Question about Fedders A6Q10F2B Q Chassis Room Air Conditioner
My window unit comes on but will not blow any air at all.
    Master:
    Sergeant:
  • 449 Answers
If you can open the unit you might find a reset button onthe compressor if you dont have a reset you are gong to have to replace unit
Posted on Sep 08, 2010
Can the freon be refilled in window units?
A refill needs to be done by a technician who has the gauges to refill it.
Jun 23, 2015 | Heating & Cooling
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
A/c unit not blowing cold air
is the compressor coming on ? this is a window unit so you should hear the compressor come on is any air coming out
Jul 19, 2011 | Heating & Cooling
Unit blows cool air out but doesn't cool room off. the compressor is not coming on. had freon checked ok
I have a question, how was the freon checked if the compressor is not coming on. If the compressor is not coming on, make sure it is received the proper voltage, if it has a capacitor make sure the capacitor is good. Also, how clean are the coils on the unit?
Apr 22, 2011 | Frigidaire FAS256R2A Thru-Wall/Window Air...
Whirlpool window unit a/c power comes on but no air comes out
sounds like a bad fan motor or capacitor. mostlikely covered by your warranty
Aug 21, 2009 | Whirlpool ACQ158XP Wall/Window Air...
The electricity went off this morning and now the air conditioner is blowing warm air and I don't hear the compressor coming on its a whirlpool window unit Thank You
turn the unit off for 5-10 mins. turn thermostat to coldest setting then turn unit back on. see if the compressor kicks on in a minute . it may need to reset itself.
Jul 30, 2009 | Whirlpool Heating & Cooling
Window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Jun 07, 2009 | Whirlpool ACQ189XM Air Conditioner
Hot air coming out of back
portable air conditioners mainly have two hoses one hose is exhaust thats the one that is blowing hot air. the one pulling is return.. the hot air blowing out should be exhausted to the outside. the blowing air needs a hose and to be laid out a window the back should have model and serial maybe product number. the two holes are either 4 inch or three inch and most portable units other than hand me downs come with a window frame that allows the hot exchanged air to go outside and cooler air to be used for heat exchange.
May 28, 2009 | Maytag NMPEB08F2A Air Conditioner
Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Fedders A6Q10F2B Q Chassis Room Air Conditioner Logo
100 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
