Question about RTO Stairmaster Clubtrack 510 Treadmill
MOTOR OVER-LOAD E203 - RTO Stairmaster Clubtrack 510 Treadmill
  • 79 Answers
Begin to explain what you mean E203 according to the technical manual:
High Motor Overload caused by one of the following:
1: Runner heavier than weight/speed envelope in conjunction with significant deck wear.
Recomendation: Restric use to people within the weight/speed specifications and check deck wear, replace if necessary.
2: Motor lead disconnected or loose
Recomendation: Check the motor leads to ensure all leads are connected. One loose or disconnected lead will cause the overload.
3: Electrical failure on the drive electronics
Recomendation: replace VSD (Electronic board)
at this point I suggest you check, a small electronic card that is in front of the machine. withdraw the engine cover and you can see it. has mounted two black wheels attached to each other. these are two thermistors are burned if you should change them. because if you change the VSD will cost you dearly
I hope this information helps you, but can write to cardiotech_me@hotmail.com
Posted on Sep 08, 2010
Quinton treadmill E203 error VSD Lower Board
Quinton E203 Error, Motor Overcurrent (Overload) Probable Cause 1. Obstruction to motor pulleys or belt
2. Disconnected or loose motor lead
3. User outside the weight/speed envelope.
4. Excessive wear to deck/belt.
5. Motor.
6. Lower Electronics.
Corrective Action Quinton Treadmill Models: Club Track 3.0 and Hyperdrive
  1. Inspect for obstruction and remove if necessary.
  2. If the motor did not turn, inspect for loose or disconnected motor lead. Reconnect if necessary.
  3. Restrict users to weight capacity of unit. Restrict use to people that do not move slower or faster then speed setting.
  4. Inspect deck and belt condition. Deck should have a slick smooth surface, free of nicks, grooves, or rough areas. Deck should be flipped or replaced if necessary. Underside of belt should not have a hard glazed appearance. Belt should be replaced when deck is flipped or replaced.
  5. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If unit operates and then error appears again, replace drive motor.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is greater than 100 ohms, the motor needs replaced.
  6. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If error message appears immediately, replace the lower electronics.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is less than 100 ohms, replace the lower electronics.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Quinton Treadmill E203 Error Code
Feb 20, 2013 | RTO Stairmaster Clubtrack 510 Treadmill
Tip
ERROR codes Canon 8570
Canon 8570 E000 Fuser problem. Temperature too low. Heat lamp, thermal fuse or thermoswitch, thermistor, triac etc E001 Fuser problem. Temperature too high. Probably triac E005 Fuser web finished E005 Fuser cleaner belt user up E010 Drive E010 Main drive problem E011 Drive problem. Could be main motor, scan motor, cleaning web motor or duplex motor E011 Main motor, scan motor, cleaner belt motor, duplex motor, toner motor, lens motor or driver bd. for any of these E020 Toner sensor problem or lack of toner feed. This occurs if toner feed signal is present for 3 min E020 Toner empty sensor sees no toner added for 3 min probably toner feed problem E050 Duplex problem E050 Duplex problem E203 Scan motor problem E203 Scan motor E210 Lens motor problem E210 Lens home sensor or lens won't leave home E240 DC controller board E240, E241, E242 Control board (main board) E241 DC controller board E242 DC controller board E243 Operation panel board E243 Operation panel E400 DC controller, ADF board or 24V E400 DC controller or document feed board E500 DC controller or sorter board E500 DC controller, sorter board or 24V E510 Finisher; feed motor, pulse sensor, finisher board E510 Finisher E520 Finisher; stack motor, stack tray sensor, finisher board E520 Finisher
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 8070
Canon 8070 E000 Fuser problem. Temperature too low. Heat lamp, thermal fuse or thermoswitch, thermistor, triac etc E001 Fuser problem. Temperature too high. Probably triac E005 Fuser web finished E005 Fuser cleaner belt user up E010 Drive E010 Main drive problem E011 Drive problem. Could be main motor, scan motor, cleaning web motor or duplex motor E011 Main motor, scan motor, cleaner belt motor, duplex motor, toner motor, lens motor or driver bd. for any of these E020 Toner sensor problem or lack of toner feed. This occurs if toner feed signal is present for 3 min E020 Toner empty sensor sees no toner added for 3 min probably toner feed problem E050 Duplex problem E050 Duplex problem E203 Scan motor problem E203 Scan motor E210 Lens motor problem E210 Lens home sensor or lens won't leave home E240 DC controller board E240, E241, E242 Control board (main board) E241 DC controller board E242 DC controller board E243 Operation panel board E243 Operation panel E400 DC controller, ADF board or 24V E400 DC controller or document feed board E500 DC controller or sorter board E500 DC controller, sorter board or 24V E510 Finisher; feed motor, pulse sensor, finisher board E510 Finisher E520 Finisher; stack motor, stack tray sensor, finisher board E520 Finisher
E203 error message when i press start button
5. Motor.
Jan 09, 2013 | Exercise & Fitness
Quinton treadmill error 203
5. Motor.
Jun 16, 2012 | Exercise & Fitness
Tip
ERROR codes Canon 4540
Canon 4540 E00 Low fuser temperature E001 High fuser temperature E010 Main motor clock pulse E011 Bind or load on main motor E020 No TF for 3 minutes E030 Copy counter E050 Duplex unit E201 Scan motor E203 Scan motor E210 Lens home E240 DC controller E241 DC controller E320 CCD E400 DC controller, 24V E500 DC controller, 24V E510 Finisher feed motor E520 Stacker motor E530 Guide plate shift motor E531 Stapler motor E620 DC controller, edit board
Tip
ERROR codes Canon 4035
Canon 4035 E000 Low fuser temperature E001 High fuser temperature E010 Main motor clock pulse E011 Bind or load on main motor E020 No TF for 3 minutes E030 Copy counter E050 Duplex unit E201 Scan motor E203 Scan motor E210 Lens home E240 DC controller E241 DC controller E320 CCD E400 DC controller, 24V E500 DC controller, 24V E510 Finisher feed motor E520 Stacker motor E530 Guide plate shift motor E531 Stapler motor E620 DC controller, edit board
on Jan 18, 2010 | Office Equipment & Supplies
E203 error message on Quinton Clubtrack treadmill
Dear Sir:
Your problem is lack OF LUBE, do it in according with the instruction manual maintenance, is to due worn deck.
This produce enough friction between deck vs deck belt.
3) Test the input voltage for main motor if there are voltage motor need repair or replace.
4) Test the output voltage from main board, if there are NOT, the board is faulty.
5) Try to RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you
Apr 30, 2012 | Exercise & Fitness
Quinton clubtrack treadmill shows E203 code, says drawing more than specified current. Could it be a bad motor?
5. Motor.
Dec 06, 2011 | RTO Stairmaster Clubtrack 510 Treadmill
I have a quinton club track treadmill that posts an E203 error
E203 = Motor unable to run. Usually caused by the VSD Lower Board. This board is about 14" square on a Quinton Clubtrack Hyperdrive 3.0
Rather difficult to remove escpecially if your not familair with electronical compnents in a tight space.
My reapir coast $374 from J&R Technical Services and exactly one year later I got the exact same code. Warranty is 90 days.
It appears they rebuilt one of the components on the board called a Phase Modulator. There are three of them. They stated they had replaced it, but upon close inspection it appears that simply replaced the bad micro-component on the modulator and reinstalled the exact same phase again.
I'm debating whether to trust them once again. Little choice though since they control the market and have the equipment to reset the board upon repair. Nobody at thome has this equipment.
Sep 15, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
RTO Stairmaster Clubtrack 510 Treadmill Logo
262 people viewed this question
Top RTO Exercise & Fitness Experts
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
