Question about E-Machines T6532 PC Desktop
I believe my video card has failed. The monitor says "No Signal". I would like to purchase a new video card for this computer. Not sure what video card would work or fit. Any information would be appreciated.
    Sergeant:
  • 172 Answers
This computer has 1x PCIe slot. you can buy any PCIe video card
you can buy video card like this one
Posted on Sep 09, 2010
Acer monitor no signal
If your monitor has various input sources, make sure it's on the correct input source in the main/input menu. If that's not the problem double check the cable for bent pins also make sure if you have a video card with DUAL dvi outputs that your using the correct one.. as the other one might be secondary and non-functional. It's possible but highly unlikely if you unplugged the DVI cable while the monitored was still powered on it could have damaged the video card of the computer or mainboard of the LCD monitor. When in doubt try another DVI cable if all else fails.. if you have another DVI monitor (thats a known good) try that also to make sure that the video card is not the problem.
Nov 05, 2013 | Acer H243H Monitor
When i on my desktop it show blue screen and says no signal analog
That means that the monitor is not getting a signal from the computer. There are several possible issues involved. 1) Make sure that the computer tower is on. 2) Check that the video cable is connected to the active port on the desktop. (Computers often have video connections on the motherboard and an added video card. The motherboard connection is disabled when the video card is active. Similarly if there are several ports (VGA, DVI, HDMI, Display port) only one may be active.) 3) Try a new video cable (if possible) and one of the other video ports (again if possible). 4) Try connecting a different monitor to the computer or connecting this monitor to another computer.
Open up the computer and check if the card requires a separate power connection to the power supply. Make sure it is plugged in. Do the fans in the computer spin up?
If a second monitor doesn't work or the monitor works on another computer, then the problem is with the video adapter on the computer, the power supply or the power switch. Please add a comment with more information about the type of desktop and the current video graphics adapter (on the motherboard or separate card). I will provide additional help if possible.
(who has a computer in the company that needed a new monitor (power supply failed) a few months ago and lost the fan on the video card last week. Without the fan, the card overheated and shut down. Thus no signal to the monitor.)
Oct 02, 2011 | Computers & Internet
My e machine monitor says no signal detected when the computer is on? what could be the problem and how do I troubleshoot it?
Youhave to understand that the monitor is telling you that it is not receiving a signal from your computer connection. check the connecting cable to be sure itis tight, try another cable. if that fails then the Videocard in the computer may have come loose or corroision on the fingers that connect down in the mother board. take the video card out and scrub the fingers with alcohol, and replace. if that does not work, then the video card has failed.
Jan 06, 2011 | E-Machines eMachines Monitor E15T4
Well i wanted to know whats wrong with my computer i dont know if im missing some cables but it says no signal.
It says no signal can be that the video card is not putting out video signal to the monitor, you need another monitor to verify that or you can try reseating the video card if it is not the integrated video card in the mother board. It can be the VGA cable itself. Try thsi monitor with other PC to make sure it is not the monitor problem.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 10, 2010 | Proview PL913B 19" Flat Panel LCD Monitor
EMachine T6522 monitor says "no signal input" when turned on. tower switch light on and motor seems to be running. Nothing but above message on monitor. Checked both ends of cable and unplugged tower and...
This could be an issue of a video card gone bad. I have experienced the same issue firsthand. This could also mean that no RAM is installed. If you have been using this computer previously, the second option is probably not even an option.
If you have another computer available, please try plugging the monitor in to that machine to test. If it works, your Video Card is more than likely toast.
But not to worry, you should be able to find a new card for that machine. I believe it will be a PCI Video Card, which may run you anywhere from $20-$100 depending on what you purchase. Please consult with eMachines before ordering a new card. Some will not work with your machine.
I hope this helps you out. Have a great day and please don't hesitate to ask any further questions regarding this issue.
Feb 26, 2010 | eMachines Computers & Internet
Lg crt monitor no dsplay
Video card may be done or monitor is. Connect another monitor to computer and power up computer to see if it works. If so, monitor is done. Did monitor give a no signal message when it's on and computer isn't? If it did and now won't monitor probably bad. If no monitor will work on your computer, either computer is fried somehow or video card failed. Make sure your computer is booting correctly and not stopping after the POST before Windows starts. See that it's booting up and accessing hard drive but making no picture. If so, new video card or monitor. Start by connecting another monitor to your computer.
Jan 30, 2010 | LG Flatron F700P 17" CRT Monitor
My video connection does not work monitor says "no signal." I checked all connetions and they's properly connected.
Check to make sure you have correct ram installed in motherboard as the video card may share that ram. Check CPU that it's installed correctly and video should work. If not then the motherboard is bad.
Jun 01, 2009 | Asrock P4I45GV R5 Motherboard
No Video Signal
Try resetting the bios. On the motherboard there is a battery that looks like a watch battery. Remove the battery, then replace it again. (make sure the computer is unplugged from the wall socket when you do this)
Does this work?
Oct 24, 2008 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
When i turn monitor on it comes up with vga input no input signal
Hi nobumsteers,
This is most often caused by your VGA cable becoming detached from either the back of your computer or it's connection to the back of the monitor. First, check by unplugging both connections and re-attaching them firmly back into both ends.
If it still displays the no input signal error, then most likely your computer's video card is not transmitting signal to the monitor. So we need to make sure that the video card is working.
If your blue connection in the back of the computer is located near all of the rest of the cables (very close proximity, less than 1 inch apart) then you are using an 'on-board' video card. If you purchase a new video card and place it in one of your lower, available PCI or PCI-Express card slots in your computer and connect your VGA cable to that, you should have video again. But this would be a solution to a defective on-board video card, which if it is still under a warranty should be repaired by your Manufacturer.
Hope that helps.
May 03, 2008 | Computers & Internet
E-Machines T6532 PC Desktop Logo
172 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
