Question about Lucent PARTNER18 Corded Phone
How do I change a display name on the Lucent 6408D+
Phone display needs a reset
How do I change the names that are asigned to certain extenions??
Jun 11, 2012 | Lucent PARTNER18 Corded Phone
Lucent Partner phone speed dial
At ext 10 or 11, press feature 00
then feature and 600 or whatever code you want
then enter the number as you would dial it.
when done, enter feature 00 to get out of programming.
May 10, 2010 | Avaya Lucent Partner 616 Phone
Lucent 6408D phone - calls go right into voicemail. Won't let me answer.
PHONE IS EITHER FORWARDED OR IN DO NOT DISTURB MODE TRY TO FIND A MANUAL TO TURN OFF FEATURE
Nov 06, 2009 | Lands Phones
Need to change Voice Mail Time
We need to know which Lucent and which voicemail system you have. When you dial into voicemail, what does the nice lady say? Welcome to......?????
Jun 01, 2009 | Lucent DSLPipe Bridge/Router
Changing name on display
You have a Definity system, unfortunately, these are very high end systems, and you will need to contact your system administrator as it needs to be changed via the computer that runs your system.
Apr 16, 2009 | Avaya Definity 6408D Corded Phone
How do i change the name on the phone
This should be what your looking for..
From an individual extension with a Display Phone:
  1. Press [ Feature ] [ 0 ] [ 0 ]
  2. Press [ Left Intercom ] one time. The display reads: Enter Name (If a name was previously assigned to this extension, it displays instead.)
  3. Enter the two-digit code for each character you want to enter. (See Valid Entries below)
    For example, to enter the name Andy, press [ 2 ] [ 1 ] [ 6 ] [ 2 ] [ 3 ] [ 1 ] [ 9 ] [ 3 ] . The display reads: 12 ANDY
  4. If you make a mistake, you can press [ Mic ] to clear the display. Repeat Step 3 to enter the correct name.
  5. Press [ Feature ] [ 0 ] [ 0 ] to exit programming mode.
Valid Entires:
Letters A-Z, numbers 0-9, and blank spaces.
Character and Digit Codes:
Letters: Numbers:
A=21 N=62 0=00
B=22 O=63 1=10
C=23 P=71 2=20
D=31 Q=72 3=30
E=32 R=73 4=40
F=33 S=74 5=50
G=41 T=81 6=60
H=42 U=82 7=70
I=43 V=83 8=80
J=51 W=91 9=90
K=52 X=92 BLANK = 11
L=53 Y=93
M=61 Z=94
Mar 10, 2009 | Lucent PARTNER18 Corded Phone
Lucent MLX-20L Extension Edit
http://dstech1.com/changing-the-name-on-an-extension/
A label can have a maximum of seven characters.
To administer Labels for Extensions from the System Programming console:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit or Start.
  4. Press More or Right Arrow Key.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  8. Dial the extension number that you want to administer.
  9. Press Enter.
  10. Press Drop.
  11. Enter the label information for the extension number selected.
  12. Press Enter.
  13. Press Exit or Back.
  14. Press Home or Exit to exit programming mode.
Note: When programming on the system programming console, use the buttons next to the display to specify the letters A through I and punctuation. Use the line/feature buttons to specify additional alphanumeric characters for labels. Use the template provided with the System Programming console to see which line buttons correspond to which alphanumeric characters,
Dec 22, 2008 | Lucent Merlin Legend MLX-10D Phone
Can you help me?
Well, you are heading down the wrong road. To change the Auto Attendant message:
Dial Intercom 777
When prompted for the mailbox and password:
Mailbox "0" followed by the # sign
"1234" followed by the # sign
option 3 will allow you to change the recording.
To change the display names on an extension:
AT EXT. 10 OR 11:
Press "feature 00"
Press the LEFT intercom button twice
Press the RIGHT intercom button and the display will say "Extension program" enter extension you want to program
Enter the valid intercom name(see table below)
file?id=dgs6spp6_5ctm7dcfn_bIf you make a mistake, press mic/hfai to start over
feature 00, when you are done.
Jul 22, 2008 | Lucent PARTNER18 Corded Phone
Change time on phone
Phone system console. Contact your system admin, as it depends on exactly which system you have.
Jun 11, 2008 | Avaya Definity 6408D Corded Phone
Changing the display
In your system support room - - you will have two computers set up for your phone system - maybe (at least that's how it's set up here).
One is for the voicemail system and one is for the phone display, essentially.
You will log in to that other station and when you get the command prompt type
change station xxx (where xxx is the extension of the phone display you wish to change).
Sep 13, 2007 | Avaya Definity 6408D Corded Phone
Lucent PARTNER18 Corded Phone Logo
801 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
