Question about Hunter Dryers
Celling fan lights is blinking like a strob light. What could br causing this?
  • 3,287 Answers
This caused by a loose connection. Try the light without having the fan on. If it stops blinking, that would confirm it. If there is only one bulb - it could be a loose filament or a loose connection on the lighting circuit portion of the fan. If there are multiple bulbs and all blink - it is not a filament problem but rather a loose connection in the light portion of the fan. It is a quick fix for an electrician - but may be difficult for a DIYer if unfamiliar with wiring and electricity.
There is always the chance that it is something else - wall switch, or other connection in the wiring of the house - but I'm pretty sure the problem will be found in the fixture itself.
Posted on Sep 08, 2010
I HAVE A BEKO CELLING AC, THE "DRAIN" GREEN LIGHT BLINKS, THE OUTPUT AIR IS NOT COOL JUST NORMAL AIR.
Sounds like the float switch is tripped. You need to vacuum drain line with a shop vac. Your outdoor unit must not be running.
Jun 09, 2017 | Heating & Cooling
1993 del Sol Si 1.6L right F & R turn signals won't blink - front lights up and bulbs good - brake/backup lights fine - no relay under dash, bought one still nothing, left side both work
If the rear turn signal lights are out, and the front lights are ok but don't blink then, the bad bulbs in the rear turn signals should need to be replaced.
Or there could be a bad ground connection.
Also, there may be two relays for front and back lights.
Hope this helps.
Apr 13, 2015 | Honda Civic Cars & Trucks
Dont know where to put the Celling PINK, GREY, RED and YELLOW WIRE. obviosly the electrical connection, Can you give me any tips ??
red of fan==neutral white main line
pink of fan =pin # 2 of fan speed switch
yellow of fan= pin # 3 of fan speed switch
Mar 05, 2015 | Hunter 52" Ceiling Fan With Light And...
My minkaAire/Delano11 will not turn on. The green light is now blue. What does this mean
OKAY I HAVE A POSSIBLE SOLUTION! THERE SHOULD BE A GREEN LIGHT AT THE TOP OF THE REMOTE AND A BLUE LIGHT AT THE BOTTOM. YOU NEED TO TURN OFF THE BOTTOM SWITCH, WHERE THE BLUE LIGHT IS, FOR 5 SECONDS THEN BACK ON. THEN HOLD THE CENTER STOP BUTTON FOR 5 SECONDS AS WELL. THIS WILL ALLOW FAN AND REMOTE TO RESYNCHRONIZE, IF BLUE AND GREEN LIGHTS BLINK TWICE THEN U HAVE SUCCESSFULLY RESET BOTH FAN AND REMOTE. IF THIS DOESN'T WORK CALL MINKA AIRE TECH SUPPORT 1-800-221-7977. GOOD LUCK!
Nov 19, 2013 | Minka Aire Ceiling Fan
MY HP 60 235DX WILL NOT TURN ON. I TOOK BATTERY OUT AND HELD DOWN POWER BUTTON, PLUGGED IT BACK IN AND IT STILL WILL NOT WORK. NO POWER LIGHT WHEN THE POWER CORD IS PLUGGED IN. BUT WHEN I DO PLUG IN...
fan turns? hear it and feel it.blow.? in must.
cd drive ejects? (button)
no text ever on the screen? this is first. all else more complex.
do the flash light trick?
http://www.pcdied.com/monitors.html#flashlighttest
no beeps
no flashing caps lock key (codes) if yes, what code.
step one is get BIOS and its screens working
even using and external VGA monitor will help.
and the magic Fn+F4 key to turn that on.
hp is down this morning...(support pages)
the G60 series uses a CCFL lamp, that blows out (easy)
or its inverter.
if external monitor works, and flashlight trick works
CCFL back lamps are dead.
Aug 23, 2017 | HP G60-235DX Notebook
I just installed a hunter 70" fan model #23285.
Not really a solution but .. try this.. Don't use the fan lights as primary lighting. Install low wattage bulbs in the fan to reduce the shadow depth, and use alternate primary lighting, for example a Torchier style floor lamp.
You realize of course that it did not show in the store because it was surrounded by alternate light sources, eliminating the shadows.
Nov 28, 2010 | Hunter Ceiling Fans Individual...
Can't initialize @ start up lights strob and display reads c 1?
after you turn on, can you make copies, does the unit creates any grinding noise, please let me know.
Jan 17, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Dryers Logo
935 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
