Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
I have a Troy-Built Series 550 mower with a Briggs & Stratton engine. I cannot find the drain plug. Is there a good diagram available?
  • 183 Answers
Most professional shops no longer drain the oil through a drain plug because of all the covers under the engine. With your Briggs and Stratton engine, the best way is to drain through the dipstick. You can purchase a suction device to **** out the oil, or you can drain it. To drain, place you mower on the tailgate of your truck, or on the picnic table. Grab a drain bucket, remove the dipstick and tilt the handle to the ground. The spark plug should be pointed straight up into the air. Might be a good idea to do a test run before removing the dipstick, so you will know exactly where to hold the bucket. All 20 ounces of oil will drain through the dipstick in about a minute if the engine has been warmed up. Refill with a good quality SAE HD30 weight motor oil. Remember...only 20 ounces. Check the oil level after filling before you start the engine.
Good luck.
Posted on Sep 08, 2010
You have to tip the mower sideways and the drain plug is above the blades on the underside of engine. It's easiest to use a 3/8 drive ratchet with an extension to loosen the drain plug that typically has a 3/8 square recessed hole.
Wiring diagram for a 250cc 11.50 briggs and stratton engine on a troy built wood chipper
http://www.briggsandstratton.com/us/en/support/faqs/horizontal-shaft-replacement-engine-specifications
Jul 11, 2014 | Parks Optical 13.5hp Briggs And Stratton...
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Oil plug location
there is a drain plug on the bottom of the engine near the crank but it is faster to turn the mower on its side and drain it from the dip stick hole
Apr 01, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Briggs and Stratton Troy Built 21inch 190cc 650 series Gas Powered self propelled Lawn Mower. I moved to new house and the movers lost the manual. I bought it last year so only one seasons use. How do I...
If how you described you unit is true you do not have an electric mower you have a gas powered mower, you DO NOT have a battery!!!??? Place the throttle lever to choke position and prime carb with primer bulb 3-5 times then pull cord. Wala!!!! It's running rite. That guy at Loews must have been smokin somthin. Good Luck...
Apr 22, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Cannot find drain to change oil.
Poulon 550 yellow 22" Briggs and Stratton. It looks like you have to drain it out the cap by tipping it. There IS no plug on mine - spent 40 minutes looking for one, and I know what both types of the plug look like. What a lousy design. This mower is a piece of junk. The valve froze a week after I got it. Never again. A headache.
Dec 13, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
603 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
