Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
My freezer and refrig are not staying cold, the freezer is defrosting and ice is forming on the back of the freezer.
  • Kenmore Master
  • 43,501 Answers
Many times a freezer and/or refrigerator
do not work right because of a dirty condenser coil...there are also many other
things that can go wrong.
Posted on Sep 08, 2010
    Filmmaker:
    Uploaded 5 video answers.
  • 11 Answers
I\'ve been struggling trying to keep our 2 goldens dog hair from the coils of our 8 year old Kenmore side by side with "W" compressor coils, but like everyone else was unable to clean past the first set of coils.
I came up with this solution that worked to get much of the big stuff, hair and bunnies, off of the further back coils. Not perfect but much better than nothing.
Removing the back lower panel I was able to snake a crevice attachment from our vacuum down the right side of the coils (left side looking from back)
Looking from front"
I made a compressed air contraption to blow the dust/hair across the coils using a compressed air nozzle that I added a 10" long tube and a 90 degree deflector
From the front of the fridge, on the left side of the coils, I snaked the compressed air nozzle towards the back and started directing the air stream blowing towards the vacuum crevice tool at the opposite side of the coils.
The compressed air dislodged the hair/dust enough that the vacuum was able to suck it away. Again, not perfectly but certainly much better than I was able to clean the coils in the past.
I suppose you could use a can of compressed air and add some sort of deflector if you don\'t have a compressor.
I then got to thinking how to prevent the dust from accumulating on the coils, I\'m going to try an air conditioner filter. I cut it slightly oversized to fit the front opening then split it in half to make it thinner for more air My freezer and refrig are - 7a2fbc41-ef6b-4a4c-8961-a892df9da8ab.jpgfixya.net/uploads/images/7a2fbc41-ef6b-4a4c-8961-a892df9da8ab.jpg" alt="7a2fbc41-My freezer and refrig are - 938facae-8d39-4f2b-b07c-82f5e4219751.jpgh_mi" /> 938facae-8d39-4f2b-b07c-82f5e4219751.jpg
Picture taken before making the filter thinner.
For years I had my calendar remind me monthly to vacuum the coils but now hopefully I\'ll be able to simply change the air filter.
Posted on Feb 01, 2014
Clean the condenser coils under the frig. Use a vacuum to suck off dust from the first bank of coils. A thin brush or compressed air blast (with back panel removed and frig rolled out into the room) can be used to get dust off condenser heat transfer banks behind the first bank. These \'banks\' are arranged in waves under this frig. The face of the first wave is all that a vacuum can reach, which is why a fine brush that can reach between the metal heat transfer rods or compressed air are needed.
Posted on Jul 02, 2013
My fridge and freezer stopped cooling, what could be the problem?
First check the back wall of the freezer to see if there is frost build up. If it is frosted over, check defrost system for failure
Aug 19, 2015 | Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
MSD2650KES SIDE BY SIDE REFRIGERATOR - BACK OF FREEZER ICED OVER AND REFRIG NOT STAYING COLD. DEFROSTED FREEZER, WORKED FOR A WEEK OR TWO NOW THE SAME THING...HELP
either the defrost heater located next to the evaporator core is burned out or the defrost timer unit is defective in the refrige compartment controls area or the defrost thermostat on or near the evaporator coil in the freezer is defective
Jun 08, 2010 | Maytag MZD2766GES Side by Side...
My GE Adora side by side refrig. has stopped making ice and I am having a hard time regulating the settings on it. The freezer is too cold and the refrig. section isn't cold enough. I also have noticed...
Defroster circuit/timer has failed.
The water line to the icemaker has probably frozen,so no ice. The cooling coils are in the freezer, and the cold air moves to the fridge via vents and circulation fan.
When it all ices up, no air gets to fridge, fridge gets warm.
Many models have a mechanical defroster timer located under the lower front kick panel. Manually rotate the timer until you hear the compressor stop.
Defroster heater then should come on and you hear scorch/hiss/gurgle of defrost sounds. If the timer is working, the fridge should come back on after about a half hour or so.
Sometimes timer fails, sometimes heater element fails. There is also a defrost thermostat that's part of the heater assembly.
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 23, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Unit gets cold when turned on then slowly gets warmer and then does not cool at all
Most probably defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Frigidaire Refrigerators
Warm
If you need freon you can't do it yourself
Could be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 23, 2009 | GE Refrigerators
Our freezer and fridge or not keeping cold enough
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor or back of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator isn't very cold- drinks are just slightly chilled
Usually caused by failure of defrost system, Air ports from freezer to fridge blocked by ice
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 23, 2009 | Whirlpool Refrigerators
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
290 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
