Question about Sony Cybershot DSC-T200 Digital Camera
All of a sudden the camera won't turn on, I have 2 batteries and they are both charged, but it acts like the batteries are dead and turns on for half a second and then nothing.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 09, 2010
My G1N suddenly stop power dead until now I cannot use it .pls help
see this tips and fix it.
If the camera won't turn on, check the batteries with the same type alkalines FULL , or connect the camera to an AC adapter .
2) batteries loaded with wrong polarities
3) memory card slot/battery cover is open
4) batteryies are not the same type
5) insufficiente battery voltage.
6) poor contact between camera and battery terminals. Polish the terminals.
Oct 04, 2012 | Cameras
Camera was low on battery. Took a couple of pictures with no problem then got it home to charge the battery and the camera is dead. Won't turn on or charge. Tried plugging it in directly with the...
1. Check if the battery is positioned and seated well in the camera.
2. If OK, and problems persists, exchange the battery and recheck.
3. If that does not help, your camera needs probably to be repaired.
Aug 05, 2011 | Olympus SP800UZ Digital Camera
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
My phone is completly charged and when i pull it off charge about half an hour after depending on how much i use it, it turns itself off and then when i try turning it back on the Lg start up comes on then...
The happy news is there is no problem with phone,the hardware of your phone is in good condition.The problem is the battery.The battery of the phone is dead.This a step behind Stone dead stage.Next state of your battery is stone dead.You can't even use it more.Now the phone Battery will act like charging.Your battery can take small amount charge only because it is dead..Even though you charge your battery for 2 days continuously it will stay for 30 min or 10 min depending the charge usage.
Solution for this is you have to replace it soon..Go to nearest shop and check this with their battery and buy it.
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | LG KU990 Viewty
G7 just dead. can't turn on power. check battery
These G7 powershot cameras sometimes get a short from a loose screw which often leaves the camera with no power. You'll want to have it fixed but with a place that knows of the problem and does the correction inside the camera so that it doesn't keep happening. The place that just does powershots and they do amazing work on these cameras is: www.camerasandparts.com They charge about half of what canon wants to fix this problem and the include the service and the correction to the screws inside so it won't keep happening. It's $89 for everything with them, a great deal and they do superb work on these cameras.
Feb 27, 2010 | Canon Camera Multimedia Projector
My camera turns off right after i turn it on. it
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Unfortunantly KODAK do no longer repair this model. They offer a Trade up option where you for 25-30% cheaper than the listed price can exchange the camera to any newer model provided KODAK has the model in stock.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 24, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Camera wont turn on
I actually fixed mine... please read all instructions b4 making actions...
i dont know how but ill tell u wat i did. (brace urself.. i will rambling a bit with unnecessary details, but it may help u... SO
i went to target... where i bought the camera and
1. bought a new battery b/c other forums said its the battery thats deffective.... This didnt help because i put the new battery in and it did the same thing.
2. i cleaned the new battery with a q-tip (the 3 metal parts.. and the inside of the camera where the metal parts connect) This did not work either
3. Clicked it to FAVORITES cuz i knew it was able to review pictures... i clicked menu and i reformatted the Month day and year and time (because it said it was wrong)... that didnt help...
4. finally... i decided this may work like the iPod.. so i held down the ON/OFF button while holding down the Time/Ascending Folder button (its in the circular panel where OK button is ... it is the button under OK on the circular panel) ... and eventually that green blinking light kept blinking... and all of a sudden i the monitor was showing picture again .. i took a picture of myself... deleted it... went back to camera mode... turned off the camera turned it back on... and its back to normal....
4- 1/2. I but back in my old battery... and it works like normal
IN CONCLUSION.... maybe its not ur battery. .so b4 u go out and spend 29.99 onn a new rechargable... follow my instructions and maybee it will work for u too!!
Jun 20, 2009 | Kodak EASYSHARE M763 Digital Camera
When i turn key it acts like a dead battery , battery is charged
1. There is a wiring connection that is draining the battery.
2. The alternator needs to be checked.
Cheers.
May 22, 2009 | 2000 Mercury Mystique
Sony Cybershot DSC-T200 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
