Question about Dell Powerconnect 3024 Ethernet Switch (POWERCONNECT3024)
I've forgotten username and password for Dell Powerconnect 3024 Ethernet Switch.Pls give me the steps how to reset. I tried few steps but unable to follow. Below are those steps: 1. Connect to the switch via the console port and manually reboot the switch 2. As soon as power is applied, press and hold the key 3. At the command prompt, type "EmergencyPasswordReset" (case-sensitive without the quotation marks) 4. At the confirm (Y/N) prompt, type X 5. If done properly, you will receive a message stating that the password has been disabled 6. Type G and hit enter to reboot the switch I was stucked at after typing "EmergencyPasswordReset" its not asking for confirm, instead its giving an internal or external DOS COMMAND error. Pls reply to this ID : jasonysmith@gmail.com Thanks, Jason.
RSBennett
  • 54 Answers
SOURCE: fn key on dell inspiron 1501 keyboard not working
Sounds like your number lock is on. Find the key with blue lettering that says 'Num Lk' (or something very similar). Press Fn and that key, and your number lock will be turned off and your keys will go back to normal.
Hope this helps.
Posted on Mar 10, 2009
  • 24 Answers
SOURCE: Dell OptiPlex GX150 won't do anything.
on the motherboard there is a battery. it looks like a watch battery. there should be a jumper next to it with 3 prongs. move the jumper over to the next prong and start the computer.( it will start but will not come on). turn off the computer and put the jumper back to the first position. start the computer again and the bios will be reset
Posted on Mar 29, 2009
  • 126 Answers
SOURCE: remove a ACE from an ACL using CLI
Sure thing:
First to enable the web interface, try command:
ip http server
Also try:
ip http port 80
That will enable it on the default port
As for the ACL's I looked at the documention and I believe the syntax is to put a deny in front of the command and that will remove it.
Of course the GUI will be easier to deal with
The manual can be downloaded from:
http://support.dell.com/support/edocs/network/pc6024/en/index.htm
Posted on Jul 16, 2009
  • 32 Answers
SOURCE: Performance Issue
thats not a big diffrence if you use a 24 port switch or if you use 48 port switch actually switch is used to a number of connection not for a internet speed that is use for a networking if you want to upgrade your configuration then you upgrade your ram and our hard dives configuration
Posted on Sep 19, 2009
  • 153 Answers
SOURCE: I have a dell optiplex sx280 computer and monitor
How's the status light of your computer monitor? is it blinking amber? and the status light of your computer tower's power button? blinking amber as well or solid green or no light at all?
1. Disconnect all the connection at the back of your computer tower
2. Press the power button of the computer tower for 15 seconds
3. Reconnect the power button and the monitor cable at the back of your computer tower and turn on the computer (if it turned on that means that one of the device plugged at the back of your computer tower is faulty)
4. If still the same problem, open up your computer tower.
5. Reseat the video card, Reseat Hard drive, Reseat Memory, Reseat CPU, Reseat power cord coming from the CPU to your computer (doing all things one-by-one to pin-point the root cause of the issue)
If none of the troubleshooting steps fixed the problem, possible that the power supply is faulty and if the power supply is faulty sometimes it goes with the motherboard.
Posted on Jan 09, 2010
I forgot DELL INSPIRON N5110 ADMIN BIOS PASSWORD......HELP
I forgot my Dell laptop password,I use Windows Password Recovery Tool 3.0 to help me. It can help you reset forgotten or lost laptop password by creating a password reset disk with CD/DVD or USB flash drive. with this powerful Dell password cracker, you can Reset your forgotten laptop password with 3 simple steps: 1.Download 2. Burn 3. Reset
Step1: Download Windows Password Recovery Tool 3.0 in any PC.
Step 2: Burn a bootable CD/DVD/USB drive in a few seconds.
Step 3: Reset Windows password under Win PE within a few clicks.
I think it can also help you.You can get it and see the datail from http://www.windowspasswordsrecovery.com
Dec 12, 2012 | Dell Diamond Black 15.6" Inspiron N5110...
Linksys password recovery
Computer Hope does not assist users in bypassing this security measure. If this is your router and you've forgotten the username or password we suggest that the router be hard reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com.
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Dec 21, 2011 | Linksys Wireless-G WRT54G Router
Hi i've forgotten the password i set for my router about 18 months ago, so i can access wifi on my ipod touch, i've tried to reset and restore to factory settings using the button on the back,...
Since you reset the router, the username and password were set back to its default values as well. For Netgear, the username and password is: Username = admin Password = password
Aug 29, 2011 | NetGear WNR2000 Wireless Router
I cannot use my DELL Laptop because I forgot my password.
Hi, once you forgot your password and for no reason to recall it. Just press cntrl-alt-del keys simultaneously and log in using username=administrator and password is none. The default username of your computer if not altered is administrator. Once you successfully logged in you can edit your forgotten password in users properties.
Jun 21, 2011 | Dell Vostro 1500 Notebook
Fans are beginning to make a lot of noise. How to I clean and lubricate them or replace them?
only way to clean fans is to blow them out if you lube them oil will cause dust to cake up,if blowing out wont correct problem replacement best bet
Jan 27, 2011 | Dell Powerconnect 3024 Ethernet Switch...
In my dell powerconnect 2016 all leds are on and not blinking what can I do?
this has happened to me, leave it for a few days and try it, problem happens if it gets corrupt from power surdge it take the caps a long time to discharge around one of the ics with controlls how the ethernet chips work as there are 2 in this one.ic n.o c77331 is the problem leave of for a few days it will reset
Jul 15, 2009 | Dell PowerConnect 2016 (pct2016)...
Password reset for ATEN kvm switch
If you are unable to perform an Administrator login (because the Username and
Password information has become corrupted, or you have forgotten it, for
example), there is a procedure you can use to clear the login information.
To clear the login information do the following:
1. Power off the CN8000 and remove its housing.
2. Use a jumper cap to short the jumper on the mainboard labeled J6.
3. Power on the switch.
4. When the front panel LEDs flash, power off the switch.
5. Remove the jumper cap from J6.
6. Close the housing and power on the CN8000.
After you start back up, you can use the default Username and Password (Login: administrator, pass: password).
Dec 12, 2008 | Videk ATEN Master View 9834 KVM Switch
Computers & Internet Logo
401 people viewed this question
Alun Cox
