both ends.
Siemens SI14-44 washing machine is error coding F:18. something wrong with the emptying of the machine.... is the filter blocked? is so where can you clean out the filter?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
F:18? if this error is for water stuck?
for the automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
A GE stackable washer/dryer that is stuck on spin?
Good Day,
your machine is normal is washing cycle?
if yes.do the same
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Whirlpool WFC7500VW Washer
417 44152400 21 code reads e63 and machine not draining properly
Good Day,
Nov 01, 2013 | Kenmore Front Load Washer
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Nov 01, 2013 | Zanussi Washing Machines
Keep getting F 02 Message
If this is a newer model Maytag (such as the Epic), "F02" is a Long Drain error code. This is usually an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608545-f02_error_code
Included is a follow-on link that explains how to access and check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please post back with your MODEL NUMBER and let me know. I hope this information is helpful to you.
NOTE: If these preliminary measures do not correct the problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Jan 18, 2010 | Washing Machines
Wash cycle stops, F21 error message appears
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Sep 11, 2009 | Kenmore Elite HE5t Washer
Leak from lower door section and from powder door thing.
This could be a partially or completely seized/failed pump.
Before a machine goes in to a spin cycle, it runs the pump to empty all the water out. It used to be quite common that the machine does not check all the water has gone before spinning, it just runs the pump for a set time which if the pump is okay, is long enough to empty it.
If a spin is then started with quite a lot of water left in the drum, it gets thrown everywhere including back out of the powder/conditioner draw. Also the sheer strain of spinning a large amount of water can force water through an otherwise okay door seal.
Unless you are comfortable working on the machine yourself, call an engineer.
Sep 07, 2009 | Hotpoint WF430 Front Load Washer
Hotpoint WF430 Front Load Washer Logo
146 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
