Question about Konica Minolta Office Equipment & Supplies
My Konica 7020 printer is stuck in the copy mode I can't switch to print - when I press the print button it beeps but nothing happens - the light doesn't switch to print.
  • tim2453 Sep 08, 2010
    to clarify I just purchased this used unit from a classifieds ad, and have never used one before. On the keypad there is three buttons, printer, fax and copy it seems to be stuck on copy. I tried to hook it up to my computer to print a document, it seems that I am supposed to be able to press the print button to switch to printing mode, however it won't switch from copy mode. It photocopies well, so the scanner seems to be working, I just want to be able to print with it.
    Thanks
    President:
  • 1,961 Answers
That is a mechanical error better check first the mechanism of your printer such as paper tray,print head,gears and motors..good luck pls do rate my help by clicking the thumbs up button
Posted on Sep 09, 2010
  • 17,970 Answers
Any previous MODE STORED; for this and other wrogns, as far as possible, parts of the system might still be available, even when an electronic problem occurs. In this case, corresponding information will be displayed, prompting you to isolate the faulty component by pressing AUTO RESET. After this, switch the unit off and on; and copying will again be possible.
To check the Function Modes in your user guide, visit this link.
Tell us news.
Posted on Sep 08, 2010
How to reset code 35-3 on photocopier konica 7020
DO THIS once because you are re-setting the FUSER it can catch on fire that will ruin a perfectly good day!!!!! Get a tech out to look at it.
Turn on the main and sub power switches.
Keep pressing the * button until the message
"Please enter service password." appears.
Input 9272 as the password and press the
[Start] key. (The password is fixed and cannot
be changed.)
[Mode Select Menu Screen]
Press 2 and 5 to select 25 mode. Then select soft switch. Set 3, then set 1 then change 1 to 0. to clear the code.
Jun 13, 2014 | Konica Minolta Konica 7020 W/fax Kit...
WHERE CAN I FIND A USAGE REPORT?
press the star button to print that info press print on that page
May 28, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
My Konica md#7020 copier does not power up to the "touch screen". When I turn on the main power switch the light indicating I am getting power goes on. However when I press the button to turn on...
After the sub power switch is turned on, the Konica name displays for approximately 10 seconds, until initial machine settings are established. Then, the Warm-Up Screen displays for approximately 6 minutes, until the ?xing temperature is reached. The Basic Screen displays after warm-up. Initial settings are shown on the next page. Except for Print Quantity, all initial settings can be changed by the Key Operator.
Jan 06, 2011 | Office Equipment & Supplies
Can't print to Konica 7030 via Parallel
You do not have the print/scan option installed on your copier. If you did you would have an ethernet port on the machine for network access and when you press the print/scan button on the control panel you would be able to access those functions. The fact that you can not means that the machine can not see that option because it is not installed. The parallel port is common and is used for uploading of firmware into the machine.
Thank You for using Fixya.
Apr 30, 2010 | Office Equipment & Supplies
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
Konica 7020 f34-4
need to rest code 25 mode dip switch 3-1 should be 0
hope that help
let me know if you need more help with access
Sep 01, 2008 | Office Equipment & Supplies
KONICA 7020 - Blank copy
I have never heard of a developer moving backwards!!!!!!!!!!!!!!!!???
the motor that runs it, the .... there is too much involved to mention. A developper moving backwards will spill so much toner in the machine anyway.
If you get a copy and then it goes blank, that tells me you have a problem with the SEPERATION UNIT, it may be shorting out causing the paper to rise against the drum giving you blank copies.
A blurr copy tells me there is a problem with the Scanner/Optics area. maybe the rails that the scanner run on are too dry or has a problem, the optics(mirrors) may be misaligned.
Not sure what you mean by (hanging) ??
Jul 31, 2008 | Office Equipment & Supplies
Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Jul 22, 2008 | Konica Minolta magicolor 2400 Laser...
Ink absober full
Service - mode in which you can perform service operations with the buttons printer. To switch the printer Canon MP-series in the “Service” mode you:
1) Turn off the printer.
2) Press and hold the button lifting / resume printing.
3) Press and hold the button printer.
4) Release the button lifting / resume printing.
5) Double-click restoration / print.
6) Release button printer.
after that time will be flashing green LED (flashing time depends on the printer model), then it will go steadily and the printer will become the “Service” mode.
Low-Level - work intended for low-level operations with EEPROM printer, in this mode MPTool works with the printer. To switch the printer MP-Series Low-Level regime should:
1) Turn off the printer on the network.
2) Press and hold the button.
3) Add a printer to a network.
4) Click lifting / resume printing.
5) Release button.
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
Jun 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Konica 4155 print shift
You need to enter a service mode. Holding down the "3" and "6" turn on .Enter "92" press copy button then press "P" when the copy quantity indicator flashes a number enter using the number keys a smaller or larger number.turn off then on.
Mar 17, 2008 | Office Equipment & Supplies
55 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
