Question about MSI RG54G2 Router (MS-6848-002)
Hi there,.. my problem is; i can connect wireless
Hi there,.. my problem is; i can connect wireless with all my devices to my router. My router gives ip adresses using DHCP. The problem is that i cannot connect via my router thru my cable modem. This modem is made for one device only. If i plug my pc direct into the cablemodem my pc receive a public ip adres and i can use the internet. with the same public ip adres i change the UTP cables and as long i do not use ipconfig /release / renew everything works with the cable of course. But there is no way that i can get on the internet with a 192.168.1.xxx adres. What should i do, specify a gateway, DNS. I already tried resetting my modem to factory defaults but nothing happend. I also tried restoring the settings but no success either. Any suggestions?? Greetings Omar
Hi, good afternoon! i am facing problem with my wireless connection. how can i connect on it? can you assist me?
Are you getting an error when you try to connect?
If you were able to connect w/ the same device before, unplug any other device that uses radio signal such as cordless phones.
Unplug your wireless router for 1 minute and plug it back in. Wait for another 2 minutes and connect again.
Aug 02, 2011 | Siemens Efficient Networks SpeedStream...
GdayI am trying to connect my PSP via WRT160N without success, any suggestions please?? Thanks
I see that you are having difficulties connecting your PS to your wireless Router, Inorder for your PSP to get connected to your Router wirelessly make sure that your remove your Network Key from the Router this will let cell phones and other mobile devices connect to your Router without any errors, to protect your Network having a disable security you can enable MAC Address filtering in your router this should let you get your PS and other mobile devices connect to your Router and at the same time give security to your personal Network.
Mar 23, 2011 | Linksys WRT160N Wireless Router
What is the difference between an adapter and router?
Hi
A router is a device that normally will be connected to the modem which gets the internet connection from the modem & gives out a wireless signal.
An adapter is a device that will be connected to the computer. This is a wireless receiver which receives the wireless signal from the wireless router & connectes to internet.
Dec 27, 2010 | NetGear Computers & Internet
WRT54G2 wired desktop fine, can't connect to wireless.
Hi Seth6025,
Try without using Wireless Encryption (password).
Try changing channels; default is 6; try 1 or 11.
Change your SSID: personalize it
SSID broadcast: Enable
Check the advanced wireless settings and make sure MAC filtering - DISABLED.
Reset the Linksys router by pressing RESET for 30 seconds should everything fails and re-configure. Firmware is another consideration BUT this is just a new release.
Regards,
Angel
Jul 08, 2010 | Linksys WRT54G2 Wireless Router
I just got a belkin wireless router and i have my computer my playstation 3 and one psp connected up to it and i am trying to connect up another psp but it keeps timeing out i was just wondering how many...
Hi! all wireless routers can connect up to 30 to 50 wireless device. If your computer, your play station3 and the other psp is not timing out.. there is a possibility that there is a problem on the wireless capability of the other psp that ur having a problem.. check the wireless settings of your other psp and match it with the other psp that is giving u a problem. check also the wireless settings of your router, there are some router that you can connect only specifi device by assigning the mac address of the device that u want to connect to the wireless network..
Aug 17, 2009 | Belkin (F5D7231-4) Wireless Router
Hi. just got cable internet (Comcast) and am
that's normal, wireless is normally between 1/4 and 1/2 the speed of your wired connection. normally the router gives priority to wired devices, but this should not cause you any further slow down unless you have wired devices plugged in at the same time you are using wireless. this can be changed from your router's admin page.
Aug 14, 2009 | Arris SURFboard SBG900 Wireless Router...
Can i use Bluetooth USB Adapter to connect PC to wireless router?I purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't...
Hi, to connect your computer to the wireless network of the router you need to have a wireless adapter. The bluetooth adapter will not work in this case as the router does not communicate with the bluetooth signals.
Purchase a wireless adapter like NETGEAR WG111
Rate it, if it helps.
Regards
Anand
Aug 03, 2009 | Computers & Internet
Wireless internet on laptop
You need an external WIRELESS ROUTER or MODEM ( provided by AT&T ). After this AT&T router configuration you needs to do configuration at your laptop using CONNECTION SETUP wizard for Wireless Networks & Devices.
Then you can set IP addresses & then you will be connected to it. I hope above steps will help you.
Rate the solution if it was helpful to you...
With Regrards,
Shyny
May 28, 2009 | Gateway M305CRV Notebook
Belkin wireless problem
If you are connected straight from the modem, your router will not have internet access, only if your modem is connected to the router you will be able to go online wireless. connect your modem to the router nad router to the desktop, so that you can access both wired and wireless connection
Aug 12, 2008 | Belkin (F5D9230-4) Wireless Router...
Linxsys wireless modem
Is it working if a computer is wired to the router?
Jun 09, 2008 | Linksys Wireless-G WRT54G Router
MSI RG54G2 Router (MS-6848-002) Logo
37 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
