All lights up but as soon as i press the start buttom its trips the sockets out
  • 3,287 Answers
I assume "trips the sockets out" means that the fuse or circuit breaker that supplies the power to the washer opens or moves to the "trip" position. I'll also assume it worked fine while plugged into this outlet before, too.
This indicates a "direct short circuit" or a very low resistance short circuit, and is potentially dangerous to people and property. Do NOT attempt to reset the circuit breaker or replace the fuse to try it again. This appliance requires a professional repairman to locate and repair the problem before you should attempt to use it again.
Be safe & good luck!
Posted on Sep 08, 2010
  • Steve Sep 08, 2010
    An additional thought... in the U.S., washers are supposed to be installed on dedicated, separate 20 amp / 120 volt circuit (that has no other outlets on it). Most washers will use nearly the entire capacity of a 20 amp circuit - so if there is another appliance on the same circuit, the combination of the two appliances will cause the circuit to fail (fuse blows or circuit breaker trips). Make sure that the ampacity of the circuit is matched to the fuse size (not bigger or smaller), and that IF the washer shares its circuit with other devices - those devices are OFF. If thelatter is the case, try to start the washer again after ensuring that everything else on the circuit is off or unplugged. You'll need an electrician to add a new / break up existing circuits so you can operate the washer as desired.
Indesit is70c
its a saftey device, called a "thermodisk". It's purpose is to turn off the heating coil or stop gas flow in the event of over heating. If the thermodisk is bad, trying to over ride it (trying to get it to run) will trip the breaker. Its about 10 bucks and easy to replace.
Dec 31, 2013 | Dryers
Tip
Pontiac service light 1983-01
Firebird
1998-01
To reset the "CHANGE OIL" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and goes out, the system is reset.
Grand Am
1999 -01
To reset the Change Oil light, open the driver's side instrument fuse panel and turn the ignition on. Press the "RESET" button and release. The light will flash. Press the button again and the system will be reset.
Grand Prix
1999-01
Driver Information Center If Equipped). Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the ignition key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on, repeat the procedure. To reset the OIL LIFE indictor if equipped with a Trip Computer: Press the trip MODE button until the light appears next to OIL LIFE. Press and hold the trip RESET button until the oil life percentage changes to be 99 percent.
Grand Prix
1997-98
To reset the oil life indicator, press the "MODE" button until the light next to "OIL LIFE" is lit. Press and hold "RESET" for 3 seconds until oil life percentage is 100%.
Grand Prix SE
1997
Turn the ignition on, but do not start the vehicle. Within 5 seconds, push the accelerator to the floor 3 times. Turn the ignition off. Start the car and the Change Oil Soon indicator light will be reset.
Grand Prix
w/ Trip Computer
1988-93
To reset "CHANGE OIL", "CHANGE OIL FILTER", or the mileage of either on the Trip Compute, continually press the "SERVICE" or "SYSTEMS CHECK" button until the item appears with the mileage below it. Then press the "RESET" button and the mileage will be reset to the maximum value. If you want to reduce this value, hold the "RESET" button down and the mileage will count down. Release the button at the mileage you would like to observe.
Bonneville,
6000
w/ Driver Information Center
1983-91
To reset "CHANGE OIL SOON" or "OIL FILTER" or to adjust the mileage on the Driver Information Center, continually press the "DIC" button until either message appears with the mileage below it. At this point, hold down the button. In 5 to 10 seconds, the mileage will count down. When it passes 0, it will cycle back to a maximum figure. Release the button when the mileage gets to the service interval you'd like to observe. If "CHANGE OIL" or "OIL FILTER" already appears, just hold the button down to reset the mileage. "CHANGE OIL" and "OIL FILTER" are reset separately.
on Dec 07, 2009 | Pontiac Grand Prix Cars & Trucks
Technics sl qd33
tone arm could need cleaning never done it personally but if you take it to a stereo shop they should b able to help you
Sep 19, 2013 | Audio Players & Recorders
How do I reset "Maint
First open your ingintion and make sure dash reads odometer, then close ignition press and hold trip-odometer buttom open ignition odometer read out will show --------------- flashing lines wait until they dissapear and odometer reading is back 69487 or else then release buttom reset is done.
Jan 13, 2011 | 2002 Toyota Camry
How do I reset the change oil light after changing the oil. It did not go out.
Try this and if it does not work let me know.
1. Turn the ignition key to the "ON" position without starting the engine.
2. Fully press and release the accelerator pedal three times within five seconds.
3. If the CHANGE OIL SOON indicator flashes two times, or the display reads "OIL LIFE INDEX RESETTING 100%" then the system is resetting.
4. Turn the ignition key to "OFF", and then start the vehicle.
5. If the CHANGE OIL SOON indicator comes on and stays on, or CHANGE OIL SOON is displayed then the system did not reset and repeat the procedure.
1. To reset the OIL LIFE indictor if equipped with a Trip Computer, press the TRIP MODE button until the light appears next to OIL LIFE.
2. Press and hold the trip RESET button until the oil life percentage changes to 99%.
Sep 14, 2010 | 2001 Pontiac Grand Am SE
I started a wash cycle, needed to add more laundry, press the pause/cancel buttom twice, now I can't start it again. When I press the start buttom everything goes blank, all lights go off
Remove the power plug and keep aside. Keep the sart button pressed on to discharge. After 15 minutes switch on the washer while holding the pause/cancel button.
If the set does not come back to life it iis possible that the main board has encountered some errors.
Repeat the procedure after some time.
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Program Optoma EP-739 remote to Bell Express Vue 3100 remote
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Feb 23, 2009 | Optoma EP739 Multimedia Projector
Remote codes
5-Press record
Jan 03, 2009 | Bell SH50102 Remote Control
Bell express vu remote codes for soyo tv
5-Press record
Jan 02, 2009 | Soyo Crystal DYLT032B 32 in. LCD...
1999 Pontiac Grand Prix lights are staying on
what is the procedure you are using can you explain it to me?
Resetting Procedure
To reset the CHANGE OIL SOON indicator if equipped with the Driver Information Center (DIC).
  1. Turn the ignition to ON without starting the engine.
    • If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the ignition key to OFF then start the vehicle.
    • If the CHANGE OIL SOON indicator comes on and stays on, repeat the procedure.
To reset the OIL LIFE indicator if equipped with a Trip Computer.
  1. Press the trip MODE button until the light appears next to OIL LIFE.
  2. Press and hold the trip RESET button until the oil life percentage changes to 100%.
Hope this helps Ill look into the ABS lights but I do believe that you will need a scan tool to retreive a code to be able to diagnose the reason for the lights
Sep 18, 2008 | 1999 Pontiac Grand Prix
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
