Question about Dell Inspiron 530 Desktop Computer
Monitor- My screen display went from vertical to horizontal! How do I get it back to vertical??
  • Dell Master
  • 32,281 Answers
If you mean your display went from landscape to portrait or vise versa then -
UPSIDE DOWN DISPLAY This is caused by unintentional pressing Ctrl-Alt plus the down arrow key.
Restore by pressing Ctrl-Alt plus the up arrow key.
ALSO
To change the display from portrait to landscape
Press Ctrl-Alt plus a left or right arrow key.
Posted on Sep 09, 2010
Get rid of "Out Of Range" message on e218c1 monitor.
The device driving the monitor is exceeding the horizontal and vertical frequencies that the monitor can display .....thus the "out of range". The specs for this state that the Horizontal Freq. is 80Khz and the Vertical Rate is 75hz. If you are driving this monitor from a computer running Windows, reboot the PC and use the F8 key to put it in SAFE mode. This will cause the video driver to default to a rate that the monitor can handle. Then go into the screen resolution settings and reset them. The native resolution of the monitor is 1680x1050 at 60 Hz. Exceed that and you'll get the "out of range"
Sep 10, 2014 | Envision Peripherals 22"" envision e218c1...
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
How do you adjust the vertical and horizontal of the image on your screen?
Press the OSD (On Screen Display) button on the face of the monitor. You'll find controls to control the size & position both horizontally & vertically.
Jun 01, 2010 | Dell E773C 17" CRT Monitor
LG 700B SHAPE SIZE AND POSITION UPSET PLEASE HELP TO RESTORE
Push the button on the Monitor to activate the OSD (On Screen Display). With the OSD, one can "stretch" the picture (horizontally/vertically) and "move" the picture (horizontally/vertically) in order to "fill" the viewable area with your compueter's output.
May 09, 2010 | LG Flatron F700B 17" CRT Monitor
Top screen has horizontal and vertical lines
The only solution is to replace this top screen.
Buy.com has the top screen for $20 Bucks!
Search Top Screen Replacement Display on there.. Hopes this helps.
Apr 14, 2009 | Nintendo DS Lite Console
Monitor is vertical display instead of horizontal display
the keys ctrl+alt+right arrow should do the trick for you. if not then right click on the keyboard and select properties for options and you will find your graphics software has its own rotational software. good luck with two year old, sounds like you'll need it.
Feb 25, 2009 | Dell Computers & Internet
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Kogi L9ch 19 in flat monitor
(I posted the latest post.) Change the resolution. (Mine was 1024 by 768, so I changed it first to 800 by 600 and then back to 1024 by 768, and it's back to normal!)
Hope that helps.
Feb 13, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Monitor displays vertically
If you mean that your screen display became narrower, then there are usually buttons on the screen to fix this, among other adjustments of the screen. the setting you're looking for has a two way arrow going horizontally through the middle of an icon representing the screen. In case i'm misunderstanding your problem, or this does not help, you can also try to let the screen rest for a while(at least 30 minutes), and turn it back on, to allow it to degauss. Good luck
Mar 13, 2006 | HP A4033A 20 in. CRT Monitor
Dell Inspiron 530 Desktop Computer   Logo
69 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
