Question about Olympus WS-100 Digital Voice Recorder
I deleted the recording in the device through pc and it started malfunctioning. i tried to reset the device and format the file inside but all it says is format error.
    Genius:
  • 1,218 Answers
Deleting the file is not the problem but if you tried to format the recorder from the PC then you have a problem ...try to reformat again when not connected to PC. If youv'e lost the manual you can get one at www.olympusamerica.com they are under "support."
Posted on Sep 10, 2010
I'm using a Sony ICD-BM1 w. 32Meg memory stick. When I connect it to the computer (Win 7 PC) & start the Sony Digital Voice Editor 3.3.01, the recorded file disappears from the memory stick. The...
Welcome to Fixya
As part of the test. Try to copy files (pictures) to the device and see if the device were able to save the file. If not then try to format the device. Please take note that formatting the device will delete everything. see procedure below:
1. press menu 2. using the jog lever, select format 3. press enter 4. use jog lever and select yes 5. press enter -> Ok? -> press enter 6. formatting will be displayed on the screen. press menu after formatting the device and test the issue.
Thank you for using Fixya!
Jun 08, 2011 | Sony ICD-BM1 Handheld Digital Voice...
I've deleted all my files. But when I try to record something new it says "memory full".
Try to format the memory, if the device support formatting function, use this tools. But if there aren't any formatting tools, you can format your memory card via PC.
Put off your memory card and format it (you sure there is no file anymore, do you?).
After formatting complete, put in your memory card in your recorder again.
I hope you can record something again.
Hope this help and if you feel helped RATE please.
Jan 23, 2011 | Olympus WS-110 Digital Voice Recorder
How do I delete the recordings on the vr5220 digital voice recorder? Step by step
To erase files or bookmarks, while playback is stopped:
1. Press x once.
2. Press '<< / >>' to select one of the erasing options:
  • Delete the current file (DEL 01)
  • Delete all files in the current folder (DEL AL)
  • Format the memory of the player (FORMAT) (Caution! All data inside the memory will be erased)
  • Delete all bookmarks in the current file (DEL BK)
3. With one of the above options selected, press and hold x for about 3 seconds to confirm your selection and start the deletion.
  • File numbers that come after erased one will be moved forward by one automatically.
  • Press to cancel erasing all files. The undeleted files are saved automatically.
  • Formatting the internal memory may be required when encountering compatibility problem, etc.
  • You may also format the player when connected to a PC (by right-clicking on the player's drive name or letter and select "Format" from the menu). Make sure you select FAT or FAT32 as the file system.
Jan 02, 2011 | RCA VR5220 Digital Voice Recorder
Can you recover deleted files from the Olympus Recorder VN-4100PC? also, one of my files is unable to play. any way of recovering it?
YES, it is definitely possible to recover such kind of files deleted from your Olympus recorder.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your recorder to a PC with a recovery program installed. Photo Recovery Software (also recover Voice memos, audio and video files) is right what you need to use if you are running Windows. If you are Mac OS X users, turn to Data Recovery for Mac.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. I hope this will help. Best regards!
Sep 01, 2010 | Olympus VN-4100PC Digital Voice Recorder
I deleted my audio files directly from the computer. Now that I try to record again, the device says that memory is full, even though I have no files on it. How do I reset it to record again?
To erase a selected file, first press the [ERASE] button. Next, press the [+] (plus) or [-] (minus) button to select "ERASE," and then press the [ERASE] or [OK] button.
To erase all files in a folder, first select the folder and press the [ERASE] button for three seconds or longer. Next, press the [+] (plus) or [-] (minus) button to select "ALL ERASE." Finally, press the [ERASE] or [OK] button.
NOTE:
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended. Individual files can be deleted using the computer with no negative effects.
Feb 05, 2010 | Olympus WS-321M Digital Voice Recorder
The Olympus DS-330 read only memory lock
You may need to format the recorder to clean the file system on the recorder. Follow the directions below to format: If you format the recorder, all function settings will return to their defaults*. All files** stored in the recorder will be deleted. If you have important files that you want to save, connect the recorder to a computer and transfer those files from the recorder to the computer before formatting the device. * Date and time settings won't be cleared, so you won't need to set them again. ** Locked files will also be deleted. 1 Press and hold the FOLDER/MENU button for 1 second or longer. The menu opens. 2 Press the up or down arrows button to choose "FORMAT". 3 Press the REC/SET button again. 4 Press the FF or REW to choose "START". 5 Press the REC/SET button. Formatting starts. "FORMAT DONE" displays when formatting ends.
Jun 11, 2009 | Olympus DS-330 Digital Voice Recorder
I get a "full" message but it is not full
Try this:
4 Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
May 28, 2008 | Olympus WS-100 Digital Voice Recorder
File format error - Transcend T.sonic 610(1gb)
I had the same problem. I had formatted the player's drive using Windows explorer and the got this error: "File Format error" while trying to play any mp3 file.
I went to the command prompt. Deleted all files:
E:\> del *
Then I copied the MP3 files again in the T.sonic MP3 player. All MP3 files played fine after this.
Jan 29, 2008 | Transcend T.sonic 612 MP3 Player
Recorder says "PLEASE DOWNLOAD FILES," but there are no files to download
The DS-2 has a format option in the menu under submenu. After you choose start you will see a progress bar and it should return to full record time. Use on a MAC seems to cause the reduced record time more often than on a PC.
Dec 11, 2007 | Olympus DS-2 Digital Voice Recorder
Mp3 player
if it is not accesible as a device in my computer, there should be within the players menu a factory or default reset or format command,or a reset pin hole on the side, this should return to factory settings
May 02, 2007 | Kbyte K-BYTE MP3 S320 MODEL 128MB HOLIDAY...
Olympus WS-100 Digital Voice Recorder Logo
251 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
