Question about Avanti Dryers
Avanti washer/dryer Model WD 2001S..... Need small gear that meshes with and turns washer barrel.
3 Suggested Answers
emissionwiz
  • 76846 Answers
SOURCE: Avanti D24 dryer....manual on how to install new
go to the link below for instructions with pictures of th ejob.
http://www.diynetwork.com/how-to/how-to-replace-a-dryer-belt/index.html
Posted on May 23, 2010
SOURCE: I need an exhaust filter for my Avanti dryer.
I've seen two indoor vent kits that on Amazon that people use with this dryer.
http://www.amazon.com/Dundas-Jafine-TDIDVKZW-ProFlex-Indoor/dp/B000DZFTC6/ref=pd_bxgy_k_img_b
and
http://www.amazon.com/LTF-Supurr-Flex%C2%AE-Lint-Trap-Kit/dp/B00009W3HD/ref=pd_sim_hi_6
Hope that helps! :)
Posted on Nov 26, 2010
Need user manual for Sonya compact dryer
Hi, could not find a users manual for sonya SYD-60E dryer so that I could order a thermal fuse, as the dryer would not run, however, I found a blog that suggested that Avanti, Sonja and Panda were made by the same manufacturer, I found a phone number for Avanti, ordered the thermal fuse for the only model that Avanti sells, which cost $10.00, and in about 10 business days the part arrived, we installed it in our Sonya dryer and our dryer works beautifully! Hope this helps
May 24, 2016 | Dryers
If Avanti doesn't carry this model anymore , how can I replace the belt on my Avanti electric dryer model D-24?
Hello Anonymous,
Take the belt to your local appliances parts store, they should be able to match it up.
Good Luck,
JP
Jul 02, 2015 | Avanti Dryers
Where can I find a motor for an Avanti D-24 Electric Dryer?
Hi
This company sells your parts but you will need the model number. This link tells you exactly where that number is found.
Return to the home page with the model number for a link to ordering the appropriate part. Hope this helps.
Dryer Model Number Locator - Find the Right Part for Your Dryer with PartSelect:
http://www.partselect.com/Model-Number-Locator+5+repair.htm
Jul 13, 2014 | Avanti D-24 Electric Dryer
Washing machine
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
When replacing my rear wheel bearing and oil seal the two small gears in the pumkins feel out I need to know how to put them back in
There should be 2 cone type washers with the gears, the washers go on the bigger part of them, they will set into the hole in the center. First, rotate the gear carrier so you can reach both sides, take both gears with the washers in place and lightly hold them at 180 degrees so they mesh with the side gears. You then rotate one axel slowly to roll the small gears into place [ this may take a couple times to get them lined up so the shaft will go back in]. When you install the locking bolt, it would be a good idea to clean the threads on both parts and use a thread locking compound.
Apr 18, 2011 | 1987 GMC VanDura
My Hamilton Beach Food processor model # 702-1 has a BROKEN plastic gear that attaches to the motor drive shaft (it threads onto the shaft). It meshes with another plastic gear that turns the spindle that...
my suggestion is that watever spare part u replace, get it replaced by the original manufacturer to avoid future problems. take it to the shop you have bought it from, ask them where u can get one. they may help u better with contacting the manufacturer. i know its time consuming! good luck!!
Oct 14, 2009 | Food Processors
Oil leaking from washer
if it smell like wd 40..your transmission is defective,,need help replacing post question,,
Dec 27, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryers Logo
181 people viewed this question
Top Avanti Dryers Experts
Tim Whalen
richie46
Are you an Avanti Dryer Expert? Answer questions, earn points and help others
