Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Listen, I don't want to pay for it...... I have an horizontal colored line in the middle of the screen
  • 57 Answers
If it's still under warranty, call the manufacturer & they will repair or replace it..
Posted on Sep 08, 2010
  • suzanne_sue4 Sep 09, 2010
    This is not the kind of TV I have, the one I have is a Toshiba cx28613 TV 1992, so it is sure it doen't help.....thanks anyway. Suzanne
My philips 240b powervision tv, about 10 years old, while watching, all of a sudden the screen video turned into slanting horizontal whilte lines. the input is from setup box. I guess it happened when i...
Slanting horizontal lines indicate that the horizontal hold is out of adjustment. As the components age they change values and don't have the same effect on the circuit. some units have a horizontal hold adjustment pot on the back that can be adjusted to bring the horizontal back to the middle. If the adjustment pot is not on the back the only way to bring the horizontal hold back is on the inside of the unit and this is not a safe proceedure. If the picture was really good before it went bad then it might be worth the cost of repair. If the picture was getting weak (light colors, washed out look) then the repairs are not cost effective (not worth the money to have the unit repaired) There are some tv repair people that work quite a bit cheaper than others. It would be worth a few phone calls to get an estimate and make an informed purchasing decision.
May 01, 2011 | Televison & Video
When i turn it on it has an horizontal blue line in middle of screen then comes on, when shut down it has the colors in the middle in tight formation then suts off. is it the picture tube
the set having blue scteen when the nosignal condition so blue horizontal line due to failure in vertical deflection section and system control detect the vertical delection failure . so system control farce to set to shut down pls repair the vertical section and system should be ok
Aug 26, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
Red/Orange horizontal lines
it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
Jul 27, 2009 | Akai PT5492S 54" Rear Projection...
Picture screen
Hello! You have vertical collapse. There are bad solder connections at the vertical output IC. I have repaired MANY panasonic tv's like this. Very easy to repair if you have any soldering experience. If soldering does not fix the problem you need to replace the vertical IC. Good luck
barneyluc
Oct 06, 2008 | Televison & Video
Black screen with colorful line going horizontally through the middle of the screen
Problem in the vertical circuitry.
If you have the know-how, check for "cold-solder" joints around vertical i.c.
Also, bad electrolytic caps.
Voltages ok?
Resistor values ok?
Replace I.C.
Don't tell me the yoke wires were off or gnawed thru by a roach!
Aug 07, 2008 | Toshiba 32A33 32" TV
Blank screen with a line across the middle
thats the VERTICAL OUTPUT IC that went bad , needs to be replaced . hope this helps
Apr 30, 2008 | Jensen 5" Color TV 5 in. Portable...
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
26 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
Steve
Martin Murray
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
