Question about Cross Royal® Heavy Duty -Cut Paper Shredder
Royal 1200mx confetti cut shredder : wont turn on plug is in perfectly
Makes grinding noise and does not pull the paper in or shred. I have pulled out all bits of paper stuck between the teeth. I'm afraid this thing is toast
This type of shredder can get clogged so badly, the material has to be removed with a utility knife. This is especially true if someone has tried to shred coated stock or, worse yet, credit cards. The noise you are hearing is the mechanism bouncing over clumps of residue jammed in-between the grinding "teeth".
Apr 18, 2015 | Royal 1200MX 12 Sheet Strip Cut Paper...
Does it make a difference which shredder oil I use? There are so many. I have a Tech Solutions cross cut TS8000.
You can use any kind of shredder oil. They are all priced so differently, I use fellows brand for my royal shredder & it works just fine.
Feb 07, 2011 | Fellowes WilsonJones Q4 Paper Shredder Oil...
Royal Shredder 1200MX model Motor is running but not rotating blades to engage cutting fed paper
If the motor is running but the cutting blades are not turning then you have likely lost a gear/ or the teeth off a gear inside. You will have to open it up to find out which gear/gears are broken then you can contact Royal at 1-800-524-0799 for parts pricing and assistance.
Dec 29, 2010 | Office Equipment & Supplies
If its dead...no lights, nothing, then the pcb inside has probably gone. Give Royal a call at 1-800-524-0799 for parts and prices.
Sep 07, 2010 | Royal Office Equipment & Supplies
I have a nice Royal confetti cut shredder that will go in reverse but barely tries to start when in 'auto'. Can this be repaired ?or am I better of to pitch and buy another.
Try lubricating the machine first...put some shredder oil on a piece of paper and shred it...do this a number of times to get the oil down into the ctting shafts.
Jun 10, 2010 | Royal Office Equipment & Supplies
Royal confetti shredder perforates paper but does not shred it.
You may have lost a bearing, try contacting Royal at 1-800-524-0799 to see if parts are available.
Jun 09, 2010 | Royal CC70 Shredder
I have a 10X confetti paper shredder model # PCUA 29054E. When I put the paper in it shredds spuratically. It will shred then stop then continue then stop completely. If I back it up it might continue but...
Lubricate the machine....put shredder oil onto a sheet of paper and shred it...do this a number of times to get the oil down into the cutting blades... x-cut shredders should be oiled regularly.
Mar 18, 2010 | Royal Office Equipment & Supplies
Royal 10X confetti shredder
More than likely, there is a lot of paper debris jammed between the cutters and strippers. If you are handy, try the following.
Disconnect the power.
Disassemble the shredder from the lower bin to access the cutting head. Clear the head of all debris with a small screw driver or ice pick. Reassemble and oil the cutters with shredder oil, being careful not to get any oil on the optics. This should solve the sluggish problem. Oil on a regular basis, before every use.
Jan 06, 2009 | Royal 10X Shredder
My shredder requires about an hour of cool down every time it shreds a load.
do spry lub down in the cutter shoot like WD40. If not do it. If you do there may be a billed up of paper dust in the machine it is a catch 20,22
Oct 24, 2008 | Royal VF-1200MX Shredder
Cross Royal® Heavy Duty -Cut Paper Shredder Logo
35 people viewed this question
Top Cross Office Equipment & Supplies Experts
Computer Links
Ivan
Ivan
Level 1 Expert
k24674
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
