Question about Kenwood KDC-V7017 CD Player
Faceplate opens to remove the faceplate but there is no display?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
You probably have a bad flexible cable (goes from the face to the main motherboard). unless you are good at desoldering and soldering, you may want to have it done by a professional.
Posted on Sep 09, 2010
Will not turn on without removing faceplate and putting it back in
Try cleaning the contacts behind the face and on the sub panel behind the face with either q-tips and rubbing alcohol or a pencil eraser. If you use a pencil eraser, make sure you brush off the debris.
Jan 22, 2013 | Car Audio & Video
I need the security code of my car radio I removed the battery now it need a code which I don't know Kenwood PDX500M serial number 31104056 please.
For this fix you need to reconnect your battery.
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc
Dec 19, 2012 | Cars & Trucks
I have a Sony CDX-GT310 FM/AM Compact Disc Player with detachable faceplate. The unit still plays fine, but the display on the faceplate quit working. I've tried resetting the unit as well as cutting...
check the connectors between the faceplate and the unit carfully they can get damaged with constant removing/refitting if not the faceplate and/or unit is faulty
Dec 09, 2017 | Sony CDX-GT310 CD Player
Display doesn't illuminate on flipdown faceplate
Has unit gotten very cold lately? If faceplate is removable, remove it and clean the brass terminals with a CLEAN pencil eraser, wiking sure to blow off any rubber "crumbs" when finished.
Mar 10, 2009 | Car Audio & Video
Pioneer deq 7600 display went black today the eq works fine.
the faceplate contacts may need to be cleaned. remove the faceplate, and using an eraser, clean the metal tabs on the main unit and rear of the faceplate.
If this doesnt remedy the problem, service is required. May be the light unit in the faceplate.
Dec 22, 2008 | Car Audio & Video
Display issues with Aiwa CDC X207
I had the same problem. There are two small light bulbs that illuminate the digital display, and they are burned out.
You can easily replace them. The Aiwa part number for them is 8Z-KT1-641-010. The bulb is made by Sony, and the Sony part number is U0087654U.
I purchased them from Union Electronic Distributors:
https://www.ued.net/ued/addItems.do?itemCode=SNYU0087654U
Note that the product is not an item they keep in stock, so it may take 1-2 weeks or more before you receive them. Be patient.
Here are the steps to replace the bulbs. You will need a small (#1) Phillips screwdriver and a soldering iron (low heat). A very small flat blade screwdriver (1/8") will also be helpful.
1) Remove the faceplate from the radio and bring it to a well-lit work table.
2) Remove the four Phillips screws on the back on the faceplate.
3) Carefully separate the back half of the faceplate cover from the front half. There are three locking tabs along the top, and three locking tabs along the bottom. I used the small flat blade screwdriver to separate the two halves.
4) Once the back half of the faceplate has been removed, re-install two of the Phillips screws to hold the circuit board in place (one screw on each end). You don't need to screw them down tightly; just screw them in until you begin to feel them stop. These screws will keep the circuit board from separating from the front faceplate and causing the buttons to fall out!
5) Locate the two bulbs. They are labeled PL 901 and PL 902 (may also be labeled PL 1 and PL 2). Carefully unsolder the bulbs and remove them from the circuit board. You may want to do one at a time.
6) Each bulb has a colored cover to change the color of the light (I jokingly refer to them as 'bulb condoms'). Remove the covers and carefully slide them in place on the new bulbs. You may want to slightly dampen the bulbs to aid in sliding the covers on. Be sure to slide them all the way down.
7) Solder the new bulbs in place. They are not polarity sensitive.
8) Trim off the excess wires.
9) If you installed the two screws in Step 4, remove them.
10) Carefully re-attach the rear faceplate cover to the front faceplate cover, making sure that all six locking tabs snap in place.
11) Put the four Phillips screws in the rear faceplate and carefully tighten them.
That's it! Now, put the faceplate back on the radio, turn it on, and enjoy your lighted display!
Hope this helps.
Ron
Dec 13, 2008 | Aiwa CDC-X204 CD Player
Kenwood KDC-X717 - Facplate opens when powered on, stays open. No display.
I've had this problem before. The ribbon cable needs to be replaced. They wear out every few years. Take it in for service. Or do you want to sell it? I need the face plate for mine.
Nov 06, 2008 | Kenwood KDC-X717 CD Player
Kenwood KRC -X858 Faceplate/Power Problem
I have the exact same problem. I called the tech line and the tech reported that the ribbon cable is probably broke. It is the flex cable between the head unit and the rotating face plate. He said it's not an expensive fix but we would need to mail it to a service center if you're like me and not near one. I just replaced mine with a new unit. It was about time anyways.
Apr 26, 2008 | Kenwood KRC-X858 Cassette Player
Putting on faceplate for samsung t319
hi you best bet is go to a repair mobile shop if are in doubt to try this .
you'll need a small Philips head screwdriver to complete the installation. To take off original faceplate, remove 2 screws located below the inside display (screws are hidden under stickers). Next, gently pry off the faceplate along the edges between faceplate and phone with a Faceplate Removal Pry Tool. When re-attaching screws, do not over-tighten screws
riz.
Aug 23, 2007 | Nokia 6288 Cellular Phone
Kenwood KDC-V7017 CD Player Logo
83 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
