Question about HP Compaq nx9030 Notebook
I have the same problem, caused by a falling from the desk. Now I can see the image, but completly brightless. I think it's a cut wire, but i don't know which one. What should I do? Buy and replace the inverter, or try to repare the wire? Do you know the pinout of the monitor laptop wires to motherboard in this model? Excuse my english and thanks for all
  • HP Master
  • 4,924 Answers
If you have an image on ..but just shadows it is the inverter to blame and Im not sure it is from a cut-wire..so ..I suggest to get a new inverter and install it cause it is not very expensive and this way you will avoid any improvisations that may cause future issues ..(inverter back-light )
Posted on Jan 23, 2012
  • janfriwein
    janfriwein Jan 23, 2012
    Thanks you Catalin. I did that: i bought a inverter, but when it arrived (i had some problems), the lcd screen was broken, so i'm looking for a broken laptop to change it :) Thanks you
  • Catalin Turcu
    Catalin Turcu Jan 24, 2012
    http://www.ebay.com/itm/HP-Compaq-NX9030...
    If the screen is the issue and you know it for sure..try one of these for an alternative ..It may be cheaper cause a new screen is over $200 and it is not worth the money for such an old model ..
I have bizhub c450 , printing time devoloper comin on edge of paper , my imaging units are nes
Removed all imaging unit then below you will see PCL in every imaging unit you must clean it with soft cloth completely. When PCL is covered with dust,toner,dev etc.. the developer from your imaging unit become to fall causing developer on edge of paper(dirty copies).
Dec 26, 2014 | Konica Minolta bizhub C450P Laser Printer
2003 Mitsubishi lancer 2.0 ralliart. Complete loss of power under wide open throttle between 2,000 - 3,000 rpm. Car idles fine and continues accelerating after 3,000 rpm under wide open throttle just fine....
oxygen sensors buddy, and there is two of them. one above the engine and under. you have to cut it enough to where you can splice and re wire another sensor on.
Feb 23, 2013 | Cars & Trucks
I have a Ford Ranger 1997. I don't think the anti theft is factory. Someone may have installed it. how do I start my truck.
We only have info on factory installed systems. But go under the dash and look for cut into wires and a black box taped up in the factory wiring, that will be the aftermarket device.
Oct 17, 2012 | Ford Ranger Cars & Trucks
My desk is extremely cluttered and I know I need to clean and organize it, I just don't know where to start. It all feels way too overwhelming. Can anyone give me some tips on how to best organi
Cleaning your messy desk can be a daunting task at times; however it is necessary. I came across a great article about desk cleaning that I think could be very useful.
http://www.wikihow.com/Clean-Up-Your-Desk
Aug 15, 2012 | Furniture
I need to find a new power button for my acer t690 . the old one craped out the spring and now cant use my desk top <sad and cryin> please help
Making a (DIY) Do It Yourself switch will cost you less rather than replacing it with the same switch, if you cant find one.
Tool's
Soldering Iron Soldering lead Desoldering tool (Optional) Shrinkable tube. Wires (Optional)
it might still work, most casing switches looks like this
Figure1: Power Switch with cable and female header pcsyke_33.jpg
1. Open your casing, trace the wires of your Power Switch. cut and replace the power button if found defective. some samples of PS buttons.. pcsyke_37.jpg
2. Solder the black and red wires to your new power switch. put the shrinkable tube, apply heat to shrink.
Hopefully this helps. Sorry I don't have actual images.
Thank you for posting.
Jul 07, 2011 | Acer Aspire T690 (AST690UP820A) PC...
Whilst driving along the electrics gradually cut out, starting with the radio, power steering,instrument panel then totally cuts out on a fiat seicento
check your battery cables make sure there tight and secure but what i think you will find is a fuseable link going from the battery to the wiring harness has blown and once you replace that!! then you need to find the component that cause it to blow which wil probably be the heater motor also check and make sure your alternator belt didnt fall off
Jan 20, 2010 | Fiat 124 Cars & Trucks
Mi copiadora sharp AR5125 tiene codigo U6
code Sub code U6 00 Content Desk communication trouble Detail Failed communication with desk Communication line test error occurs when power is turned on or after the exit of a simulation mode. Cause Improper connection or broken wire of connector or harness Desk control PWB defective Control PWB (PCU) defective Malfunction due to noise. Check and remedy Clear the trouble by turning the power supply On/Off. Check communication line connector and harness. U6 01 ~ 03 Content Desk 1, 2 and 3 CS lift-up trouble Detail Desk cassette lift-up trouble (1st - 3rd cassettes). Cause Defective sensor RADF control PWB defective Broken gear Lift-up motor defective Check and remedy Check lift-up sensor detection with SIM4-2
Nov 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
Purchased Sharper Image Model S1481 desk lamp and it stopped
you can go for LED retrofit w/ this one on amazon:
http://www.amazon.com/--1134-Lumens-Conversion-FML27W-Fluorescent/dp/B00J7Q4004/ref=sr_1_42?s=hi&ie=UTF8&qid=1402581740&sr=1-42
bypass the ballast & just connect LINE & NEUTRAL wires (from the ON/OFF switch) to the LED light
seth
Aug 09, 2009 | Kitchen Appliances - Others
Image on master is cut off
If you open the drum and inspect the master on the drum,do you get complete ink coverage on the image that is on the master.
Mar 16, 2009 | Office Equipment & Supplies
My element 19 inch flx-1910 tv will not power up
Element FLX-1910
Problem: When the TV is turned on a picture appears for a few seconds and then the picture turns off. Audio is still heard.
Solution: Not a simple fix! This TV has 4 small florescent looking bulbs that act like a back light to light the image on the liquid crystal display (LCD). At least one of these bulbs is burned out or broken. The wires powering the broken bulb need to be cut and spiced together. Basically you’re bypassing the bulb and completing the circuit when cutting the wires going to the bulb on each end and splicing them together.
WARNING: This worked for me but no guarantee for anyone who tries it. This is a very involved procedure and involves completely dismantling your television. To be honest I don’t recommend anyone trying to fix it unless you are very technically minded and have a couple of hours to waste carefully tearing apart your TV. If anyone is willing to attempt this repair I am willing answer questions.
Cause of problem: It is my guess that this problem occurs when the TV is left on for extended periods of time. Like leaving the TV on when you fall asleep at night. My TV was left on a lot. I noticed that the plastic was melted and discolored where the bulb had burned out. (This can only be seen internally and is no way visible from the exterior)
Jan 20, 2008 | Televison & Video
HP Compaq nx9030 Notebook Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
