Question about Panasonic Viera TX-32LX70 32 in. LCD TV
I have a new 32" panasonic 20b after a week it has now started to turn its self off. we took it back to the retailer they said they fixed it turned off the stand by timer. got it back home same thing turns its self off checked timer off and stand by off no diffrence returned it back to factory settings still no joy the set stays on for only 7 to 10 mins.it is only conected via a coaxial cable
  • Panasonic Master
  • 8,457 Answers
This tv have power supply problems,take it back to retailer demand an exchange or call Panasonic for a warrenty repair.
Posted on Sep 08, 2010
Testimonial: "good will try again"
My audiovox 32" 3205 died a few weeks ago and took
Not a projection set if 32 inch---If looks like blotches try turning set with it on to see if they change--if so you may have not plugged the degaussing coil (usually a two pin plug) back in when you did the repair--it goes on the power board.
Jun 16, 2012 | Televison & Video
Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
TV TURNS ON THEN TURNS OFF AND RED POWER LIGHT FLASHES.
TV shut self off.Will not turn back on. No red light,no signal of anything.
Dec 28, 2009 | Panasonic CT-32HXC14 32" TV
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to http://store.ramplus.com/fsfspopfrpos.html
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
Jan 04, 2009 | ViewSonic NextVision N3260W 32 in....
Panasonic PT-51DX80A
Look at the main circuit board do you see any burned resistors?
I had this same problem.
Sep 28, 2008 | Panasonic PT-51DX80 51" Rear Projection...
Samsung le32r74bdx 32
i have a $1256 samsung 40'' lcd i have had it for about 1.5 years..just long enough for the warranty to expire..i went to turn the tv on like nomal but all i got was a ed blinking light..and than it would go out after the relay inside clicked a few times.tryed all the to fix it my self..new power cord,diffrent outlet,letting it sit unpluged for 24hrs.ect..finally i took it off the wall took the back off to see if any fusses were blown out. nothing it all looked good to me.so i took my air commpeser to it and blew the whole thing out..put it all back together..and it turned on red light was off and just a hint of light at the edge of the screen...so i was like ok and began to play my ps3 and after about 45 min i just shut off ..nothin would work back to the blinking ed light.i have not messed with it for 3 weeks and yesterday tryed it again.nothin but relay click and red light...so i hit my tv at the bottom by the switch and i came on...i couldnt believe my eyes..it was short lived after watching it for 5 hrs tuned it off and went to bed...in the morning i ran down stairs to turn on my tv..but yet again black..i was not going to spend $300 to $700 to get it fixed..so to day i got my air commpeser and blew it out again..this time i was messing with the power cord right where is hooks to the tv and the red light stayed on solid like it was in stand-by so i pressed the power button and it turned on..so long story..check the power cord and blow out you tv.."but be carful"
Aug 09, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Dmr e85 will not start up
Hi Audi,
Try unplugging the hdd & then turn on the dvd recorder & wait for about 5 minutes.
Then unplug the dvd recorder & plug in the hdd & turn back on the dvd recorder to see if that fixes the problem.
Oct 18, 2007 | Panasonic DMR-E85H DVD Recorder
Rca f27450 TV
It sound like your set have dryjoints
Oct 11, 2007 | RCA 32F531T 32" TV
Panasonic Viera TX-32LX70 32 in. LCD  TV Logo
460 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
