Question about Candy CPDA241 Top Freezer Refrigerator
The fridge tries to start but after 5 seconds it stops.
  • Candy Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 08, 2010
Samsung srl38nmb
We found that the problem was the sensor that regulates the evaporator flap. Replace that and it should cure the problem. Each light represents a certain sensor in the fridge, if that sensor isn't working, the according light will flash. If you go to a Samsung agent, they will be able to assist you.
Nov 13, 2013 | Refrigerators
Westinghouse fridge turns it self off to defrost is this normal
If your second hand fridge is over 5 years old, then it might be time to buy a new one. Most fridges nowadays have a lifespan of 5-8 years the most. Danni
Jan 10, 2013 | Refrigerators
Our fridges problem is that when we started the fridge after 3-4 mins the fridge stopped working its on standby but the cooler/fans stops working.
I am trying to understand your refrigerators problem. Has it been cooling normally before this happens? Do you hear any clicking? Also what model is your Samsung? The model number should be around the fresh food section door frame. Are you saying the the refrigerator tries to start but the fans also turn off after the first 4 seconds?
Thanks Sea Breeze
Nov 30, 2012 | Refrigerators
Maytag fridge stops cooling, then 1-2 days later restarts on own
The buzzing is typically gonna be the compressor trying to start and failing. Am I right in saying the fridge is at least 12 or more years old?
Maytag used to use a compressor made by Tecumseh and they had a problem with starting. They would buzz and sometimes start back up. Sometimes in a few tries or a few days or never. It would continue to re try every couple minutes and last 5-10 seconds.
I would verify if it is a Tecumseh or an Embraco compressor then make your decision.
A service tech should be able to figure this out pretty easily! Normally what I would do is if I go in and it is running then I would turn it off and back on right away. the fridge will go through its restart sequence and typically make its noises then. Hopefully you are not being charged every time they come out
Compressors are the most expensive repair! and on these I always replace the discharge tube since they tend to rot out from sitting in the drain pan.
Let us know what you find!
Feb 21, 2018 | Maytag MFD2561HE Bottom Freezer French...
Motor goes on/off every few second.
You have problem with the motor compressor,it is trying to start, but cannot for one reason or another, could be siezed motor, sticking start relay.etc'
It is stopping and starting due to the motor overload device cutting in and out. it acts as a safety device.
This is usually associated with a serious malfunction..Plz rate my solution.
Thanks.
Dec 28, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge not cooling contents
YOU DIDN'T STATE WHAT MAKE YOUR UNIT IS, HOWEVER IT SOUNDS LIKE IT IS THE OVERLOAD COMPONET THAT MOUNTS ON THE COMPRERSSOR TO START IT. TRY THAT FIRST IT IS THE MOST COMMON.
Dec 02, 2008 | Refrigerators
Fridge stopped working suddenly
Sounds like the relay (start device) on the compressor has failed.  This is a very common problem especially for models that are 3-5 yrs old.  I would replace that first.
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Candy CPDA241 Top Freezer Refrigerator Logo
145 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
