Question about Mitsubishi WD-52725 52". Rear Projection HDTV
TV was working fine when we went to bed Monday (August 30) night. Got up the next morning and turned it on. It appeared it was going to come on, the green light flashed and then the lamp indicator light just went red. Per the owner's manual, this means the lamp needs to be replaced. We have had to replace the lamp two other times since we purchased the TV in 2006. However, the last two times we had to replace it, the lamp light started with a flashing yellow light and then eventually days later went to red. We purchased a new lamp and put it in. Still does not work. Purchased another new lamp and put it in thinking possibly the first bulb we purchased was defective. The TV still does not come on. The light starts flashing green as if the TV is going to come on, you can hear the fan going and then the lamp light goes red and the fan shuts down again. HELP!
    Sergeant:
  • 259 Answers
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A
Posted on Sep 14, 2010
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
Lg50pc1d purple screen
try to unplug the set for a period of time?
Mar 12, 2012 | LG Televison & Video
Bought strada 1.2 new in 2006 Problems: 1.Drivers seat replaced 2009; new seat broken again 2.Clutch replaced on 35 000km. 3. Rev counter replaced after three attempts to...
think you had a friday night monday morning one ,some of the problems are of your own making though ,clutch?? drivers seat broke twice ,how much do you weigh ?? do you like a big mac ?' ,water pump ?? and it went a month later was it fitted correctly first time ,wiring problem with fuel injection was it damaged when changing water pump by taking engine mounting off and jacking up engine ?? .but some of the other problems are not of your making though like the speedo or radiator ,just a friday night monday morning car and i see them on all makes ,try a seat next time ,lot better build quality
Sep 04, 2010 | Fiat Strada Cars & Trucks
Samsung PS50C91HDX Sound but no picture
It sounds like the main board or screen may have gone
Sep 26, 2009 | Samsung 50 in. Plasma TV
TV will not come on.
check to see if the power cord is pluged in firmly
Dec 17, 2008 | Sylvania 6427GFG 27" TV
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Changes Channels
Need to know model number and date of manu.  You may have bad control assy due to spills or cleaning of screen and liquid went into screen and buttons. will effect remote also
www.classtorations.com
Jun 03, 2008 | RCA P52937 52" Rear Projection Television
Vizio vp50
Maybe the scart has gone or it is not in properly hope this helps..
Jan 22, 2008 | Vizio P4 46 in. HD-Ready Plasma Television
APEX TV problems
need flyback transformer #030531-5283
Nov 05, 2006 | Apex Digital GB5108 51" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
294 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
