Question about Kohler Home
I am trying to get replacement plug for my kohler ceramic sink. Is this possible?
  • 22 Answers
Call 1-866-405-1933 for Kholer sinks
Posted on Sep 11, 2010
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
May 12, 2016 | Kohler Model 10433: Fort® Single-control...
How do I replace a hose diverter in a single handle Kohler kitchen sink?
Yes, contact Kohler and they have a site you can watch that should be helpful.
Jan 11, 2013 | Kohler Home
Kohler parts - plumber told me the ceramic ring in the faucet is broken- and that's why it is dripping. I am trying to piece out parts to fix myself on Kohler diagram - what is the ceramic ring called?...
hi, just had a quick look and the part you would have to source would be :78125 spline adapter. this is shown here...... http://www.us.kohler.com/onlinecatalog/pdf/1146603_2.pdf the taps are washerless ceramic valves and pretty good quality, are they still covered under warranty as i would imagine that part is not cheap.
Jan 14, 2011 | Kohler Fort© Widespread Lavatory Faucet...
Will Kohler Disposal Flange K-11352 work with Kohler Sink K-5924?
Kohler makes their sinks standard, and most all sinks are the same size hole, yes it will fit.
May 22, 2010 | Kohler Plumbing
Crack in farm house undermount sink Kohler
Possible you could use an epoxy or J B Weld to repair it. I have fixed a couple of gas tanks with JB weld it should work on Cast also . It not to expensive and may be a start for you.
May 02, 2010 | Kohler Nice Cast Iron Kitchen Sink
Misaligned lever on Kohler kitchen faucet
There are two possible things to look at.
Because you say "misaligned" and "frozen" it could be the handle is not set to the correct position.
There is a set screw holding the handle in place. It is a hex key I believe on that tap. Loosen the set screw and lift the handle off. move to the correct neutral position and set the screw.
If this does not do it and you are getting nothing but hot. The ceramic ball and washers could be stuck or broken. While the handle is off remove and inspect them. They should move freely in the socket. Replace or repair if necessary. Just take them to a plumbing store they are common parts.
Hope this helps. Please rate the answer if it helped you.
Mar 10, 2010 | Kohler Model 15160L: Coralais®...
Trying to find basket strainer for Kohler vast
all of kohlers baskets fit their sinks, even older model sinks.
do you have a special strainer, or sink?
have you contacted Kohler direct? or one of their distributors. a wholesale plumbing supply house (NOT lowes or home depot) in your area will be able to help you also
Oct 15, 2009 | Kohler Plumbing
Replacing the ceramic valve in the handle, how do you remove it?
it has a screw down cap on top of the valve.counterclock wise.then pull straight up on valve. if you twist the supply line while doing this disconnect the line first then work on valve.
Jun 30, 2009 | Kohler K-10270-4A-G Forte Centerset...
Black Sink - white haze
A lot of the soaps and things that we put into our sinks can cause tiny scratches into the glaze. That's what is causing the "haze" you are describing. It's not something that can be lifted off but might be buffed out. I would recommend contacting Kohler and asking if the sink can be buffed successfully. They may be able to give you some contact numbers of people that can repair the sink if it can be. I wish I could offer some more advice but you might be heading towards a replacement instead. Good luck to you!
Apr 02, 2009 | Kohler Deerfield Smart Divide undercounter...
Home Logo
120 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
