Question about Refrigerators
How to remove temperature sensors on model GE PSS25MGNAWW
  • Refrigerators Master
  • 3,083 Answers
This site has exploded diagrams of your model:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5100044
This person on justanswer.com tells where the sensor is, and perhaps with the previous diagrams, you can locate it:
ok thanks ... XXX problem will be the temp sensor inside the freezer behine the back inside panel on the coil and the part number is XXXXXXXXXX and cost about $8 and you can get it at a local appliance parts dealer near you / thanks Hope this helps, good luck, and thanks for using FixYa.
Posted on Sep 08, 2010
My ge refrigerator model pss25mgnaww motherboard is bad is it a recall on it
WR55X10942 is the part # of the board and from what I can gather on
Line, it is under recall. Call GE and mention recall of that board and see what they say.
Sep 08, 2017 | GE Refrigerators
Is there a recall on the motherboard of ge profile artica model pss25mgnaww
From what I see online, there seems to be. Call GE and mention recall of part # WR55X10942 and see what they say
Ge stove oven get a f4 fault
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.What is the model number?
Nov 08, 2012 | GE Stove/Range/Oven Oven Control -...
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 | GE Freezers
JS968SF4SS model gives 'F2' error. Possible
F-2 usually oven sensor shorted or bad. Replace oven sensor an you should be good to go. Hope this helps.
Feb 13, 2010 | GE Ovens
Oven shuts off and F2 appears in digital display area. Have followed manual's suggestion of shutting off power but it hasn't corrected the problem.
F2 is a bad temperature sensor inside the oven.
Turn off the circuit breaker to the oven.
Remove the oven racks.
Locate the temperature sensor in the top rear of the oven. Remove the mounting screws and pull it out of the hole.
Unplug the sensor and replace it with a new sensor.
If there is no appliance parts store in your town you can order from www.appliancepartspros.com .
Go to this site and enter your model number then click on the temperature sensor.
Jan 24, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE Model PSS25MGNAWW Artica Profile Refridgerator has begun freezing the contents of the bottom Sealed Pan and Fresh Produce Drawers. Put setting up to 2 and Chill Dial to Cold (left) but temp is stayng...
Freezing in cripsersG.E artica:
Models Affected: All 23 25 27 and 29 cubic foot electronic side-by-side refrigerator units with plastic Liners manufactured in 2001 or later. This includes all Profile- (Arctica and Eterna") models Consumers have called with reports of freezing in the Vegetable (middle) pan or the CustomCool M (bottom) pan , frozen water tank or frozen water filter.Freezing in the pans , a frozen water tank or a frozen water filter is caused by excessive airflow from the vents in the tower.
To eliminate these freezing issues , install kit WR49X10045. Follow the instructions included in the kit.
Damper door broken G.E artica:
Affects all 2001 models produced with "M" as the eight letters in the model i.e.: PSS25SGM with serial date code LA4 , MA4 , RA4 , SA4 , TA4 , VA4 , ZA4 & AD4. Freezing happens when damper door breaks leaving the unit with no control over the very cold air entering fresh food compartment from the freezer.
Replace damper door assy , with new damper door kit WR17X11508.
To verify the damper door is broken , remove the light shield and rear light bulb from the top of the refrigerator. Enter the factory diagnostic mode by pushing all four temperature control buttons at the same time. Perform damper motor test (FZ 1 , FF 0). Press any other button i.e. Custom cool or filter reset to start damper test cycle. Shine flashlight through right hand side opening of light assembly to view movement of damper door. To exit test mode (FZ 1 , FF 6). lf damper door assembly needs to be replaced , pull top two shelves out 2 ". Pull rear tower assembly slightly forward with both hands, move to the left and the right to expose the two screws that secure the duct assembly , also remove both screws that secure the duct to the ceiling. Replace with new damper motor assembly WR17X11508.
Dec 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge pss25mgnaww the refrigerator does not cool or freeze
You have a main control board problem . Pt # WR55X10656 . You can replace the board , or , remove the board , and on the backside , you can visibly see where a solder joint has become "unsoldered" . Resolder this one spot and reinstall the board . The board is located on the back of the fridge , behind an 8 X 10 panel . Be sure to disconnect power before attempting this .
Aug 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
F3 code on GE
ok here is the result to searching GE the answer to thew code.
Please rate our help to keep this free service online
Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Aug 28, 2009 | GE JVM1430 Microwave Oven
Getting a f2 code on GE oven model JKP13
Control senses oven temperature above 615F-630F (F-2)
If actual oven temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Jun 13, 2009 | GE Profile JTP18 Electric Single Oven
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
