Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
How to remove top, and repair switch - Kenmore 3.2 cu. ft. Plus Top Load Washer
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16
Posted on Sep 08, 2010
How do I remove front panel on my mede200xw
Remove the top screws from rear, slide top back and up to remove,
You just exposed the screws in front top that fasten the control panel - remove thos and lift off control panel, now exposed are the top front panel screws, remove those and tilt panel out and pull up. Some have a few screws at bottom of front panel that have to be removed as well - also remember to disconnect the door switch wire harness.
RDU Appliance Repair Washing Machine and Dryer Repair
Jan 01, 2015 | Dryers
Parking lights dash lights plate lights not working
Check the fuses first, then if they are ok you may have a defective headlight switch, they connectors can get burned and the switch contacts as well this can cause the loss of lights like you have. Replace the headlight switch and connector as one repair, do not crimp connect the repair connector on, solder and shrink tube the solder joints. To remove the headlight switch for inspection follow these directions.
Remove two bolts under the radio and pull out that bezel
Remove four 9/32 bolts (or screws seen vehicles with bolts, some with phillips screws, some hex screws) on the very bottom of the panel by your knees (two hidden under the hood release handle)
Remove two bolts right behind the top seam of that panel under the steering wheel holding the top panel to the dash (you should be able to pull the steel panel by your knees down slightly to get to them, but you may need to remove or loosen yours, depends on if someone has had it off before)
Remove the three bolts holding the top cover inside the upper lip by the instrument cluster then you can remove the dash panel holding the switch
Sep 14, 2012 | 1997 Ford Explorer AWD
I need to change the door switch. I have the part. Should I take off the top or the front to change that part?
For the model dryer you have listed, the easiest way to access the door switch is to lift the top panel. The switch can then be removed and replaced by following these steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Remove defective switch and replace.
NOTE: Now would be a good time to do a routine inspection and cleaning of the interior dryer cabinet to ensure there's no lint build up.
Once repairs are completed, lower the top panel back in place and reinstall the two screws along the lint screen opening.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them.
If you have any questions about this repair, or if the model number is different, please post back and let me know. I hope this helps you.
Apr 26, 2011 | Roper RGX4634KQ Gas Dryer
GE washer will not spin or agitate. Belt is intact machine is a 2009 model #WJRE5550K1WW
replace the lid switch located under the switch as most likely a wire has broken off this switch and is usually not repairable,remove the front cover by using a putty knife near the top of the front cover to dislodge the clips,then remove front cover and the wires to the switch will be near the right side of the tub leading to the underside of the tub and you can then remove top cover to replace this switch
Apr 10, 2011 | Washing Machines
How do I repair A knob that is broken off at the stem of my ge profile flat top stove?
You cannot repair this switch, you will have to replace it.
You will need to remove the cook-top and remove the glass top to access the switches. There will be a series of screws around the underside of the lip of the glass top that attach it to the burner box. Remove all of the remaining knobs and lift the glass straight off the box.
I would get your model number and order the replacement switch before starting the process.
good luck!
Jun 16, 2010 | Kitchen Ranges
How do I remove and replace the on-off switch on hoover upright self propelled vac.
Greetings,
This is a relatively easy fix for you. What I've done for you is take pictures of this repair on your type of vacuum to make it as easy as possible. I will explain step by step what you need to do in order to fix the switch on your Hoover.
What you'll need to do this repair:
- Phillips head screwdriver
- Needle Nose Plyers
- Hoover Windtunnel Switch
Step 1. Turn the vacuum cleaner2_bing.gif so that the back is facing you. Remove the two screws at the top of the vacuum that are holding the handle on the machine. Please see the picture below of the two highlighted screws that need to be removed;
Step 2. After these two screws have been removed, simply slide the handle backwards, and remove it completely from the vacuum and set it aside. You now can see the on/off switch, but you can't easily change it from here, you'll need to complete several other steps before you may remove the switch. Here's what the vacuum should look like after removing the handle:
Step 3. After removing the handle from the vacuum, turn the machine around so the front of it is facing you. Open the bag housing and set the bag door aside. Also remove any attachments that are on-board in the tool storage bin, this model has a hand-held turbo brush stored here. After removing both of these parts, you'll need to unscrew 3 screws that holds the tool caddy onto the vacuum cleaner. I have circled the area where these 3 screws are located:
Step 4. After removing these three screws, pull the tool caddy off of the vacuum by pulling straight forward by using the tool caddy lid. You'll now have access to both the front and the back sides of the switch. Use your needle nose plyers to remove the two wires that are attached to the switch. Be careful when pulling these wires off because if you pull too hard, then it will break the switch terminal off inside of the wire. Most models have the wire that has a plastic covering over the end of it on the top, and the metal terminal is connected on the bottom. The two lead wires that need to be removed are highlighted:
Step 5. After the wires have been removed from the switch, turn the vacuum back around so that the back of the machine is facing you. Simply use your flat head screwdriver to pry the switch off. You may push on the front side of the switch where the wires connect to it in order to give a space so that you can get a screw driver behind it. Here's how it should look:
Step 6. Once the old switch has been removed, simply push the new switch into the open hole. Important: Make sure that the Off setting of the switch is at the bottom, and the part of the switch that says on is on the top, otherwise the switch will be reversed. Re-attach the wires to the switch, with the wire that has the plastic covering on top, and the metal wire terminal on the bottom. The only tricky part of reassembling is when you put the handle assembly back on the vacuum. As you can see, there is a metal cable below the switch. This metal cable controls the self-propelled mechanism. If you look at the handle assembly, you'll see where the self propelled cable sits inside. The easiest way to line these up is to pull the cable up to the top, and then line up the rod inside of the handle that the cable goes in, and slide the handle back on the vacuum.
I hope that this was helpful in fixing your Hoover Windtunnel switch. If you found this helpful, please be sure to rate the repair as helpful by clicking the Thumbs Up Icon in the top right hand corner of the repair. If you have any questions, or need some help on this repair, please just use the Clarification Request option here on Fixya, and I'll be happy to help you further.
Thanks so much,
Chris J.
GoVacuum
Feb 18, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Actuator on gas dryer snapped off
step by step is not easy on here, but if you remove the top, 2 diff types of units. you can get to the switch and replace the lever and switch with ease.
top filter type... remove 2 screws under filter, then pull forward on top then up almost at the same time.
front filter type.... remove control panel, hinge it back and remove 3 screws to remove the top.
then the same applies to remove the switch on both. 2 screws hold the switch to the front panel and either has a 2 or 3 wire plug on switch or will have 2 or 3 wires mounted right on the switch.
2 wire type, no drum light. 3 wire has drum light. if your wires are right on the switch, be sure to mark where the wires go before you remove the wires.
Dec 31, 2008 | Dryers
Kenmore C880 6587590 burner switch replacement.
I just replaced the switch just yesterday.First remove the glass panel by pushing back the 2 black clips at the top end,then remove 2 silver screws at the top and 3 at the bottom also remove 2 black screws behind side panels on the top. Now push side panels slightly up and forward and it fill fall forward and now replace the switch.
Feb 21, 2008 | Kitchen Ranges
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
